07-14-2011, 07:57 AM
#436 |
Oddometer: 130
Yeah but that was for the upper roller.
2007 BMW X-Challenge 1989 Honda NX-250 |
07-14-2011, 10:46 AM
#437 | |
Oddometer: 236
doesnt take long to lose fluid either
07-14-2011, 10:49 AM
#438 | |
Oddometer: 236
07-14-2011, 02:40 PM
#439 | |
AttitudeIsEverything
Oddometer: 1,279
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~ Kids: OSET electric | Honda CRF50FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar! |
07-28-2011, 10:19 AM
#440 | |
Oddometer: 2
covered?
hey motojc, im having the exact same issue with my bike right now, was wondering if the bmw dealership covered this under warranty or if it came out of pocket?
Thanks! Quote:
07-28-2011, 03:35 PM
#441 |
Ross
Oddometer: 273
X-Ch LCD disintegrate.
The LCD on my X-ch has started to disintegrate. anyone else see this on their G? It looks like a small squiggly line forming on the display. It stays there when the key is out. I pulled the cover off expecting to see a piece of dirt in there but there is no contamination at all. It appears that the LCD is just coming apart. Took the unit into local BMW dealer. Good timing. I have 3 weeks left on my warranty. So it is being replaced under warranty, no problem.
This speedo unit was replaced last year under warranty as it leaked water. This unit hasn't leaked. |
08-22-2011, 11:25 AM
#442 |
Dubletruble
Oddometer: 59
07
Xch 10,000 miles problem: Still have the fuel pump issue, it won't pump fuel when connected? Dealer(s) say they can fix but can't tell me how? already cost me $110 which was during warranty and still dealer didn't fix. So this is what is happening, fuel pump works fine when connected to power source, when connected to the connector on wire harness power gets cut to pump as soon as connected, not all the wires (there are 4) just the one responsible for pumping fuel. When disconnected the wire on the harness reads 8.0, right when touched to connector it goes to 0.0? remedy: added (spliced) a wire from power source coming from fuse box (the same fuse controlling radiator fan). Fuel pump is now always pumping fuel as soon as ignition is switched on and bike runs fine and has been for at least 2000 miles, the wire supplying the power to the fuel pump reads 12.0 and it run directly to fuel pump connector. new problem: bike stops running when it feels like it. yesterday while out for a quick run thru the twisties coming around a corner bike power shuts down. Coast to a stop listen for fuel pump and nothing turn key on and off a couple times still can't here the fuel pump, take off the seat remove fuse box from its holder which is right where the splice is, reconnect the fuel pump wire together and fuel pump goes back on. Push wires back down and put fuse box back on holder and back on my way, bike ran great the rest of a spritied ride. This is the 2nd time in 4 days that has happened although the first was leaving for work in the morning after bike sat all night. side note: have noticed the radiator fan has not come on all summer when in use during "hot" rides, also the overheating "dummy" light has never come on either although all works when keyed on (precheck). I did do a radiator flush and refilled with water wetter and the fan does work when power ran directly from battery just hasn't gone on from bike again neither has the overheating light. Could the bike just be running that much cooler after the flush and using water wetter? Anyhow i really like this bike and have a blast on it in all different kinds of riding, It's handling great after some suspension mods and is a blast as a all-around town commuter and would be the most fun bike owned for riding if the electrical gremlins would go away. Anyway to get a schematics on the electrical would hopefully help me solve the issue. |
08-22-2011, 07:26 PM
#443 | |
Mapaholic
Oddometer: 235
Loom Gremlins
My XC has similar milage to yours backyardorganics. After a good spirited run, stop then fuse (F) blows on hitting the starter button upon re start attempt. Replace fuse multiple times before finally co operating. Cold start was always good. My auto electrician tested and concluded there must be an intermittent short somewhere in the loom between starter switch and starter relay so that has been by passed. Have't had time to ride since so hopefully it is good now.
