Old 09-09-2012, 09:05 AM   #1696
frogy
frogy's Avatar
Oddometer: 873
K100rs
Very clean bike.The smoking is usually caused by oil bypassing the rings after the engine has been turned off and you lean it on its sidestand.Before you lean it over to the left onto its sidestand,lean it to the right for a moment after turning it off.The oil will drain into the pan (at least most of it will).The miles on your RS is nothing for the piston rings if she's been taken care of...great find.
frogy is offline   Reply With Quote
Old 09-09-2012, 11:44 AM   #1697
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 4,207
YES,that bike ( Trey ) was bought from Pat.It use to be blue but my wife wanted purple and ofcourse Pat had a set of just about every color body work Suzuki put out so purple it became !!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 09-09-2012, 05:29 PM   #1698
bmwloco
bmwloco's Avatar
Oddometer: 1,511
Originally Posted by England-Kev View Post
Here you go
Ah, many thanks Kev. Speedo has been reset to 000000... that way I know exactly when to service it again. I have new pipes, just need to pop on a header set up and it'll be about 94% quieter. As it is, though, it makes a nice throaty roar.
Great K100RS too. I used to sell those when they were new! It was an interesting time. Airheads still available, K100 and K75 models on the floor, and the new R1100RS just coming out.
They were the Legendary Motorcycles of Germany then. The ones that remain still are. Everything else from BMW is suspect.
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Old 09-10-2012, 10:33 AM   #1699
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,301
1974 mx175 - $600
MX360 front end $150
skyway 6th gear pipe $125
redwing shocks $200
footpegs, bark busters, real tires,seals, etc. $150.00
tank $75.00
waiting on a seat cover. gotta build up foam in front of seat to stop the ballbuster
now ready to race
current bikes
stainlesscycle screwed with this post 09-10-2012 at 03:06 PM
stainlesscycle is offline   Reply With Quote
Old 09-10-2012, 11:48 AM   #1700
Motoduc1
backtrackvideo.com
Motoduc1's Avatar
Oddometer: 988
Originally Posted by stainlesscycle View Post
1974 mx175 - $600
redwing shocks $200
tank $75.00
now ready to race
I can hear that bike from here! Great find! Nice original tank, too!
www.backtrackvideo.com
Motoduc1 is offline   Reply With Quote
Old 09-11-2012, 08:21 AM   #1701
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Location: Da frozen tundra eh? 1.5 mile west of Lambeau
Oddometer: 799
91 k100-rs
At todays exchange rate I paid $1200
At that price you got a beautiful classic BMW. Those are known to easily go WELL over 200,000 miles with no engine work. Two members in my BMW club exceeded 225,000 on their K-bikes.
The smoking, after the bike is parked on the sidestand, is a very common characteristic of the K-bikes. But it is not necessarily caused by crankcase oil seeping by worn rings, because the oil sump level is actually below the pistons. More often it is caused by oil mist that had condensed in the air box (the crankcase breather is routed into the airbox). When the bike is parked on the sidestand that oil can dribble down into whichever throttle body is the lowest, and at startup the smoke is caused by that very minimal oil being burned in the combustion chamber.
To put your mind at ease, have a compression test done. If it comes back in spec, then you only have the typical K-bike Startup smoke and nothing to worry about it. Ride it, enjoy it!
When life throws you a curve,.....lean into it!
42+ year rider, 22+ year MSF Coach, Street, Dirt, Ice, ride em all!
Andyvh1959 is offline   Reply With Quote
Old 09-12-2012, 04:24 PM   #1702
FlySniper
Bleh...
FlySniper's Avatar
Oddometer: 1,664
$550 before new tires, chain, sprockets, tune up, etc... Got it home and cleaned the carbs, added gas and a battery... went for a ride! The cases came with my DR650, the mounts I made. Been riding the thing for a few months and have about 6000 miles of my own on it. (17,000 miles now.)
Too bad my first post here is with a crappy cell phone pic... but I just happened to remember I wanted to put this up.
A feeling of having made the same mistake before: Deja Foobar.
"Think about how stupid the average person is. Now, realise that half of them are dumber than that." - George Carlin
FlySniper is offline   Reply With Quote
Old 09-12-2012, 06:05 PM   #1703
senatorperkins
Oddometer: 34
1970 CB350 bought for $200.. missing carbs, rear brake lever, battery, clutch/brake levers, center stand, key switch, drive chain, rear taillight, air filters, throttle/tach cable, mirrors, horn, header had a missing flange, cracked speedometer..
And it had these dumb glass pack mufflers. I new it was never going to be a pretty bike, but I got it all tuned up and had a lot of fun blasting around town on it. About $250-300 worth of parts into it, then I got tired of riding around on the stock tires and installed some new ones before selling it.
1973 Yamaha MX360 given to me for free by a friend of my dad's who had ice raced it as a younger lad. Cleaned the carb, converted for pre-mix, rode it around my parking lot a couple of times and seized it due to a big exhaust leak and/or gunk in the bottom/top end.
Had a friend weld the crack in the pipe, flushed the bottom end, rebuilt the top end with a fresh piston + rings, hone job, small end bearing, new gaskets all around. Rear shocks stuck, no rebound in front fork.. useless tires, laid it down on the grass once and decided it wasn't for me. Sold it for $400 to an old dirt rider who liked the old thumpers.
senatorperkins is offline   Reply With Quote
Old 09-13-2012, 07:19 AM   #1704
stainlesscycle
Oddometer: 2,301
doh! if you find another one you'd like to sell for $400, i'd be all over it.....
current bikes
Old 09-13-2012, 11:16 AM   #1705
Dorzok
Dorzok's Avatar
Oddometer: 2,011
I've a '76 for a couple hunert more if u interested.
well a YZ 250 annyway.
Dorzok screwed with this post 09-13-2012 at 02:12 PM
Dorzok is offline   Reply With Quote
Old 09-13-2012, 12:29 PM   #1706
blaine.hale
blaine.hale's Avatar
Oddometer: 3,267
1973 BMW r75 /5 Toaster LWB bought for $1000 even. Has just over 19k confirmed miles on it. There's a build thread on over in the Airhead sub forum.
1974 BMW R90 /6 | 1968 Bultaco Matador MK3 | 1973 BMW R75 /5 Toaster LWB | 1966 Ducati 250 Monza | 1976 Ducati 860 GT | 1977 Moto Guzzi LeMans 850
blaine.hale is offline   Reply With Quote
Old 09-13-2012, 01:26 PM   #1707
England-Kev
Oddometer: 3,749
Nice one Blaine
England-Kev is offline   Reply With Quote
Old 09-13-2012, 02:14 PM   #1708
Dorzok
Dorzok's Avatar
Oddometer: 2,011
needs to be link in this thread.
Old 09-13-2012, 09:46 PM   #1709
rthuey
twist your wrist!!!
rthuey's Avatar
Oddometer: 2,831
prolly not the spot for it. but what makes it a toaster? been mentioned a couple times recently here.
We're gonna go ridin!!!
rthuey is offline   Reply With Quote
Old 09-14-2012, 10:13 AM   #1710
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
The small gas tank looks like a toaster oven. Usually called toaster tanks.
Current: 93 R100GS, 03 XR650R
Prior: 73 CB350, 77 R100/7, 83 R100RT, 04 XR650L
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Times are GMT -7.   It's 01:34 AM.
