Old 06-27-2009, 08:38 PM   #1
proxyissues OP
Oddometer: 234
Micatech bag complaints? Anyone?
I'm in the process (like many people) of narrowing down what panniers to get, and I'm leaning towards the Micatech bags (Pilot as V2's seem to have same bike width as the 12" pilots but are smaller).
Anyone with them have complaints about them they want to air?
proxyissues is offline   Reply With Quote
Old 06-28-2009, 04:02 AM   #2
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,451
i've never had Micatechs, only seen them. they look fine, a bit large, like having two gigantic toasters on each side of the bike. seemed to be made well with a good capacity. i didn't study the rack (which i hold more important than the boxes themselves) so i can't comment. they seemed to be priced about right, same as Jesses, same as Touratechs, etc.
all i can say is this:
if i ever, ever consider buying a side-opening pannier again, i'm going to slap myself. what a PITA. what i needed was never in the front, things spilled out no matter how many bags i used, and taking the actual box off the bike often required removing most of the contents since the mounting pucks are deep inside the pannier.
on the whole they look fine. i think it could be a solid move.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is online now   Reply With Quote
Old 06-28-2009, 04:10 AM   #3
andmoon
andmoon's Avatar
Oddometer: 3,190
costly they are!
POVERTY SUCKS
andmoon is offline   Reply With Quote
Old 06-28-2009, 07:58 AM   #4
Eyes Shut
See no evil
Eyes Shut's Avatar
Oddometer: 2,116
I like 'em. The only downside seems to be the left-hand side one (adjacent to the exhaust) gets too hot for storage of heat-sensitive things, like chocolate, for example..... but that can be fixed by placement of a heat-shielding material on the outside of the case.
Eyes Shut is offline   Reply With Quote
Old 06-28-2009, 08:03 AM   #5
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,097
The other minor downside is that they block access to the lock to remove the seats (which you can get around with pull wires to bypass the locks).
I have never had anything fall out when opening them up and we pack them pretty full for multi-week 2-up camping trips. I previously had Jesse to loading cases, and much prefer the side loading Micatechs.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 06-28-2009, 08:29 AM   #6
ADVDAD
Trip-n on da Beemer
ADVDAD's Avatar
Oddometer: 78
I have bothe the panniers and the 55ltr top box, nothing finer!!! almost 50,000 miles on them with no problems and no leaks!! Super fast on and off, bullet proof!! I am listing mine on the forum for sale because i'm selling the bike, along with a Russell and a Marsee Twist lock tank bag.
I RODE TODAY, DID YOU?
DUE TO BUDGET CUTS, THE LIGHT AT THE END OF THE TUNNEL HAS BE TURNED OFF!!!
07 BMW 1200 GS
00 KLR 650
IBA #32390
www.dadsgallery.com
ADVDAD is offline   Reply With Quote
Old 06-28-2009, 08:41 AM   #7
LeftCoastLefty
Long Time Lurker
Oddometer: 36
No complaints
The left one is smaller, warmer, more prone to stuff falling out, and it blocks the lock. But these are all manageable problems and well worth it, IMHO.
I put my expensive stuff in the right one. My laptop fits perfectly across the wheel-side wall. I use Eagle Creek's Pack-It system to keep things organized. There are several work arounds for the key issue.
-duane-
LeftCoastLefty is offline   Reply With Quote
Old 06-28-2009, 01:37 PM   #8
GB
Mod Squad
GB's Avatar
Oddometer: 56,852
Originally Posted by BobbySands
if i ever, [I
ever[/I] consider buying a side-opening pannier again, i'm going to slap myself. what a PITA. what i needed was never in the front, things spilled out no matter how many bags i used,
You obviously haven't used the Micatech semi side loading cases. When you open the doors, NOTHING falls out, and you can load the pillion deck and still access the contents of the cases. The mounts are invisible once the cases are removed and customer service is second to none.. and that for me, is the most important factor in just about any purchase.