07 X-Challenge |
08-23-2011, 01:45 AM
#444 | |
Two-wheelin' Fool
Oddometer: 2,571
08-23-2011, 04:12 AM
#445 | |
Challenged Adventurer
Oddometer: 1,385
ex X phile Avoid the Gavel, travel by gravel |
08-23-2011, 07:44 AM
#446 | |
Dubletruble
Oddometer: 59
I looked at the ignition switch and the connectors seemed fine, nothing lose or corroded and the soldered tabs seemed good. What kind of "gremlins" were you experiencing ? If it really is that simple it would be great but seems like the ignition switch only allows power to the bike, but if you were suffering same problems then that may be the answer. When you say "inside your ignition switch" do you mean taking it apart or just where the wires connect ? Also anyone know the easy way to check the radiator fan or the temperature sensor which would tell the radiator fan to go on ? |
08-23-2011, 07:48 AM
#447 | |
ENDURO Wanabee
Oddometer: 181
you can disconnect round plug that goes to temp sensor (right side of the engine head) - with ignition turned on - fan should start to spin fast.
Regards Lucas ---------------- I have a new challange ..... X-Challenge .... www.vimeo.com/mtbiker http://picasaweb.google.com/lukasz.lechowicz/XChallenge MTBiker78 screwed with this post 08-23-2011 at 07:57 AM |
08-31-2011, 07:40 AM
#448 | |
Dubletruble
Oddometer: 59
removing power (battery) for 15 min or more will reset memory to zero. When the battery is reconnected should the reset of idle actuator still be done? (hold throttle open, turn key on, wait, turn key off) also when doing the reset this way should you hold throttle open while turning key off? (ie: hold throttle full open, turn key on, wait, turn key off while still holding throttle full open, wait, turn key on start as normal after precheck complete), or should you let throttle go back to close before turning key off? Also will this reset other sensors (O2 sensor etc.)? |
09-10-2011, 10:49 AM
#449 |
Dubletruble
Oddometer: 59
so still can't get an electrical gremlin figured out. It started with the fuel pump stopped working for no reason while on a ride. After splicing wire from same fuse and running directly to fuel pump i was able to continue riding and did so all winter. Noticed radiator fan was never going on so tried MTBIKER78 suggestion "Please try to disconnect cable that goes to temprature sensor - round plug that goes to engine head (somewhere in the middle) on right side. With unpluged sensor and ignition turned on fan should spin. Just a test for fan operation." when i did this the fan didn't spin?, so ran a wire from battery to fan and fan worked fine.
After thinking about it some more the fan NOT turning on may have started the same time the fuel pump stopped pumping, (just never noticed since the fan only comes on when temp is high), this makes sense from the standpoint that both run from same fuse. So I'm still in same position fuel pump won't work when plugged into harness and radiator fan won't come on when temp goes up, although both work fine when power is supplies directly from battery. Just a side note the "dummy" light on the console does work when the temp gets high enough so it tells me the bike is overheating but doesn't turn fan on to help cool it off. What is the easy answer? since i'm a basic dumbass when it comes to this kind of fix hopefully the smart inmates may know the answer. |
09-10-2011, 12:14 PM
#450 |
Oddometer: 2,089
It actually sounds like you're pretty close to solving it. I don't have a diagram, but based upon what you've said:
The fuel pump and fan are on the same circuit. Your loads function properly when directly connect to the battery - therefore So somewhere in that circuit you have an Open. Most likely at a point common to both before the loads unless they share the same wiring/ground point after the load. There can't be a whole lot of wiring to check, although I can fully understand not wanting to venture into the loom if it is bundled up. An alternative would just be to run a new wire and bypass whatever region you determine the problem to be. I realize this is all stuff you probably know, but it sounds like you're pretty close. Since the problem is in one circuit, I would think the odds are some loose/corroded connector. But chaffed wires are always possible on motos.
Marc 07 XChallenge 99 VFR |
