Old 07-20-2009, 12:58 PM   #1
Jnxdrcg OP
notanoob
Jnxdrcg's Avatar
Oddometer: 15
15 minute idle clarification....
I have looked everywhere for clarification on this point and cant seem to find an answer. Do you shut the bike off or just start riding it at the 15.5 minute mark?
Jnxdrcg is offline   Reply With Quote
Old 07-20-2009, 01:02 PM   #2
Crisis management
Latte riders FTW!
Crisis management's Avatar
Oddometer: 1,477
My understanding is that you turn the bike off then restart and go play..if you don't shut it off between 15 minutes and 15minutes 40 seconds the ECU doesn't reset itself, it needs the actual shut off action to cause the reset.
This gem of internet wisdom is based upon researching these "facts" here, rather than any in depth knowledge of how the ECU works.
Orange...cause it makes me look like I know what I'm doing!
Crisis management is offline   Reply With Quote
Old 07-20-2009, 01:15 PM   #3
alphajory
alphajory's Avatar
Oddometer: 589
you have to shut the bike off at 15 min 30 seconds of the reset. If i remember correctly it best done in cooler temps with the motor cold. Once done your good to go.
There are a lot of different treads on why and how it works but basically it has to do with the way the closed loop system that is on these bikes works.
alphajory is offline   Reply With Quote
Old 07-20-2009, 03:06 PM   #4
dezracer
dezracer's Avatar
Oddometer: 642
With all due respect this appears to be 'a guess". Not only the 15minute idle but whether or not to cycle the key. I have done the 15 minute idle, but proceeded to ride without cycling the key and yes it always "seems" to run smoother off idle.
I would feel better if the process was written somewhere, anywhere. With auto ECUs the procedure for re-setting always includes unhooking the battery for 10 minutes or so and starting with a clean slate so to speak. This makes sense to me so thats what I do, but again all this 15 minute idle thing is not written anywhere to my knowledge. If Im wrong then I will stand corrected.
2007 990 Adventure
Suspension by Super Plush
Rekluse Pro Auto Clutch
WINGS N.O.S Exhaust
Euro Headlight with PIAA bulbs
KTM Hard Parts Radiator Cover
CJ Racer Clear Spoke Clutch Cover
Hilslamer Long Pegs
GPR Stabilizer
DH Racing tripleclamps
'300' Throttle Cam
16t CS Sprocket
Mefo "Super Explorers"
Ram Mount Garmin 76c
PABIKER sidestand relocaton kit.
2007 KTM 300XC (long live lightweight 2-strokes)
Las Vegas, NV and the Great Mojave Desert
dezracer is offline   Reply With Quote
Old 07-20-2009, 03:10 PM   #5
Venteuri
I don't give a shit
Venteuri's Avatar
Oddometer: 15,395
From the bible:
The 15 minute Idle Trick:
Superduke: It seems there's a little confusion about the so called “15 min idle trick”
If the dealer changed the mapping (maybe for a different exhaust ) he had also also to do the 15 min idle run. But we don’t want to change the mapping, we only want the EFI to “re calibrate. Because of the self learning EFI the “actual” parameters of the engine are measured and stored into the EFI as new basic information, if you do a 15 minute idle run.There is a good information about this in a document from KTM Sommer.
I will try to translate the most important things you have to do.
Preparation:
Enough gas in the tank !
Do it outside , not in a closed garage and somewhere in the shadow.
You need also a stop watch.
What to do:
The bike must be in a vertical position – so don’t use the side stand for the procedure.
The engine must be cold.
Start the engine and let it idle for 15 minutes.
You are not allowed to use any functions of the bike in this time.
The time must not be less then 15 minutes and not more then 16 minutes.
If the engine stops running during this time, just restart it and let it run for the rest of the time.
BMW R1200GSA 2014
Member #68,893
Above all stop pandering to posts from morons like Venteuri who can't even spell Venturi properly.
Venteuri is offline   Reply With Quote
Old 07-20-2009, 03:22 PM   #6
Venteuri
I don't give a shit
Venteuri's Avatar
Oddometer: 15,395
Originally Posted by dezracer
With all due respect this appears to be 'a guess"....
Correct.
And the repair manual, says
BMW R1200GSA 2014
Member #68,893
Old 07-20-2009, 03:29 PM   #7
roundtripping
Adventourist
roundtripping's Avatar
Oddometer: 1,702
Originally Posted by Venturi
Correct.
