Old 11-02-2011, 09:45 PM   #151
SocalRider
Oddometer: 4
So for this first time trials rider I have located the following bikes. I am still waiting on some of the photos including the Montesa. Just looking for input. I realize this is the Montesa thread but most of you have probably owned one or two machines over the years and have some input.
2002 Beta Rev3 250
2004 Montesa 315R
2007 Scorpa TY250
And I have located 2 Sherco 2.9's 2005 and 2006
My price point is less than $3500 and that includes shipping as most of these are not close by.
Any feedback? From what I hear they are all capable machines. Looking for ease of learning and dependability.
SocalRider is offline   Reply With Quote
Old 11-03-2011, 07:17 AM   #152
ridenm
not waiting anymore
ridenm's Avatar
Oddometer: 1,653
2002 Beta Rev3 250
2004 Montesa 315R
2007 Scorpa TY250
Beta insists on using case materials that contribute to water pump failure. Ask.
ridenm is offline   Reply With Quote
Old 11-03-2011, 07:59 AM   #153
LowPSI
Oddometer: 191
The 2004 Montesa was the best Cota 315R made. It was the final year for the 2 stroke. It had updated "Factory" porting and the motor is sweet. On all these bikes look closley at the condition of the skid plate and linkage.
If the Monty had normal usage then all you need to do is a good service and you're ready to go. Change engine oils, ask previous owner what he used in the clutch, change fork oil, lube all pivot points, linkage, steering head, wheel, bearings the swing arm is very well sealed and rarely needs attention, maybe repack the silencer and you've got a good bike for years to come.
LowPSI is offline   Reply With Quote
Old 11-04-2011, 10:43 AM   #154
BikePilot
BikePilot's Avatar
Oddometer: 10,901
I would expect that of those bikes the Montesa will be the most trouble free. The Sherco is a bit lighter and more zippy feeling. Also its easier to get Sherco parts. The Montesa feels a little more stable and like has a lot more flywheel than the Sherco. They are all way more capable than me and probably most riders so I can't tell you which is best if you are a top rider. I've just done a couple of competitions in the noob class. I have ridden the 2.9, my 'tesa and a beta (but don't remember what year the beta was). The beta felt a lot like my Montesa - heavy-ish flywheel. It had maybe a bit more grunt than my montesa, but the 'tesa has more than I know what to do with. I like the feel of the Montesa's clutch better than the Sherco or Beta, but that could have as much to do with setup as design (the montesa's clutch was horrible when I got it, but awesome after changing to the elf oil).
The bearings for the dog bone in the linkage on the Montesa are prone to going dry and wearing/breaking. It's quick and easy to clean and grease it. A complete set of new bearings/seals/bushings is $80 from All Balls IIRC, so not a costly repair if they are shot.
I'd also strongly suggest changing shock oil in whatever you get. Its almost always overlooked and gets hammered. I had mine changed and it made a huge improvement in suspension action. Should be less than $100 at your local moto dealer, at lest for the 'tesa. Its a simple showa shock, my honda shop had no troubles sorting it.
My Montesa really, really likes the factory spec elf oil in the gearbox. A Montesa parts dealer/guru at a D-6 event confirmed that they are all pretty picky about this. He also noted that the factory spec oil works for longer than most anything else so the cost isn't that bad. He changes it twice a season.
I think that overall the Montesa is probably your best bet. It has the best suspension (imo), is very stable and easy to ride. About the only area where I found the Sherco easier was that with its lighter flywheel the motor shut down more quickly. For example, on the Montesa if I go up a big ledge, or really anything that requires a bit of throttle and rpm, to slow down I have to pull in the clutch because with all the flywheel inertia the motor keeps on pulling for a while. On the Sherco just chopping the throttle is often enough to get it slowed down. Of course all that flywheel weight makes the motor easier to manage when you are first applying the power and, I found, makes it easier to float the front end around in rocky stuff. Again this is a trials noob's take, better riders might have other views.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot screwed with this post 11-04-2011 at 10:52 AM
BikePilot is offline   Reply With Quote
Old 11-04-2011, 11:04 AM   #155
SocalRider
Oddometer: 4
Bike Pilot
Thanks for the comprehensive response. Great information. I agree that all of the bikes are capable and have there strong points. Looks like the Montesa is going to be my new bike. I made the deal yesterday and should have it in about a week. Most of the opinions I have received parallel what you have said. Being a total trials beginner I don't see that I can go wrong with this bike. Reliability is key for me, I have enough bikes, quads and a Rhino so I don't need to be spending alot of time fixing one more bike. The Honda brand was a big selling point as was the showa suspension, but most of all the input from other owners and a couple of trials bike shops and club members gave me the overall comfort to buy this bike. Thanks again to all that responded, I am sure I will have many more questions as I go forward.
