Old 03-26-2011, 11:20 AM   #406
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
Speedo wheel setting (17" is correct setting).
Max Kool is online now   Reply With Quote
Old 03-26-2011, 10:08 PM   #407
dustdonkey
dustdonkey's Avatar
Oddometer: 193
'02 R1150GSA
'09 G650X-Country
'82 R80G/S
'58 R50
'85 R80G/S PD (sold )
dustdonkey is offline   Reply With Quote
Old 03-28-2011, 11:40 AM   #408
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
LED turn signals
Hey there - been searching on the bike, in the manual, and online for this topic: is there something that needs changing when installing LED turn signals in place of the OEM ones? I bough an LED flasher relay but don't see where the OEM one fits...thoughts? Anyone install LED turn signals and the flashing rate went well without any alterations?
FYI: when I installed LEDs on my truck I changed the flasher relay but I knew where it was
Thanks in advance (and apologies for the cross-post, just trying to get the maximum feedback)
Nadim
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 03-31-2011, 06:33 AM   #409
QUIRKSM
QUIRKSM's Avatar
Oddometer: 130
Disco- you need to put a resistor inline to the leds to provide enough resistance for the flasher to work properly. I just left mine alone, it blinks faster but i figure that will get peoples attention more so than the regular speed.
Year-2007
Model-G650X challenge
Mods-unifilter and remus titanium
Mileage-13500
Problem-I noticed air bubbles in my oil resevior after a ride the other day. Wondering if this is normal operation because of the oil moving from the engine to the resevoir or if it is a sign of something wrong. I have never really payed that much attention to if there was bubbles or not before.
2007 BMW X-Challenge
1989 Honda NX-250
QUIRKSM is offline   Reply With Quote
Old 03-31-2011, 08:57 AM   #410
QUIRKSM
QUIRKSM's Avatar
Oddometer: 130
Well I've been searching around and have found many cases where people are saying that small bubbles in the oil is normal for this engine, so i guess I"m just being paranoid. It still seems like something is off though, I'll change the oil and check a few more things this weekend and if i don't see anything obvious i'll say screw it and ride.
1989 Honda NX-250
Old 03-31-2011, 09:05 AM   #411
Don't shoot me!!!
Snowflakes are cold...
Don't shoot me!!!'s Avatar
Oddometer: 569
Nadim
The flasher relay is a buildt inn unit in the dash...
Don't shoot me!!! is offline   Reply With Quote
Old 04-01-2011, 05:11 PM   #412
SCflyer
SCflyer's Avatar
Oddometer: 1,657
I cut into the fitted end of the #4 hose where it points to towards the engine and now it leaks a bit. May not be a worry but like things neat and...not leaking. The cost is about $17.00 so may order another but curious if anyone has replaced this hose with one from a yamahondazuki shop, autozone etc.
I split it using a dremel to get the "special tool required" hose clamp off to replace them with... the simpler ones shown on the fiche. Funny the ones I cut off aren't the ones they have here.
Thanks folks
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 04-02-2011, 12:52 AM   #413
Muddler
Muddler's Avatar
Oddometer: 797
Thanks folks
any leak is definitely a problem
I marked my hose trying to fit my TT tank. Is that how you damaged yours?
I would like to replace my hoses with silicone hose to provide added protection against the hot header issue
Agree it would be interesting to know of any non-BMW hoses that might fit.....anyone??
Muddler is offline   Reply With Quote
Old 04-02-2011, 04:29 AM   #414
SCflyer
SCflyer's Avatar
Oddometer: 1,657
No, I was just cutting them to replace them with the easier "no special tool required" clamp.
Old 05-09-2011, 04:24 PM   #415
Muckpee
Noobie Adventurer
Muckpee's Avatar
Oddometer: 77
headlight clampy thing failure!
Model: (xCountry)
Year:2007
ABS:ya man
Mileage at time of issue:30.5k
Date of occurrence:
Modifications (if any):
Description of Failure(s): Clamp thing that holds headlight bulb to the back of the headlight glass has seperated. Two of the four tiny little indents in the thin metal have given way. Now the bulb floats around giveing me about 3 feet of visibility at night...
Resolution (if any): Drill and tap a few tiny screws into the bulb holder metal??? No way im paying ~300$ for new headlight assembly!
EDIT: JB WELDED
This happen to anyone else?
PS: Checked my idle actuator valve (its been about 500km) and it only had a very thin layer of black sooty buildup sso far. (Removing right side cover provides direct access to the idle actuator)
2007-BMW X-Country 25409kms
http://www.xrange.ca/
Muckpee screwed with this post 05-09-2011 at 06:14 PM
Muckpee is offline   Reply With Quote
Old 05-09-2011, 05:59 PM   #416
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 2,013
Nadim
I think you just need a resistor for each pair, something like this http://cgi.ebay.com.au/LED-Bulb-Turn...item43a6af1a10
dirtsurfer is offline   Reply With Quote
Old 05-09-2011, 06:42 PM   #417
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Thanks - I decided to keep them as is with a faster blink rate...not gonna lose sleep over it...
Old 05-09-2011, 10:54 PM   #418
SCflyer
SCflyer's Avatar
Oddometer: 1,657
I put the LED inserts in that "cooksabit" and employee sells - front and back. They had a fast rate until I cranked the bike just to see. I think the battery was a tad low on charge. Engine running - no problem, but maybe a faster rate will get folks attention better anyway.
Old 05-10-2011, 12:03 AM   #419
dirtsurfer
dirtsurfer's Avatar
Oddometer: 2,013
Yeah his inserts have built in resistors
Old 05-16-2011, 02:11 PM   #420
matloik
kludge
matloik's Avatar
Oddometer: 1,253
Battey - Ignition Switch - Fork Seals
So here's the poop: Fork seals were blown. Brought the bike in as I didn't have time to do them myself. To my surprise they were covered under warranty. I have about 3 weeks left. Had them also check the battery as I was starting to experience difficult starting after stopping for a bit, e.g. for gas. Sure enough, the battery was not holding a charge. This was the 3rd battery from BMW ... but they were not going to warranty it. I had to get a battery right then as I was heading out on a over-nighter, otherwise I would have waited for a Odyssey.
And wouldn't you know it, I got stranded by the ignition switch at my first gas stop as I was heading out to meet some guys for a ride and camp. At first I thought it was a bum battery, but a little jiggle to the wires going up into the key switch caused the instrument panel to tweak out (that's a technical electrical term ). Well crap. And, well, I'm glad to have read about this problem right here in this thread. And, luckiliy, there was an auto parts store right next door. Went in and bought a toggle switch, some 10 g wire and 4 alligator clips. I needed to make some jumper cables as I drained the battery trying to coax it to start.
I will of course be bringing the bike in to get BMW to pay for a new switch. I'll grumble about the battery again too.
Below are a couple pics of the surgery and temporary ignition switch. Got that all buttoned up, and then plugged into a donor battery on a Harley to get started. Tim in Yelp, WA, was nice enought to come back with his bike after noticing me wiring things up.
2011 KTM 250 XC-F / DRZ-ADV / 2013 WR250R (wife's)
matloik is offline   Reply With Quote
Times are GMT -7.   It's 01:26 PM.
