06-22-2009, 04:31 PM
#1 |
befuddled
Oddometer: 8,137
Mapsource Waypoint
I have 50 or so .gpx files that are waypoints. Is there a way to open them all up at one time using Mapsource Topo?
STURGIS ride report. 2009 R1200 Gelände/Straße Abenteuer A GS is like chlamydia, it grows on you whether you want it to or not. WhiteManFlail Save $5 on Smugmug "1alkVgTNLEuyQ"
06-22-2009, 04:39 PM
#2 |
Exchange your GPS Track!
Oddometer: 2,515
not that I know - but GPX is a file in XML format, it's easy to open them up and concatenate them using say Notepad++ (free text editor)
06-22-2009, 04:47 PM
#3 |
REMF
Oddometer: 8,546
You could just open up one Mapsource window as a "master" then open up each .gpx and copy/paste the waypoints into the master file.
Mike S. '09 Bonneville Black AMA MSTA STOC http://autos.groups.yahoo.com/group/...orcycleriders/ |
06-22-2009, 07:41 PM
#4 | |
Oddometer: 3,978
Even if you could open all 50 files with one click they are still 50 seperate files that can only be viewed 1 at a time. Like outlined above, bite the bullet and copy each waypoint to one "master" file then it is done for life.
Jerry Counts |
06-23-2009, 07:39 AM
#5 |
befuddled
Oddometer: 8,137
Thanks for the help. I was really hoping for a simple very fast way.
06-23-2009, 08:11 AM
#6 |
Wannabe
Oddometer: 1,242
If you're using OS X (or Linux), I can write you a quick and dirty script that will combine multiple GPX files into one but for Windows, it'd mean installing add'l software.
Let me know... |
06-23-2009, 08:41 AM
#7 | |
Oddometer: 1,347
However, you can use other software such as gpsbabel to combine them into one. For examples, see http://www.gpsbabel.org/htmldoc-deve...ced_Usage.html If you are using gpsbabel with M$ Windows: In the file-open dialog, press and hold the CRTL button; then you should be able to select more the one file from the listing. Here, all selected files must be from same type (GPX).
Greetings from Lausanne, - Joerg -- 1990 BMW R80GS and K100LT Jörg's Motorcycle Pages - pfranc of Switzerland |