Old 11-04-2011, 02:22 PM   #156
BikePilot
BikePilot's Avatar
Oddometer: 10,901
Congrats, you'll love it!
For the basics you'll wanna do when you bring it home in addition to checking bearings, etc., mentioned above this should get you pretty well sorted.
1. Put in fresh Elf oil as spec'd in the manual (HTX740 I think), clean and oil the air filter - like any two stroke filter maintenance is key.
2. Check that it has a resistor plug, it'll do all sorts of really weird things with a non-resistor plug.
3. Fresh fuel mixed at about 70-80:1 with some quality 2-stroke motorcycle premix (I use the honda syn stuff, but its not critical what brand). Note it seems to hold about a liter and is good for ~ 8 miles before you run out.
4. ~4-5psi in the back tire, 5-6psi in the front.
Have fun and remember to pull in the clutch when you need to slow down - figuring out how to slow down quickly took me awhile.
Old 11-20-2011, 08:51 PM   #157
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 5,486
So, the carb on the Montessa... the fuel screw on the front left of the carb. Out is richer, correct?
I have a manual on the way to me, but want to do a little tuning for the colder weather.
"There isn't any secret," he said. "It's all very obvious."
UngaWunga is offline   Reply With Quote
Old 11-21-2011, 04:57 AM   #158
Spacemonkeyr
Spacemonkeyr's Avatar
Oddometer: 7
On my '99 315, the spot on the front left is empty. It has a spot in the casting, but it is not drilled. The larger center screw is the idle, and the rear left is the mixture screw. Think of it in terms of an air screw, the more you turn it out, the leaner the mixture. My bike is all stock, and mine is 1 turn out.
Spacemonkeyr is offline   Reply With Quote
Old 11-21-2011, 06:24 AM   #159
SocalRider
Oddometer: 4
The manual for the 2004 shows the air screw in that position. And reads "turning the air screw clockwise will lean the mixture, counter clockwise will enrichen the mixture."
Old 11-21-2011, 08:00 AM   #160
BikePilot
BikePilot's Avatar
Oddometer: 10,901
The manual on my '01 is wrong, the older bikes had a different carb than the newer ones, they never updated the picture in the manual as far as I'm aware. Turning the air screw out makes it leaner, turning the fuel screw out makes it richer. Fuel screws are in front (engine side) of the slide, air screws behind the slide (airbox side) and idle screws are right on the slide.
Old 11-21-2011, 10:20 AM   #161
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 5,486
Thanks. That what I thought, screw towards the carb mouth adjusts air, screw towards engine adjusts fuel. Just double checking.
Old 11-24-2011, 06:14 AM   #162
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 5,486
While I'm waiting for my manual to arrive... how many turns out is stock for the fuel screw? 2001 model. Thanks.
Edit:
Found this
UngaWunga screwed with this post 11-24-2011 at 06:19 AM
Old 12-12-2011, 06:18 PM   #163
thebleakness
thebleakness's Avatar
Oddometer: 99
Here's my '04. Paid $1k for it.
It does however need a new fan and a new one costs around $150, being a college student, I have some budget constraints. Has anyone found a replacement motor for it? I was thinking possibly one from a computer fan might work. I was going to give it a try when I have time.
thebleakness is offline   Reply With Quote
Old 12-12-2011, 06:25 PM   #164
NMTrailboss
Team Dead End
NMTrailboss's Avatar
Oddometer: 4,451
Sweet bike for that money! Nice score!!
Give Dennis a call at Overland Trail Cycle Shop 412-780-3693 to see what he can do for you on a fan motor. http://www.overlandtrail.biz/
NMTrailboss is offline   Reply With Quote
Old 12-14-2011, 02:52 PM   #165
BikePilot
BikePilot's Avatar
Oddometer: 10,901
That is a heck of a score
If you have't, give the fan power directly to confirm that its not something else (switch, wiring, whatever). Its a pretty robust fan motor and it wouldn't surprise me if the issue were a wiring connection or something simple.
If it is the fan itself I'd take it apart and see what the deal is. electric motors are often not that hard to fix. I've never taking the 'tessa fan motor apart, but mine's never gone bad either
I think it'd be worth using the correct parts rather than rigging something that'll inevitably not look or fit quite right. Considering you got the bike for a third of its value $150 isn't that bad. heck that's one text book
Times are GMT -7.   It's 02:46 AM.
