Old 06-30-2009, 10:11 AM   #1
jossef OP
Oddometer: 37
My DR650 Rebuild Project Thread (Yossi / Israel)
Hi everyone,
I would like to start a rebuild thread of my DR650.....as I promise to Mezo last week. since it is my first time here let me introduce myself....My name is Yossi and I am from Israel, age 40 married with 3 kids,my love to suzuki thumpers started 20 years ago and since then the DR650 is my favorite bike. I read a lot on ADV but always stays in the background.....
So, the story of this rebuid begun last year while buying a faulty motor, year 99 from a friend who decided not to fix it, so I bought it and started an overhall. The engine was disassembled in order to find the root cause of the noise been generated while changing gear.
I started by taking off the clutch cover and the problem immidiatly appear, the primary gear axe was moving, and the bearing had significant play. I then understand that I need to open the case in order to replace this particular bearing......
So the goal of the project are:
1- rebuild the engine: replacing all bearings, all oil retainers, gaskets, rings, piston etc'
2- Then find a bike with a broken engine, pay cheap and install this one.
3- Rebuild the whole bike from scratch so at least it will be like a new one.
3- Build a bike which will be a real adventure bike, good both for off and on road.
4- comfortable.
5- Able to ride long distance with larger fuel tank.
6- and then if I don't have budget problems , start upgrading each module like: shock absorber, brakes and accessories.
Realy don't know how this bike will look at the end .......with these kind of projects you know how you start but don't know how it ends, so I will go slowly slowly step by step.....
So I start with the head removal, camshaft etc
and the cylinder. As you can see the walls were shiny. Before assembling back, I tried the scratching stuff with scotch-bright and WD40 as recommended in many websites for Nikasil material- what I can tell you guys this is BS- Nikasil is very hard no scotchbright can do anything to it unless I missed something here.....
while inspecting the clutch cover I noticed that a piece of metal is missing arround the clutch rod (in the middle of the picture)- I assume this was the root cause for the demaged bearing of the primary gear axe. Probably the rod had some play and clutch release was not smooth as should be.
To make the long story short the case was openned and finally reached the faulty bearing and removed it....
On the way a new set of engine bearings was bought and the old ones got replaced.
so as all the oil retainers...
Then after the case was closed I install a new JE piston+rings, this is a high comp one 10.5:1 instead of 9.5:1.
Here I want some feedbacks from you guys regarding this uograde. How does the engine feels ? how is the riding with the new piston?
keep moving upward...now it was the engine head turn to be rebuilded. all valves spings and stuff were dismantled and kept in separate boxes.
Head was cleaned thoroughly and start lapping the valves seats.
Nice to meet you all.....welcome to my shop.
Once the head was ready I put the valves and springs back to their original places.....now it was the valves cover assembly to be taken apart: all shafts were inspected and measured with a micrometer to make sure they are in spec limits, then moly pasted them and lube.
Don't get me wrong....This pix above is the "before" cleaning....
jossef screwed with this post 07-03-2009 at 01:05 AM Reason: type error
jossef is offline   Reply With Quote
Old 06-30-2009, 10:17 AM   #2
LukasM
Oddometer: 5,427
Jossef,
I got a sneak peak at your project from Mezo and thought it was great. Looking forward to seeing more of it!
Lukas
Old 06-30-2009, 11:13 AM   #3
jossef OP
Oddometer: 37
Originally Posted by LukasM
Jossef,
Lukas
Hi Lukas
thanks, I will try to write a little each time to keep you updated, since I have a lot of pictures/photos
You can call me Yossi.
Old 06-30-2009, 11:26 AM   #4
clinton1396
Oddometer: 10
I just had to crack my crankcase open on my sp200 same as dr just to replace this drive shaft part b/c a bolt snapped off into it that made me mad lol. but it was a great learning experience good luck with the project
clinton1396 is offline   Reply With Quote
Old 07-01-2009, 06:04 AM   #5
NOSIGN
NOSIGN's Avatar
Oddometer: 94
Hi Yossi,
looking with interest...
NOSIGN
DR650SE ('97) current project
CBR954 ('03) daily ride
CBR900 ('96) the 'ol days
CR250 ('03), 125 ('89), 80 ('85) the 'ol days
KX80 ('92) the 'ol days
NOSIGN is offline   Reply With Quote
Old 07-01-2009, 10:31 AM   #6
nave
Nave
nave's Avatar
Oddometer: 354
Hey Yoosi,
Come on, don't be lazy and load more pix...
Nave
nave is offline   Reply With Quote
Old 07-01-2009, 12:08 PM   #7
jossef OP
Oddometer: 37
have plenty of photos....have hard time to upload them since they are high quality and this takes time....
I will do my best.
Yoss
Originally Posted by nave
Hey Yoosi,
Nave
Old 07-02-2009, 04:28 AM   #8
Mezo
Oddometer: 2,129
Hi Yoss, superb mate, thanks for taking the time to post & write up the build, you will inspire others to "have a go"
Yossi had read my build thread & Lukas`s, he had mailed me some pics of his bike i forwarded them to all the other DR builders on the forum, and all agreed Yossi has talent & they told me to "convince him" to post his build, and voila
macdesign oops, there i go it just blurted out, macdesign is also building a very trick DR650, im trying to "convince him" also to post a thread see married men with children can find time to play with there toys.
Ive put a link to your build on my own site, i must get round to that other project of mine The DR650 Builders WALL-O-FAME
Cant wait for the next installment Yoss, there will be plenty of popcorn munchers on this thread
Me for one,
Mezo.
Mezo is offline   Reply With Quote
Old 07-02-2009, 01:25 PM   #9
jossef OP
Oddometer: 37
how do you editmthe thread title- made a typo error
shall be "rebuild" instead of "rebuid" ?
Old 07-02-2009, 03:32 PM   #10
Mezo
Oddometer: 2,129
Pres "edit" on your post & then press "advance edit" at the bottom
We knew what you meant mate.
Mezo.
Old 07-02-2009, 05:18 PM   #11
kuyaoli
kuyaoli's Avatar
Oddometer: 320
ask one of the mods to change it for you the title can not be edited by yourself.
By the way, great start, I am looking forward to see more of your rebuild.
2012 Kawasaki KLX250S
kuyaoli is offline   Reply With Quote
Old 07-02-2009, 09:47 PM   #12
DisTech
DisTech's Avatar
Oddometer: 616
I've seen the preview's (thanks Mezo) and I'm really glad your decided to do a build thread. Good luck and keep it coming!
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech screwed with this post 07-02-2009 at 09:49 PM Reason: :lurl
DisTech is offline   Reply With Quote
Old 07-02-2009, 10:11 PM   #13
jossef OP
Oddometer: 37
Thanks Mark
What happens with the thread at the end- does someone moves it to the main "DR650 Thread"? or can we move it now? so it can be tracked...you get lost after with all the information.....
Yossi
Mezo.
Old 07-03-2009, 01:11 AM   #14
jossef OP
Oddometer: 37
Need some info on Nikasil scotch-bright and JE HC piston
"Before assembling back, I tried the scratching stuff with scotch-bright and WD40 as recommended in many websites for Nikasil material- what I can tell you guys this is BS- Nikasil is very hard no scotchbright can do anything to it unless I am missing something here.....
JE HC piston how does it impact power ? any feedbacks on this upgrade?
Yossi
Old 07-03-2009, 01:26 AM   #15
DRjoe
DRjoe's Avatar
Oddometer: 5,318
Good to see you started a report on your build.Like mezo said it will inspire others.
It's looking good so far.
Joe
Times are GMT -7.   It's 07:49 PM.