Try this with a top loader
Old 06-28-2009, 03:16 PM   #9
harland
Oddometer: 46
I had the system cases on my 06 gs and did not like them. Too flimsy (plastic) and not big enough. Have the BMW aluminum cases (side and top) on my 07 GSA. They are OK but tend to turn anything light colored that is put into them black. Always have to take something off the bike in order to get into the side cases. Have the Micatech side cases and the largest top case they make. These are the cases to keep. They hold probably more than half again what the BWW aluminum side cases hold and there is absolutely no comparison on what the top case will hold. I have a 17 inch Macbook Pro, a Nikon D80 in a camera bag, a pair of binoculars, a rainsuit, 3 hardback books, gloves and number other smaller items in the top case and it will still hold more. Have never had anything fall out of the side cases because of the way they are made and I do not have to unload something from the bike in order to get to the sidecases. I seldom take the seat off so the case is not really a problem. And besides they have service second to none. I had a very small leak in the top case and called Sue. She said send it back and I did. They fixed the leak, put a larger rubber gasket on and repowdercoated the case. No charge. Service second to none. My next bike will also have Micatechs.
harland is offline   Reply With Quote
Old 06-28-2009, 05:22 PM   #10
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Worlds finest craftsmanship
The folks that manufacture the Micatech's are a customer of mine I've known for 14 years. (I repair the CNC metal fab. machinery) and I have seen the product being built. All TOP notch engineering and build quality. Bikes everywhere being fitted and such. These panniers are the best no-compromise design I've seen. This is 37 years of motorcycling and 31 years of professional metal fabricating experience talking to you.
Old 06-28-2009, 08:24 PM   #11
VonHelm
soggy doggy
VonHelm's Avatar
Oddometer: 4,000
Everyone likes to make fun of the way they look...
Until they look closer, and see how they're built.
http://www.oilandpiston.com/
Well he’s one of those who knows that life
Is just a leap of faith
Spread your arms and hold you breath
And always trust your cape (Guy Clark)
VonHelm is offline   Reply With Quote
Old 06-28-2009, 10:00 PM   #12
Roadie
2-Wheels Rule
Roadie's Avatar
Oddometer: 158
i love my new Micatechs. I've had System cases and Jesse's. There's no comparison. Huge capacity, unparalleled customer service the highest quality.
I'd buy them again in a heartbeat.
Roadie is offline   Reply With Quote
Old 06-28-2009, 11:08 PM   #13
DJ Tomás
DJ Tomás's Avatar
Oddometer: 40
I like mine...but
I wish I could fit my helmet into the right side case. I have an XL Arai that won't fit inside the right case as advertised.
DJ Tomás is offline   Reply With Quote
Old 06-29-2009, 03:22 AM   #14
Petethepup
Petethepup's Avatar
Oddometer: 80
Micatech convert here
Installed used Micatechs on 2008 GSA. Took a little 2 week, 5600 mile camping trip.
1. Huge bags. If you need bigger, check the Ford or Chevy truck catalogue.
2. Very well made. Strong aluminum, simple construction.
3. Very easy to use. I love the semi-side loading. When the lid is open, it never pops off the strap (unlike OEM occasionally). Plus, the lid has a 1/2 inch lip that holds stuff that is sitting on the lid.
4. Yes, you have to install a seat-opening wire or string, no big deal.
5. When the bags are off (most of the time in my day to day) the racks are the least obtrusive of any on the market. MUCH less so than the OEM erector set.
Petethepup
I used to love bikes.
Now it's gotten serious.
Petethepup is offline   Reply With Quote
Old 06-29-2009, 07:08 AM   #15
ChiefPilot
Rather be flying, but....
ChiefPilot's Avatar
Oddometer: 80
I had BMW Vario system bags on my '06 GS. They were replaced of this past winter with Micatechs.
LOVE the new Micatechs. Side loading these bags is not a problem and NOTHING falls out even when stuffed to the max with gear.
Heat in left bag has not been an issue and I recently added the Excel exhaust extenders to ensure it stays that way.
They are stout and waterproof. I tested both (oops) and rode 8 hours through much rain and wet roads. All dry all the time.
The seat key thing is kind of a pain, but not really a big deal with the wire installed.
Plus, their customer service is about the best you'll ever find from any vendor.
Good luck.
'12 K1600 GT
'06 R1200GS Leaving the Garage Soon.....
If you are in trouble anywhere in the world, an airplane can fly over and drop flowers, but a helicopter can land and save your life. - Igor Sikorski, 1947
ChiefPilot is offline   Reply With Quote
Times are GMT -7.   It's 02:42 PM.
