Old 07-20-2009, 01:03 PM   #1
andrewgore OP
Team MGH
andrewgore's Avatar
Oddometer: 3,512
BMW G650X Issue Log (xCountry, xChallenge, xMoto)
In lieu of the various electrical gremlins a lot (all?) of the G650xCountry owners seem to be running into, I thought it would be a good idea to assemble a list here of just the facts of what is going on with everyones bikes. I want to keep this as factual as possible, without any sort of rif-raff. I feel it'd be a great resource for those who run into issues can reference this post and hopefully diagnose, fix, and be back on the trails ASAP!
Below I've got a simple format. If anyone feels there should be anything added to it to help make this log more descriptive\accurate, please let me know and I will change it quick snap.
Model: (xCountry, xMoto, xChallenge)
Year:
ABS:
Mileage at time of issue:
Date of occurrence:
Modifications (if any):
Description of Failure(s):
Resolution (if any):
Reference Thread:
Again, if there are other things that could be added that would help keep track, let me know.
Andrew
andrewgore screwed with this post 07-20-2009 at 01:23 PM
andrewgore is online now   Reply With Quote
Old 07-20-2009, 01:22 PM   #2
andrewgore OP
Team MGH
andrewgore's Avatar
Oddometer: 3,512
Model: xCountry
Year: 2009
ABS: No
Mileage at time of issue: approx. 3000mi
Date of occurrence: May 15th 2009
Modifications (if any): Heated grips, power for GPS, otherwise stock.
Description of Failure(s): After a minor crash, bike no longer held a charge.
Resolution (if any): Replaced battery with a Yuasa YTZ10S. Bike has run like a champ since, and holds a charge quite nicely.
Reference Thread: NA
Model: xCountry
Year: 2009
ABS: No
Mileage at time of issue: approx. 4000mi
Date of occurrence: June 16th 2009
Description of Failure(s): Engine lost all power from mid range to top end. Felt like a plug was stuffed in the exhaust.
Resolution (if any): Dealer found the Catalytic converter had broken inside exhaust. Exhaust was replaced with aftermarket unit.
Reference Thread: http://www.advrider.com/forums/showthread.php?t=479425
Andrew
Old 07-20-2009, 01:33 PM   #3
slide
A nation in despair
Oddometer: 21,122
model x-country
ABS
2007
mileage 400
no mods
bike would not start. battery would not accept a charge. took battery to dealer who tested & agreed battery is dead. replaced under warranty.
mileage 2,000
during heavy rain riding, LCD display blanked. remained blank during rain. slowly returned (faded in) when rain stopped (took 30 minutes to return)
mileage 8,000
all warning lights on or flickering all the time. includes oil warning light. took to dealer who saw the display. tested for error codes. no codes. lights went out during test (dealer said).
Mileage 11,000
Same as first. Bike will not start (no starter - not even a click) Headlight will not come on. LCD display shows some wonky messages. Remove battery & hike to auto repair place. Nice lady opened up for me & let me put battery on charger / tester. Battery will not hold charge.
This one is far away and by the time I gave up, it was night & Sunday. I will try to recover the bike Wednesday. This occurred after several days straight riding - maybe 800 miles in 3 days so it wasn't like the bike ever sat. I switched off to stretch my legs (take a leak) & bike is dead dead dead. First time same thing - switch off and it won't switch on again.
Can't help but note that over the same time I've owned this bike, our two Triumphs (Tiger 1050 & new Bonnie) have not had a glitch or any unscheduled maintenances
slide screwed with this post 07-20-2009 at 03:03 PM
slide is offline   Reply With Quote
Old 07-20-2009, 02:47 PM   #4
5Chord
No Short-Term Memory
5Chord's Avatar
Oddometer: 1,040
Model: xCountry
Year: 2009
ABS: Yes
Mileage at time of issue: approx. 1500-3500
Date of occurrence: Numerous, Feb-Jun
Modifications (if any): none
Description of Failure(s): Periodically the bike would not start. After a time (Usually 10 min) it would start up without any problems. It would resurface many times without pattern. The exception would be, that it would always start when cold. It would also flash A15 occasionally. It probably means low battery.
Resolution (if any): The shop said it was a defective battery and this is a known defect. They replaced it under warranty, however the problem did not get resolved. Later the same day I picked it up, the bike failed to start at a routine dry cleaning stop. It started again 10 min later.
Model: xCountry
Year: 2009
ABS:YES
Date of occurrence: June 26th 2009
Modifications (if any): Heated grips, PIAA lights, otherwise stock electrically.
