Old 07-06-2009, 02:26 PM   #31
DRjoe
DRjoe's Avatar
Oddometer: 5,142
She looks great Yossi.
How did you galvanize the frame? I hope it wasn't hot dipped.
DRjoe is online now   Reply With Quote
Old 07-06-2009, 03:26 PM   #32
Mezo
Oddometer: 2,129
Pauline Hanson "Please Explain" ?
Mezo.
Mezo is offline   Reply With Quote
Old 07-06-2009, 04:08 PM   #33
DRjoe
DRjoe's Avatar
Oddometer: 5,142
I worked for a marine and civil construction company and we used to get a lot of stuff hot dipped and if it was lightly built it would warp from the heat.
I would think a motorcycle frame would warp if exposed to that kind of heat a as well but I'm normally wrong about these things.
Yossi how did you stop the head stem bearing seating surfaces from getting coated by the zinc coating.
Old 07-06-2009, 09:02 PM   #34
jossef OP
Oddometer: 37
I gave the frame to a shop which does metal coating like anodization, passivation, crome etc'. I did the cold galvanization- coating thickness of 30 microns merged in electrolite. The bearing surfaces can be masked not problem. But remember if you galvanized you need to use the right chemistry for the painting, otherwise its great and gives good rust protection to the frame.
Yossi
jossef screwed with this post 07-07-2009 at 01:05 AM
jossef is offline   Reply With Quote
Old 07-06-2009, 10:57 PM   #35
dylandr
dylandr's Avatar
Oddometer: 204
Thumb
Jossef... That frame looks KICKASS! Great thread! Keep it up!
dylandr is offline   Reply With Quote
Old 07-06-2009, 11:36 PM   #36
DRjoe
DRjoe's Avatar
Oddometer: 5,142
Originally Posted by jossef
I gave the frame to a shop which does metal coating like anodization, passivation, crome etc'. I am not sure if they did the hot or the cold galvanization I can check this with them. The bearing surfaces can be masked not problem. But remember if you galvanized you need to use the right chemistry for the painting, otherwise it great and gives good rust protection to the frame.
Yossi
Its a good idea to galvanize the frame if i was still in Scotland i would definitely galvanize the frame.
You would need to use a decent etch primer if you where going to paint over the zinc.
I wonder what a dr would look like with a chrome frame and engine.
Old 07-07-2009, 12:57 AM   #37
jossef OP
Oddometer: 37
Hi Joe
The frame was cold galvanized ( merged in electrolite about 30 microns coating thickness)
Yoss
Old 07-07-2009, 01:08 AM   #38
DRjoe
DRjoe's Avatar
Oddometer: 5,142
cheers Yossi i think i might look into doing that as well.
Old 07-07-2009, 03:21 AM   #39
Mezo
Oddometer: 2,129
HI Yossi,
Two questions on galvanized, did you plug the breather holes in the frame or did you let it inside ? and can you still read your chasis/frame number ?
Regards,
Mezo.
Old 07-07-2009, 03:56 AM   #40
jossef OP
Oddometer: 37
1- No I didn't plug anything when zinced. Zinc thickness is between 10 -30 microns depends on how much you want.
2- You need to plug threads and bearing surfaces only during powder coating (50-80 microns)
3-you can read the number, what made a problem is the powder coat
Yossi
Originally Posted by Mezo
HI Yossi,
Regards,
Mezo.
Old 07-07-2009, 03:59 AM   #41
jossef OP
Oddometer: 37
Just remember when you do it like this you go on regular painting (spraying) with proper etch primer and not powder coat.
Yoss
Old 07-08-2009, 04:41 AM   #42
Mezo
Oddometer: 2,129
I had my mate come over tonight, we sat & had a couple of drinks looking at the frame sat on the table, i talked about this particular thread, id mentioned Yossi & the problems with paint after dipping etc.
My mate looked at me & said "Chrome" has any one done that ? has any one chromed the DR frame yet ? what an idea though.
My mind is set on white, but now ive read Yossi`s thread & dipping, there are so many types of metal treatment out there, its just up to your own imagination.
Haa, i can see the gold plated DR650 pimp bike, "bling bling"
Im kidding on the gold plate.
Mezo.
Old 07-08-2009, 05:02 AM   #43
LukasM
Oddometer: 5,425
I think chroming would be pretty difficult and expensive.
Doing it in a chrome like powder coat however would not be a problem and only increase the cost a bit. It generally needs a base coat and clear coat on top.
EastwoodCo and Caswell both sell it if your local powdercoated can't get it.
Old 07-08-2009, 06:44 AM   #44
Mezo
Oddometer: 2,129
Ah well Lukas thats the thing, the friend that said that also said "I have a mate of mine just 2k down the road from where were sitting who chromes motorcycle frames"
I said "Aww yeah"
So expense aside, my mate knows a bloke just a mile down the road that chromes frames (id imagine they must be Harley boys) and if Tony pie says "do a proper job its me mates bike" id get a "proper job" and getting a proper job is worth its weight.
Sorry Yossi, your the first to dip ones frame so its a bit of a talk subject.
THREAD HIJACK
Mezo.
Oh yeah forgot,,,,
Old 07-08-2009, 07:38 AM   #45
selecus
selecus's Avatar
Oddometer: 80
Very cool, subscribed!
selecus is offline   Reply With Quote
Times are GMT -7.   It's 07:59 AM.
