Old 09-22-2009, 07:12 AM   #121
DoucheBag
feminine hygiene product
DoucheBag's Avatar
Oddometer: 449
I think the dark blue is normal, just providing the picture as requested...
2007 G650X Challenge (SOLD 6/29/10 )
www.heritage.org - Learn the facts
DoucheBag is offline   Reply With Quote
Old 11-02-2009, 01:45 PM   #122
FOXedupONE
Momafox can I ride?
FOXedupONE's Avatar
Oddometer: 2,469
My ignition switch solder conection failed also. Everyone needs to beef up this conection. I'm thinking a bunch of epoxy dumped into this area should do it.
FOXedupONE is offline   Reply With Quote
Old 11-02-2009, 02:04 PM   #123
matloik
kludge
matloik's Avatar
Oddometer: 1,119
Can you post more specifics/pics?
'08 Versys & '08 450 EXC-R / '11 G650GS & '06 KLX250S (wife's)
Portland Area Off Pavement Rides ~ Hood River Rides ~ Vancouver Island Trip
matloik is offline   Reply With Quote
Old 11-02-2009, 03:54 PM   #124
MZcountryboy
MZcountryboy's Avatar
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,203
I zip tied my wires coing out of the ignition switch to the round body of the switch, to eliminate any pull/vibration. Been fine for 12k miles. Definitely a weak link, but easy fix.
MZcountryboy screwed with this post 11-02-2009 at 04:34 PM
MZcountryboy is offline   Reply With Quote
Old 11-02-2009, 04:21 PM   #125
satur9
angry black guy
satur9's Avatar
Oddometer: 368
does this affect the gauge cluster any. my bike has develop a nasty habit of reseting the clock and trip meters when i turn the key sometimes. there no stalling or drivability issues though.
seriously?.... is that what you ride?
Well, it took a lot of work to be the ass that I am
And I'm real damn sure that anyone can, equally easily f*ck you over ...(modest mouse).
satur9 is offline   Reply With Quote
Old 11-02-2009, 04:37 PM   #126
slide
A nation in despair
Oddometer: 21,030
I've had my gauge cluster all reset too. I also have had my display fade out during heavy rains. I doubt either issue is related to the solder in the ignition switch, though.
slide is offline   Reply With Quote
Old 11-02-2009, 05:01 PM   #127
TAS
TAS's Avatar
Oddometer: 482
I've had mine for two months. Bought it used with about 2500 miles on it and it now has just over 5000. Runs great with no issues but makes a howling - ringing noise while running down the road. It's hard to explain but it's made this noise since I bought it. It's almost like a hum resonating from the engine area. It does not increase as the RPM increases. I commute 86 miles a day with 70 miles of it crusing 75 - 80 MPH on I95. I hear it while commuting or while tooling along on trails at 10 MPH.
My 1150GS made a lot of noise (compared to my other bikes) but ran flawlessly the entire time I had it. Could this be the same? Anyone else notice this type of noise?
BTW: Running Pirelli Scorpions and full Remus exhaust if that helps.
TAS screwed with this post 11-02-2009 at 05:08 PM
TAS is online now   Reply With Quote
Old 11-02-2009, 05:15 PM   #128
tdv
Oddometer: 96
bash plate perhaps?
Mine made similar noise - I figured it was engine noise reflected up from the aftermarket bash plate. I put some sound deadening material (self adhesive) on the inside of the plate, it quieted down significantly.
I also put some rubber grommets between the bash plate and the places where it connects to the frame.
You could try riding with the bash plate removed, see if the noise changes or disappears before trying the padding stuff.
Dmitri
If only I knew what I'm talking about!
tdv is offline   Reply With Quote
Old 11-02-2009, 05:19 PM   #129
TAS
TAS's Avatar
Oddometer: 482
Dmitri
I'm running a TT skid plate. I never thought about it resonating; thank you very much for the input. I'll pull it and see what happens. Thanks again for your help.
Old 11-03-2009, 08:24 AM   #130
DoucheBag
DoucheBag's Avatar
Oddometer: 449
I've got the TT large bash plate, resigntes sound significantly...
Old 11-03-2009, 01:30 PM   #131
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,206
Send a message via MSN to Max Kool Send a message via Skype™ to Max Kool
I put the self adhesive bitumen inside the skidplate (the stuff you stick to the inside of car doors to make them "sound dead"). Made a lot of difference.
Available at car parts stores for a few dollars.
Max Kool is offline   Reply With Quote
Old 11-03-2009, 01:35 PM   #132
satur9
angry black guy
satur9's Avatar
Oddometer: 368
did you get your display issue resolved.mine hasnt faded out in rain. but resets like every other day.
Old 11-03-2009, 04:29 PM   #133
TAS
TAS's Avatar
Oddometer: 482
I'll have to try that. Thanks for the info!
Old 11-05-2009, 10:06 AM   #134
dmcd
dmcd's Avatar
Oddometer: 338
Originally Posted by andrewgore
I want to keep this as factual as possible, without any sort of rif-raff.
Andrew
Sorry!
Looks pretty good for these bikes. I'll keep a look out for the crank failure at +20k miles. For me that will be around 2019.
dmcd is offline   Reply With Quote
Old 11-05-2009, 10:42 AM   #135
toofast4uu
adventurer
toofast4uu's Avatar
Oddometer: 961
2007 X-Challenge
Owned since new
-My left blinker indicator stopped working...6000 miles
-Headlight assemble cracked
BMW warrantied it, no problems at all...
I'm still loving this bike!
toofast4uu is offline   Reply With Quote
Times are GMT -7.   It's 03:56 PM.