Description of Failure(s): When at a routine ATM stop the bike would not start. It did not come back to life. It would also flash A15 occasionally. It probably means low battery.
Resolution (if any): Replaced battery with a Yuasa YTZ10S and charged the OEM BMW battery. While the OEM battery was run down quite a bit, it did accept a charge and I put it back in the bike after a few days as per instructions from BMWOM. My original plan was to get it back in the shop, but the way they dragged their feet the last time, I decided to just carry an extra battery and see if I could figure it out. Even with a full charge, you could hear that the OEM battery doesn't have the same cranking power. Also, the shop used non-standard hardware for hooking up the battery and used pieces of rubber as spacers under the nuts. I used the nuts that came with the Yuasa when I put the OEM back in.
Reference Thread: http://www.advrider.com/forums/showthread.php?t=480302
5Chord screwed with this post 07-21-2009 at 07:17 AM
5Chord is offline   Reply With Quote
Old 07-20-2009, 04:23 PM   #5
xcountry rider
What happened?
xcountry rider's Avatar
Oddometer: 116
Model: xCountry
Year: 2007
ABS: Yes
Mileage at time of issue: approx. 6000mi
Date of occurrence: August 30th 2007
Modifications (if any): Autocom system for bike to bike and ipod, otherwise stock.
Description of Failure(s): After bike turned off for one hour, no power to anything
Resolution (if any): Replaced main 15amp fuse, no problems since
Gone camping, leave message.
xcountry rider is offline   Reply With Quote
Old 07-20-2009, 05:01 PM   #6
onemoreokie
Oddometer: 28
Model: xCountry
Year: 2009
ABS: No
Mileage at time of issue: approx. 500 miles to current 3000 miles
Date of occurrence: November 2008-Present
Modifications (if any): No Canister (problem was there prior to removal),
LED tailight, various cosmetic changes.
Description of Failure(s): Bike will start and idle initially and then after a few miles die when clutch is engaged. Bike refuses to idle when restarted. Issue resolves itself after 5 min-2 hours of sitting. No fault codes thrown when taken to dealer. This has happened maybe once every 3 weeks since buying the bike. (My hand is never on throttle when engaging starter)
Resolution (if any): Waiting to be picked up to return to dealer when they decide on a game plan to trouble shoot.
onemoreokie is offline   Reply With Quote
Old 07-23-2009, 01:22 PM   #7
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,788
Model: xCountry
Year: 2009
ABS: yes
Mileage at time of issue: 3000
Date of occurrence: June 2009
Modifications: HID lights, HotGrips, GPS
Description of Failure(s): battery died after one hour riding with HID lights on. (ABS light came on, low fuel light came on, tripmeter reset to "0". Stopped bike, turned everything off, cycled the key, but battery was dead.) Bump started bike, rode for 30 min without HID's, all OK after that. Did not use HID's again after that.
Resolution:
  1. Tested alternator with RPM's at 3000, HID lights "on", HotGrips on "high", headlight on "bright", GPS powered "on" -- voltmeter on bike showed 13.5 volts. So the alternator was putting out enough juice for everything I got. But the battery still died, and after only one hour of riding with just the HID's and the GPS - HotGrips were off.
  2. Described problem to dealer - South Sound BMW. They said, "no BMW recall on this battery but it sounds like a bad battery - still covered under warranty - using HID's perfectly fine and should not cause a problem - bring it in and we'll test the battery and replace i if needed."
  3. Brought it in. They tested the battery and alternator and voltage regulator -- all OK. Bike running at 13.5 volts at 3000 rpm with accessories off. Voltage dropped to 12.5 volts at 3000 rpm with HID lights turned on. Verdict was that HID lights are too big a draw. The battery will drain out and go flat at 12.5 volts.
  4. I'm going to buy an Odyssey battery. It won't fix the problem, but it might take the abuse a little better.
WUMPA
Sidecardogs.com
DRONE screwed with this post 07-24-2009 at 02:52 PM
DRONE is offline   Reply With Quote
Old 07-24-2009, 04:15 PM   #8
tdv
Oddometer: 134
Pissed keeps blowing the main fuse
Model: xChallenge
Year: 2007
ABS: no
Mileage at time of issue: 8000-11000
Date of occurrence: latest - 07/24/09
Modifications (if any): leo vince exhaust, sm wheels, ohlins shock, raised bars, custom seat, heated grips, heated vest harness, gps harness
The bike would blow the main 15A fuse, repeatedly. This first happened before I installed my electrical stuff (grips, etc), so I don't think my wiring causes it (and everything was off when it happend last time). It also flickers the neutral light when on rough road or when it gets hot - not sure if it's related.