So it seems like someone read something about 15 mins idling in the repair manual, took that final step out of context and now people think a full reset can be done by just idling for 15 mins?
12 F658GS
13 Honda CRF250L
My SPOT Tracker
roundtripping is offline   Reply With Quote
Old 07-20-2009, 04:05 PM   #8
tobys
OCD Hobbiest
tobys's Avatar
Oddometer: 321
Wow
"not less than 15 minutes and not more than 16"...
Sounds pretty hard to believe, but I can't access the link from KTM.
It's odd that the computer (or whatever it is) would take all the readings, and be ready to re-map, and then say "oops, we hit 16 minutes, nevermind...".
anyway, no harm in trying, I'll go for it.
tobys is offline   Reply With Quote
Old 07-20-2009, 04:15 PM   #9
dezracer
dezracer's Avatar
Oddometer: 642
If you are not hooked up to the KTM diagnostic tool thats the way I read it as well. Turning the key off as stated is maybe a saftey precautuion when you are hooking and unhooking the diagnostic tool????
Could this 15 minute idle thing be Orange Crush folk lore? God forbid us inmates would be lored in by an internet rumor. We are way to smart for that. LOL! Some of the stuff wriiten above seems like BS to me. Like making certain the bike is on the centerstand. What possible diffrence would that make with an EFI motor. I do agree with letting the motor warm to 3 bars though. That makes sense so I do it. (Is that even stated in the owners manual?)
I admit that the few times I have performed the 15 min idle it "seemed" smoother off idle, but then again depending on conditions the off idle abruptness seems to creep back in. I will say that with the mods listed in my sig I have basically eliminated that gremlin though.
2007 990 Adventure
WINGS N.O.S Exhaust
Hilslamer Long Pegs
GPR Stabilizer
'300' Throttle Cam
16t CS Sprocket
dezracer screwed with this post 07-20-2009 at 04:29 PM
Old 07-20-2009, 04:40 PM   #10
Jnxdrcg OP
notanoob
Jnxdrcg's Avatar
Oddometer: 15
NOTE: the engine must run in idle for 15 minutes after each mapping
operation (Mapping initializing). Do not accelerate during this time,
observe the coolant temperature and abort if the engine threatens to
overheat.
I got this from the manual and yet despite all this information there is still no word on what you do after the 15 minutes are up....
Old 07-20-2009, 05:38 PM   #11
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
So... is there a hacked version of the KTM diagnostic tool out yet?
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 07-20-2009, 05:51 PM   #12
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
tuneboy software has a "reset adaptive settings" function
MookieBlaylock is offline   Reply With Quote
Old 07-20-2009, 07:37 PM   #13
Mad Kaw Disease
Dual Sport Diseased
Mad Kaw Disease's Avatar
Oddometer: 534
Could this 15 minute idle thing be Orange Crush folk lore? God forbid us inmates would be lored in by an internet rumor. We are way to smart for that. LOL! Some of the stuff wriiten above seems like BS to me...
You'd think that someone at KTM would care enough to read these major forums and debunk any glaring myths for us...but then that might shatter the mystique...
2007 KTM 990 Adventure
2014 BMW R1200RTW
"I was going faster than I ever went in my whole life and I fell off...." Little Fauss
Mad Kaw Disease is offline   Reply With Quote
Old 07-20-2009, 09:59 PM   #14
alphajory
alphajory's Avatar
Oddometer: 589
With the 15 minute idle it's done not to change the mapping, its done to re calibrate the ECU. the ECU system self learns if i remember in the closed loop period of operation, the 15 minuite idle alows the ECU recalerbrate the “actual” parameters of your engine.
Old 07-20-2009, 10:10 PM   #15
Pete156
I love to eat!
Pete156's Avatar
Oddometer: 1,440
So how long does this recalibration last? Sounds like some inmates are having to perform this 15 minute idle several times.
I won't buy a FI KTM until they get this kind of stuff sorted. How can the FI on the new Husabergs be so spot on and the 990s so not?
530 EXCR
950 ADV S
1000 CBR
200 KDX
___________________________________
humans are the stupidest people on earth
Pete156 is offline   Reply With Quote
Times are GMT -7.   It's 05:00 PM.
