Old 04-06-2012, 06:27 AM   #481
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 5,240
I ran out of gas yesterday and the low fuel light never came on. Is there a way to troubleshoot the low fuel indicator?
Ride safe enough....
joenuclear is offline   Reply With Quote
Old 04-10-2012, 12:50 AM   #482
an13
Oddometer: 19
I have had the "not starting while hot" on several random occasions, usually after very short fueling or throwing-the-water stops. Drained my battery on starting attempts because didn't wait long enough to cool and walked to nearest settlement. Starter turns nice but doesn't even try to fire. When getting more juice with jumper cables and cooled more while pushing, bike will start immediately. Will try Lifepo4 battery for more CCA.
an13 is offline   Reply With Quote
Old 04-13-2012, 12:26 PM   #483
velofleche
Oddometer: 6
Restarting when warm
Bike intermittently fails to start when warm. Seems to have plenty of cranking amps to turn but won't fire up. Only solution i have thus far discovered is to walk away for 10mins. At least for now that seems to work, But for obvious reasons i am looking to resolve this, would greatly appreciate any input?
velofleche is offline   Reply With Quote
Old 04-13-2012, 01:44 PM   #484
August West
Wharf Rat
August West's Avatar
Oddometer: 506
Same here.
August West is offline   Reply With Quote
Old 04-13-2012, 04:55 PM   #485
JonBryant
Oddometer: 16
Funny, mine is the opposite, if i let it sit for 10 minutes i can't get it to idle. It'll fire up then die. Same thing happens when it's cold after a night sitting. Love the bike, but might find something different (F800GS)
JonBryant is offline   Reply With Quote
Old 04-13-2012, 06:37 PM   #486
Butters
Butters's Avatar
Oddometer: 2,069
Just curious . . . do you guys still have your charcoal canisters? Just wondering if it could be a venting issue collapsing a fuel line. Not sure if that's even possible, but I can't really visualize the setup in my head. But I've heard of similar things in cars.
Marc
07 XChallenge
99 VFR
Butters is offline   Reply With Quote
Old 04-13-2012, 08:13 PM   #487
August West
Wharf Rat
Oddometer: 506
No canister on mine.
Old 04-14-2012, 01:42 PM   #488
JonBryant
Oddometer: 16
nope, no canister either.
Old 04-14-2012, 09:14 PM   #489
wiggins
Oddometer: 23
Hot Starts
Guys, my bike 2009 XCountry when new would not restart a lot of times after riding, but would always start cold. I took it back to the dealer and after a lot of trial and error they said the injector was sticking. They called Germany and talked to a head engineer and he thought it was because of the ethanol in our fuel. Ethanol has some water in it and the injector being new and tight was seizing up because of the water content. They replaced the injector and again it would not start after being warmed up, I called the dealer from the side of the road and he said to tap the injector with a screwdriver with the key on and then see if it startes, it started every time I tapped the injector. I figured out the injector needed some lubrication so I started adding 2 stroke oil to the fuel every time I fuel up, after that it has never failed to start hot or cold. I would put in one bottle of the 2 stroke oil (just a couple on ounces) like you use on a chainsaw, I did this for about 500 to 750 miles and then quit using the 2 stroke oil and it has been starting every time. You can take the seat off and look towards the front under the plastic and see the injector with just enough room to tap the injector (again with the key to the run position) and mine would always fire up when hot.
The bike now has about 6,000 miles on it and it has not given me any more problems, I only used the 2 stroke for about 5 or 6 tank refuelings. I think the new injector just need a little lubrication until it loosened up.
wiggins is offline   Reply With Quote
Old 04-15-2012, 05:45 AM   #490
GSALite
GSALite's Avatar
Oddometer: 712
Nice! I will have to remember that. Thanks for the info.
The roundest knight at King Arthur's round table was Sir Cumference. He acquired his size from too much pi.
GSALite is offline   Reply With Quote
Old 04-17-2012, 06:05 AM   #491
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,206
Send a message via MSN to Max Kool Send a message via Skype™ to Max Kool
Still thinking the cause for bad starting on a hot engine is the autodecompression lever. Lever stuck in "closed" position. Compression too big, starter has a hard job to cranck the engine, and bike won't start.
I checked mine the other day (removed valve cover) and found the side surface is a bit rough. I will remove it and try to polish the sides. Which I can't do on my own, because you need to release the cam chain tension "with a proper tool" before removal of the exhaust camshaft.
...which I don't have..
Max Kool is offline   Reply With Quote
Old 04-18-2012, 12:52 AM   #492
Lankbrown
No Pain No Gain
Lankbrown's Avatar
Oddometer: 60
Originally Posted by Lankbrown View Post
I brought an 07 Xchallenge in late 2009. The bike has now done 74,000 kms and I really enjoy the bike. It has been modified in many area generally to make it a great Adv bike.
Recently it has started to develop a miss fire to the point that it is now in the garage waiting patiently for attention. I am going to clear the throttle body over the week end as I have purchased a new Idle Control Device because it is covered in crap tried an initial basic clean that had some improvement but after reading the treads a thorough job need to done.
The only thing that worries me is the miss fire. The miss fire increases as the bike gets warm which usually indicates coils. They are very expensive in OZ and wondered if anyone else has replaced theirs.
Cheers
Problem solved. The wife cleaned the throttle body, she refuses to clean the mud off the bike for me but give her some part to clean and it comes back spotless. Replaced the Idle Control Device and put in a new set of spark plus and no more missfire no more fast idle and the bike feels normal.
Going away this week end and expect to do 1500+k's in OZ we always do alot of k's and hopefully things will run smoothly.
Lankbrown is offline   Reply With Quote
Old 04-23-2012, 04:17 PM   #493
Miguel Pedro
Miguel Pedro's Avatar
Oddometer: 13
Hi to all!
Last month my free wheel died!!
Let me share with you all the work I done.
1st, I had to make my on puller (BMW in Portugal don’t sell them)
2nd , with the help of some heat I pull the magnetic well out
3 The free wheel was completed wasted.
These parts are very expensive, so I decide to put only the free wheel. KTM uses the same free wheel and is cheaper!!
After some polish, the three parts are ready to put together:
Now the bike starts very well, I’m very satisfied with the job!!
SKF makes a free wheel with the right dimensions for the X, but seems like that they don’t sell it to public!!!!!
Miguel Pedro is offline   Reply With Quote
Old 04-24-2012, 04:50 AM   #494
imeny
imeny's Avatar
Oddometer: 96
Thanks for sharing with us.
imeny is offline   Reply With Quote
Old 04-28-2012, 05:52 AM   #495
DocRogers
DocRogers's Avatar
Oddometer: 99
I'm gonna have to try that with the big bike (1200 GSA) - I've had the injectors cleaned twice on what is still essentially a new bike (4K miles). Thanks!
'09 BMW R1200GSA (Rocinante), '78 BMW R100RS Belgian, '07 BMW G650Xcountry, '08 KTM 450EXC, '07 Montesa Cota 4rt, '07 Scorpa TY-S 175, '10 Kawasaki KLX110L, '86 Honda TLR200 Reflex, '78 Husky 250WR
DocRogers is offline   Reply With Quote
Times are GMT -7.   It's 01:47 PM.
