Old 11-06-2011, 12:19 PM   #31
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,430
32 years ago, took a 1 gallon laquer thinner can, soldered two 1/8" NPT half couplings in the side. Brass drain cocks with barb fittings. Still works fine.
Old 11-06-2011, 12:28 PM   #32
squish
Out of the office.
Oddometer: 6,407
Originally Posted by sporthog93 View Post
i am using my second Motion pro tank, the first one burned up. fire extinguisher is an excellent idea.
There is some wisdom in the post... Did the first one burn up due to the tank or operator...
On vacation for a spell
squish is offline   Reply With Quote
Old 01-16-2013, 11:05 AM   #33
bob393
bob393's Avatar
Oddometer: 392
I put a push in rubber gromit fitting in the bottom of a quart Nalgine bottle, have been using it for years.
And yes: I have no idea how to spell gromit!
2007 R1200GS almost farkeled to perfection!
bob393 is offline   Reply With Quote
Old 01-16-2013, 01:40 PM   #34
markjenn
Oddometer: 10,473
Saw this while looking at Amazon the other day... seemed a lot cheaper than the aux tank options I looked at a few years back.
http://www.amazon.com/motorcycle-sho...8372381&sr=1-1
- Mark
Old 01-16-2013, 01:48 PM   #35
damurph
Cold Adventurer
damurph's Avatar
Location: The far east of the far east of North America
Oddometer: 2,004
I have used a large catheter tip syringe available at most drug stores and some clear tubing. Zip tied to the frame of the machine and runs for a few minutes.
If I still had every dollar I spent on motorbikes I would be a richer man but a poorer person.
damurph is offline   Reply With Quote
Old 01-18-2013, 11:55 AM   #36
RAL88
Marineboy
RAL88's Avatar
Oddometer: 77
I use a coolant recovery tank form Pep Boys. Already has the nipple on the bottom, is made of fuel proof material and all I do is change the vinyl hose to fuel hose. Cheap and easy.
Rich
____________
'96' K1100LT-SE
'97' R850GS-R
"If it ain't broke take it apart and make it work better"
RAL88 is offline   Reply With Quote
Old 12-14-2014, 06:15 AM   #37
Fat Monkey
Fat Monkey's Avatar
Oddometer: 199
$5.99 At HF for the disposable paint gun liners (4 left over)
$5.00 for a couple of brass fittings.
Some wire for the hanger and hose I had laying round and needle nose vise grips for a "valve". Worked pretty well for something that was shabbed together in 10 minutes
The fittings I used were not ideal but it is what I had. I could have used the plastic one that came with the cups, but I was too lazy to go to HD and get the nipple needed to fit
I have 4 more paint gun cups if anyone around Joplin would like to stop by and pick one up.
BTW, excuse the shop! It is always a mess
FM
Fat Monkey is offline   Reply With Quote
Old 12-14-2014, 06:39 AM   #38
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,430
I used a gallon lacquer thinner can, soldered a 1/8 NPT half coupling near the bottom, brass drain cock valve, hose barb, been working great 35 years. YMMV
Old 12-14-2014, 06:12 PM   #39
JohnCW
Oddometer: 1,412
I just use place my tank on the bench with a long length of plastic hose when I'm syncing the carbies. But as you haven't the tank, I reckon any container located higher than the carbies, a plastic hose pushed into in the top of it, and a outboard primer bulb somewhere in the plastic hose to get the fuel siphoning would work.
I use an outboard primer bulb to siphon all fuels e.g empty the car petrol tank. But them I'm into boating and always have one on hand as a spare. But they are relatively inexpensive and sold at every decent boat supply shop.
JohnCW is online now   Reply With Quote
Old 12-14-2014, 06:28 PM   #40
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,210
---Albert Einstein
Old 03-14-2015, 05:23 PM   #41
keensali
Oddometer: 1
Another inexpensive idea....
Hopkins Flow Tool on AMAZON
http://www.amazon.com/Hopkins-FloToo...kins+flow+tool
Put this fella on a 1 gallon gas can and flip it upside down. Can turn the flow off or on at the neck of the nozzle. No leaks on mine what so ever and all for less than $4 before shipping....
keensali is offline   Reply With Quote
Old 03-14-2015, 05:56 PM   #42
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,853
Old flood light stand with a lawn mower plastic fuel tank total $15Aud & usually hang my carb tune pro 2 on the other side of the stand.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 03-14-2015 at 06:07 PM
veetwo _tls is offline   Reply With Quote
Times are GMT -7.   It's 05:59 AM.
