Old 08-03-2009, 12:00 AM   #136
Shmerel
Oddometer: 11,152
nice paint job . brilliant outcome.
i'm starting to be the guy on the outside of the dunny
noooooo!!!!!
Shmerel is offline   Reply With Quote
Old 08-03-2009, 02:17 AM   #137
wato
wato's Avatar
Oddometer: 237
been lurking through this thread. Nice work with the chair.
I need to start looking at the chair for the 1100gs.
wato is offline   Reply With Quote
Old 08-03-2009, 02:20 AM   #138
wato
wato's Avatar
Oddometer: 237
Out of curiousity what size and thickness is the ural frame.
Old 08-03-2009, 02:43 AM   #139
Clancy
Clancy's Avatar
Oddometer: 5,940
FIIK Wato. I know the steel they make the body out of is a bit thicker than normal body panels.
I'll measure the frame in the morning and let you know.
And he sees the vision splendid of the sunlit plains extended,
And at night the wondrous glory of the everlasting stars.
Clancy is offline   Reply With Quote
Old 08-03-2009, 03:25 AM   #140
wato
wato's Avatar
Oddometer: 237
thanks Clancy. I have a velorex in the shed. It's a to light for the 1100, will probably stick it on the 80g/s when I get that project finished.
Old 08-03-2009, 03:47 AM   #141
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,053
Wow. I mean......wow....just wow.
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Old 08-03-2009, 05:38 AM   #142
Shmerel
Oddometer: 11,152
when you do your rig, you had better keep up to the standard, or else!
Old 08-03-2009, 04:11 PM   #143
TouringDave
Tri Moto Veritas
Oddometer: 7,053
Yes thank you Gad.
When do you start yours, hmmm?
K7 Strom with Chair
Old 08-03-2009, 06:26 PM   #144
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,718
Originally Posted by WhatMeWorry?
Is this tongue in cheek ?? If so, meh...
Absolutely!
Phyllis would understand. There is this certain thread, see...
rayb Crash Dummy (no testing involved)
Old 08-03-2009, 06:29 PM   #145
tripodtiger
I used to be SCRay
Oddometer: 4,718
Originally Posted by nevgriff64
but one stuck out more than the others.. With a quick chat to Phyllis ( ), his passion for sidecars for both building and riding was second to none and with an Aircraft mechanical background, I knew he was the one if he`d agree to taking it on...........
Must've been that mad glint in his eye and the crazed laughter.
Sorry if I'm going back too far. I'm catching up.
Old 08-03-2009, 08:07 PM   #146
Russ
Russ's Avatar
Oddometer: 16,805
Looking even better than I thought it would great effort.
Its going to be bloody brilliant when its complete.
Russ is offline   Reply With Quote
Old 08-03-2009, 11:07 PM   #147
Clancy
Clancy's Avatar
Oddometer: 5,940
Firstly, for Wato, The main frame of the sidecar is 50mm dia. x 2.5mm thick.
The suspension support tube is 24mm dia and I would think about the same wall thickness, and the swing arm is 45mm dia.
The assembly started today Actually there were a couple of false starts because the owner, who shall from now on be known as Nev(Can'trememberIdidn'tdothatbit)Griff, wasn't sure how it all went back together. But eventually he learned how a ratchet works and it's two thirds assembled. Pics shortly. Looks good.
Old 08-04-2009, 12:07 AM   #148
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 14,366
Between your Alzeimers and my bad memory, its amazing we got anything done..
nevgriff64 is offline   Reply With Quote
Old 08-04-2009, 12:15 AM   #149
Clancy
Clancy's Avatar
Oddometer: 5,940
The day started with putting the mudguard on, then the lights, once the auto electrician had sorted the wirse out.
The grin didn't disappear from his face all day
Once the guard was done, the body was dropped on and fixed permanently.
Then the hinges were fitted and the rear rack was bolted on. Nev put a felt sealing strip under the hinges, as the original design had nothing between the hinges and the body.
He couldn't help himself. Still grinning, he had to drive it back into the garage
The front rack, half mounted, and the seats in, "Just to see what it looks like"
That was about it for the day. The rest will be fitted tomorrow and hopefully, the wiring will be hooked up.
Old 08-04-2009, 02:39 AM   #150
Russ
Russ's Avatar
Oddometer: 16,805
Wow it just keeps getting better
You guys should turn this into a business.
I would buy one, if i could afford it.
Times are GMT -7.   It's 05:33 AM.
