Old 05-03-2012, 01:43 PM   #496
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
Originally Posted by Miguel Pedro View Post
KTM uses the same free wheel and is cheaper!!
Can you give us the KTM part number please Miguel?
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 05-04-2012, 04:27 AM   #497
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,299
Walter, it looks like the part # is in the picture.
joenuclear is online now   Reply With Quote
Old 05-04-2012, 04:49 PM   #498
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
Hmmmm Just checked it on another computer and sure enough there is a picture of the part number.
For some reason it wasnt loading on my other computer :)
Old 05-04-2012, 09:43 PM   #499
jtw000
Survivor
Oddometer: 564
A KTM part cheaper than a BMW part? This is a sign of the apocalypse. The world is going to end this year! In England they're twice or three times more expensive, in Thailand it's the other way round but here, the BMW dealers are pretty terrible.
I have an issue. My Garmin GPS packed in. Does that qualify? It was mounted on the bike at the time.
jtw000 is offline   Reply With Quote
Old 05-25-2012, 10:00 AM   #500
DESERT SCORPION
SINGLE TRACK
DESERT SCORPION's Avatar
Oddometer: 125
I luv my bmw
I love my BMW even though it stalls all the time on warmup.
I love my BMW even though it has a rear brake that squeals like a pig when I use it.
I love my BMW even though the rear brake is dragging. Maybe that's why it squeals like a pig.
I love my BMW even though attempts to bleed the rear master cylinder add air to the system.
I love my BMW even though now the rear brake is mushy as a marshmallow about to fall off the stick.
I love my BMW even though it appears that the rear master cylinder is trash & only costs $175 to replace.
I love my BMW even though there is no rebuild kit for this glorious master cylinder.
I love my BMW even though the offending assembly got trashed because it holds water.
I love my BMW even though the sealing boot of said assembly seals well at the pushrod, but not at all at the housing.
I love my BMW even though this worthless boot acts just like a Dixie cup full of water and stays wet internally eternally. I love my BMW even though this condition has corroded everything in sight at the mouth of this crumby little assembly.
I love my BMW even though it gives me writers cramp venting.
THE SCORPION
DESERT SCORPION is offline   Reply With Quote
Old 05-25-2012, 11:33 AM   #501
dakardad
Not waiting for anyone
dakardad's Avatar
Oddometer: 445
Originally Posted by dakardad View Post
07 X-
No problems, nada.
TT tank, canister removed.
I dont even know for sure what kind of battery it has.
It starts every time and isnt weak. Year two.
7k. Valves at 6k, perfect.
Frequent oil changes-Lucas synthetic 20-50 motorcycle specific.
I even bent my shifter, bashed it back with a rock, didn't break.
Golden bike, I love it.
As of today at 22k. I have toasted 2 batts. ABS motor replaced (warranty.. Whew!). The key switch shorted nd melted on a ride, had to be towed. Behr rims suck but are still turning.
Stock suspension. A bunch of tires.
Love this bike.
Where am I going you ask.... I dunno really
just THATAWAY!!
dakardad is offline   Reply With Quote
Old 05-27-2012, 05:35 AM   #502
DESERT SCORPION
SINGLE TRACK
Oddometer: 125
Rear brakes
Model: xChallenge
Year: 2007
ABS: yes
Mileage at time of issue: 17K
Date of occurrence: last few weeks
Modifications (if any): Leo Vince exhaust, canistectomy, hand guards, lots of minor tweaks
Description of Failure(s): rear brake drags & squeaks when applied
Resolution (if any): Attempted to bleed rear brake, but only succeeded in introducing more air to system. After inspecting the dirty, corroded condition of the mouth of the rear master cylinder, I believe the air was being drawn in here. Removed and cleaned master cyl. Filed down the offending casting seams that caused the poor seal. Pumped fresh brake fuild through it, reinstalled. Sealed the boot to the housing with RTV. Added a small vent hole near the pushrod end of the boot. Bled rear brake with additional proceedure of cracking the fitting on top of the ABS motor. So far, so good. The rear rotor is worn and slightly warped. EBC MD810C on order. If needed I may also order this: http://www.oppracing.com/product_dis...lack-wpush-rod This appears to be the BMW rear master cylinder, without the BMW price.
Old 05-28-2012, 10:46 AM   #503
Miguel Pedro
Miguel Pedro's Avatar
Oddometer: 21
Hi Colebatch!