The latest fuse blowage incident was just today, it blew the main fuse again in the morning, after running warming up for about a minute. It was foggy and damp in SF, so perhaps it's a factor (it was dump under the seat when I removed it). I had two spares, which it promptly blew just as the ignition is turned on.
I let it sit there for a while, disconnected all my wiring (it is wired through their own fuses, so I just pulled them), and the bike started again (with the last remaining spare fuse), but then after a couple of minutes it blew again. Had to tow it to the dealer (still under warranty) where it remains as of today.
Definitely a short somewhere. It blows just as I turn the key, before I press the starter button. A couple of times it died on me (again, with the fuse) while I was riding (not a pleasant experience), sometimes it dies on warm up.
Would appreciate any ideas.
Resolution (if any): none yet
Reference Thread: none
If only I knew what I'm talking about!
tdv is offline   Reply With Quote
Old 07-24-2009, 04:25 PM   #9
slide
A nation in despair
Oddometer: 21,122
Mine's been at the dealer for two days now. Odd but so far no resolution. Implies that things are a bit more complex than just another dead battery. I will go there tomorrow to meet & confer.
Old 07-31-2009, 08:59 PM   #10
paul_g
Oddometer: 113
Neutral too easy to shift up into
Model: (xCountry)
Year: 2009
ABS: no
Mileage at time of issue: 1900
Date of occurrence: July 29, 2009
Description of Failure(s): upshifting from first, I've increasingly found myself in neutral even when giving it a nice full uptick. It sounds and feels like a full uptick, and there goes the throttle revving and the neutral light.
Reference Thread:
While this issue has crept up in the short time I've had the bike, I must make the confession that I dropped my bike for the first time today :(
Yes, the dream of never dropping a bike is over. And it was just a dumb over reaction on some gravel that did it. Broke too hard going about 15-20 and before I knew it I was down.
Anyway, after I picked up the bike to move on, this issue with neutral was more pronounced than it was before. In fact, even when in neutral, upshifting it didn't take it out of neutral for a few tries. Really annoying. And I'm quite disappointed in myself.
I'm making a separate post about the crash which addresses a matter with the handlebars, here:
http://www.advrider.com/forums/showthread.php?t=491498
paul_g is offline   Reply With Quote
Old 07-31-2009, 09:50 PM   #11
paul_g
Oddometer: 113
Originally Posted by paul_g
Model: (xCountry)
Year: 2009
ABS: no
Reference Thread:
Ok... so, something I hadn't looked at closely... the shift lever was bent in a bit and was hitting the bike on the way up where it shouldn't. So, I bent it back out and it seems to work fine now. I hadn't considered that simple solution because I had been experiencing something similar before I'd dropped it.
Just took it for another test drive and all seems well at 30mph and lower.
Paul
Old 08-05-2009, 09:16 AM   #12
paul_g
Oddometer: 113
won't start
Model: (xCountry)
Year: 2009
ABS: no
Date of occurrence: August 5, 2009
Description of Failure(s): this morning the XCo wouldn't start. It showed the oil light, but I just checked the oil a week ago and it was good. So, could be an electrical issue throwing a false reading. Checked the oil again anyway, and it looked to be a bit over max, which is odd because it wasn't touched since I got it from the dealer, and the last I checked it wasn't nearly that high. Is condensation getting in there? Maybe just a temperature thing. This is the earliest (morning) I've tried to start it, so I'm wondering if that is an influence.
Reference Thread:
Old 08-05-2009, 09:40 AM   #13
slide
A nation in despair
Oddometer: 21,122
Paul,
You mean it shows the oil light w/o the engine running? You say it won't start.
I showed an oil light (faintly) with the engine running. Took it to the dealer who saw it. Dealer kept it a few days. Reported oil light did not return upon further starts and no error codes.
Mystery remains.
Old 08-05-2009, 05:59 PM   #14
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 389
Only one issue
I have two whole days to wait before I pick it up from the dealer. One of only 3 new bikes still available in NZ..
Kiwi Tinkerer is offline   Reply With Quote
Old 08-05-2009, 11:19 PM   #15
paul_g
Oddometer: 113
Model: (xCountry)
Year: 2009
ABS: no
Reference Thread:
Resolution (if any): yes... owner turns out to be a fool. must have left the kickstand down while trying to start it. Works fine now!
Times are GMT -7.   It's 07:06 AM.
