Old 06-26-2009, 08:47 AM   #1
das Motorradreiter OP
Diehard Extraordinaire
das Motorradreiter's Avatar
Oddometer: 321
Anybody use/make a carburetor testing temporary fuel tank?
I'm having the fuel tank to my wife's 250 Ninja restored. (It was rusting inside when we bought it recently.) I just had the carbs cleaned by a friend since they were clogged with rust particles and gum deposits from sitting for eight years. I'd like to make sure the carbs are going to run okay while I wait for the tank to be finished. Has anyone made a temporary fuel tank to hook to the carbs for testing purposes?
BTW - I will be installing an inline fuel filter when all is done.
das Motorradreiter is offline   Reply With Quote
Old 06-26-2009, 08:54 AM   #2
Pointyhead
Single Malt Sampler
Pointyhead's Avatar
Oddometer: 187
Try to get a small lawnmower gas tank, I got mine from my neighbor.
This space for rent!
Pointyhead is offline   Reply With Quote
Old 06-26-2009, 12:17 PM   #3
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,355
If you want to keep it, use a metal can and solder a small piece of copper tubing to the bottom. I had to fab one up a couple years ago and I just used a 20 oz plastic coke bottle and epoxied an old piece of tubing into the bottom, then tossed it in the trash when I was done.
GreaseMonkey is offline   Reply With Quote
Old 06-26-2009, 12:50 PM   #4
R-A-M-O-N
Oddometer: 297
Cleaned engine oil bottles with plastic tubbing worked just fine for me.
R-A-M-O-N is offline   Reply With Quote
Old 06-26-2009, 12:59 PM   #5
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,091
+1 on snagging a lawnmower tank. People down here put mowers to the curb quite often. I got one of the nice plain rectagular models with a decent bracket attached off of an old edger.
If you want to go one step fancier, go to the local Ace Hardware and add a shutoff valve inline just below the tank hose barb
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 06-26-2009, 01:36 PM   #6
stevets
Dirt Rider
stevets's Avatar
Oddometer: 225
lots of ways to make this - I used a fuel tank from my RC plane - it worked great
Only thing to make sure is that you secure it well before you start the engine - don't just sit it on the seat - the engine vibration can make it spill - last thing you want to do is spill fuel on a hot or running engine
stevets is offline   Reply With Quote
Old 06-26-2009, 04:06 PM   #7
Ranger Ron
Ranger Ron's Avatar
Oddometer: 765
There is always the Motion Pro auxiliary tank:
http://www.ronayers.com/catalogs/pu/...d=105&type=587
They seem to have about doubled in price the last few years, though.
Ron
Ranger Ron is offline   Reply With Quote
Old 06-26-2009, 04:33 PM   #8
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,742
I keep an old wr450 tank around for just those purposes, it, short so it will fit on just about any frame and made of plastic so it won't rust, no fussing around strapping on temporary tanks.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 06-26-2009, 05:38 PM   #9
Wreckchecker
Ungeneer to broked stuff.
Oddometer: 2,947
Sorta +1
I have a bulkhead fitting from the hardware store and have used it with a 2 liter soda bottle. Works fine.
But you're using so little gas to just see if the bike runs, simply setting a coil of fuel hose on the platform of a step ladder works great. Stick a funnel in the top end and it doesn't get simpler than that! Make sure it won't fall and spill. Yes, btdt.
Super Tenere & WR250R, AMA, IBA
http://s198.photobucket.com/user/Che...France%20Spain
Wreckchecker is offline   Reply With Quote
Old 06-27-2009, 06:24 AM   #10
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,853
metal tank off an old honda stationary engine/lawmmower with a fuel tap , hose & inline filter.
then mount to a old floodlight tripod stand for gravity feed is what i use.
the other side of the stand i hang my carbtune.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 01-18-2013 at 03:26 PM
veetwo _tls is offline   Reply With Quote
Old 06-30-2009, 12:19 AM   #11
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,928
Drill a hole in the cap of a soda bottle, insert some clear tubing thats a little thicker than the hole you drilled so it holds via friction and seals. Or you can use a ziptie to keep it from sliding out.
Take a coat hanger and make it straight while leaving the hook on the opposite side of the hose, tape it to the bottle, hang it up. Done.
Contrary to popular belief gas will not eat through most soda bottles. Just check with the "gas stations" south of the border. Those people use soda bottles to store their fuel and they reuse the same bottle for years.
Or cheap skate method, use an oil funnel with a thin enough end to shove into the carbs fuel line or an oil funnel with a vinyl hose. They also make ones with a closeable top.
HaChayalBoded is offline   Reply With Quote
Old 06-30-2009, 05:38 AM   #12
LostRider
Motorcycle Addict
LostRider's Avatar
Oddometer: 237
Whatever container you use gas tank or soda bottle will work fine. Use clear fule line and don't sit there watching the fuel level drop down the line and into the carb and then start screwing with it cause it's not running right.
Some things are just to much fun to stop doing.
LostRider is offline   Reply With Quote
Old 06-30-2009, 07:16 AM   #13
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,248
I used to use a 1 gallon plastic gas container. I just drilled out the vent hole large enough to allow a brass nipple to be screwed in so a hose could be fitted. Then I tipped the can onto its back side on the work bench. When finished with it, unscrew the nipple and replace the vent cap and the can is just like normal again. Still have the gas can and use it for the lawnmower fuel, all our bikes are EFI now so I haven't needed it for a bike in a while.
MCMXCIVRS is offline   Reply With Quote
Old 06-30-2009, 07:41 AM   #14
nitsuj
Oddometer: 399
You're only limited by your imagination. If you go to the "Show u your man castle" thread, you'll see a pic of my garage. Along the right wall, near a stack of tires, you'll see what looks like a coolant reservoir hanging from an adjustable height stand. What that is, is, well, it's a coolant reservoir hanging from an adjustable height stand. I salvaged it from a pile of junk parts at a dealer. The stand it just some thing I got from a store that was going out if business, it was an adjustable sign. Nice thing about the coolant bottle is that it has a hose fitting on the bottom, and it also has one up high on the filler neck used as an over flow. That works as my vent. The adjustable stand is nice because I can raise it all the way up and still have it above carb level on a bike lifted all the way up on my lift.
Be creative. This is one shop tool you can have for very, little if any, money.
nitsuj is offline   Reply With Quote
Old 06-30-2009, 03:17 PM   #15
Solo Gato
Solo Gato's Avatar
Oddometer: 773
Dont forget the all important after- the-fact Garage sized Fire extinguisher
admitting there is a "machine" in your house that your wife knows how to use and you don't deserves a kick in the balls. Joe
Solo Gato is offline   Reply With Quote
Times are GMT -7.   It's 11:48 PM.