KTM part nº 58440026000 cost me 75€
Miguel Pedro is offline   Reply With Quote
Old 06-11-2012, 05:42 PM   #504
tenfive0
tenfive0's Avatar
Oddometer: 86
New Battery
I have a 2008 Xcountry and was having an intermittent stalling problem right after start ups for about a year. If I started the bike and get on it right away and take off without warming up for a few minutes the bike would stall exactly at the same spot ½ a city block away from my house. I’d pull the clutch in and push the starter button and it would always fire right back up and not stall again until the next time upon a cold start up and a fast get away. If I’d let the bike warm up for about 30 to 45 seconds without taking off the bike wouldn’t stall at all.
Earlier this year I was teaching my 14 year old son to ride the bike and he was doing low speed maneuvers cruising around in low RPM’s. The bike stalled and wouldn’t start. We tried to pop start it with no luck. Pushed the bike home put it on the charger and it was fine until last week. I had to go to the bank and I was in a hurry. I cold started the bike after it had sat for a few days. I got to the same EXCACT spot as usual and the bike stalled. I pulled in the clutch hit the started button and it fired right back up with no problem. The bike ran fine the next 10 miles on the way to the bank. I pulled up to the drive window and shut the bike off. I did what needed to be done with the bank and turned the key, hit the button and nothing. The bike wouldn’t start. Figured I’d let it sit awhile because I’ve read sometimes if you let some of the Xbikes cool down they’d start. After cooling down still nothing, the bike wouldn’t start. Turns out I replaced the battery the next day after needing a pickup truck to get the bike home. After replacing the battery the bike seems to be running smoother with more balls. Got on the bike this morning in a hurry and took off without stalling. It appears the new battery chased the gremlin away
1969 Harley-Davidson FLH
2006 Harley-Davidson FLHT
tenfive0 is offline   Reply With Quote
Old 08-05-2012, 06:32 AM   #505
August West
Wharf Rat
August West's Avatar
Oddometer: 552
need help taking ignition switch apart
Sposed to be leaving on week long ride in a coupla hours, bike is DOA. I need help taking the bottom half of the ignition switch apart. I can see that the round bottom seems to separate. How do I get it apart.
Thanks!!
August West is offline   Reply With Quote
Old 08-05-2012, 06:50 AM   #506
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,588
Thanks!!
It's been awhile since I inspected mine, but I thought it just snaps together. I used a couple flathead micro screwdrivers to release the tabs and then it separates. At least, that's my recollection. My wires/solder joint were fine.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 08-05-2012, 06:58 AM   #507
August West
Wharf Rat
Oddometer: 552
Thanks Butters you are right. I am pretty good at breaking little plastic things so I wanted to be careful. One wire is completely separated, no wonder it didn't want to respond!
Old 08-05-2012, 06:58 AM   #508
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
Originally Posted by tenfive0 View Post
Turns out I replaced the battery the next day after needing a pickup truck to get the bike home. After replacing the battery the bike seems to be running smoother with more balls. Got on the bike this morning in a hurry and took off without stalling. It appears the new battery chased the gremlin away.
Congratulations on solving your dilemma and getting back on the road!
The G650X is VERY dependent on its battery! If you review this and all related threads, you'll find that many agonizing and perplexing problems have been solved with a new, high-quality battery.
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline   Reply With Quote
Old 08-05-2012, 09:30 AM   #509
August West
Wharf Rat
Oddometer: 552
I soldered the disconnected wire and now it runs through the pre-sequence MOST of the time, not all the time. That's confidence inspiring. I'll head out and hope it lasts....
Old 08-18-2012, 04:34 PM   #510
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,588
Originally Posted by daytona View Post
I can't find the recall on the battery on the web! was it supposed to have a yuasa ytz installed instead of the one I find in it today Exide with the BMW label and a tag with 06/09 on it! the date the bike was sold. I called the service man, got phone slammed on me, called and spoke to the mgr! said he'd look into it! call next week. Any comments on what I can do? This stallin thing is getting unbearable not to mention UNSAFE. Thanks for lettin me rant! I feel better anyway!
Although I doubt the battery has anything to do with the stalling (at least until the battery actually fails). But I would not trust that Exide battery one bit! There's a reason they went with Yuasa, Exide just couldn't fix the issue. This was a couple years ago, so maybe the newest Exide is OK. But having been stranded by a failed Exide already, I would swap it out if even at my own expense.
Marc
07 XChallenge
Times are GMT -7.   It's 03:58 PM.
