Old 07-22-2009, 10:36 AM   #1
euromotorcycles OP
Oddometer: 168
Garmin 2610 clock display ?
Can the 2610 display the time of day (clock) on it's screen.If so what must I do to access this function.
euromotorcycles is offline   Reply With Quote
Old 07-22-2009, 03:01 PM   #2
rexbro
Oddometer: 146
Easy to do but you have to do both mapping and routing separately.
-hit menu button then select tab setup option
-select mapping or routing tab
-select tab style custom option
-hit menu button again then select custom setup option
-now you can select which tab you want to customize and pick from the list
of available display types.
Hope that helps a bit.
rexbro is offline   Reply With Quote
Old 07-23-2009, 06:24 AM   #3
euromotorcycles OP
Oddometer: 168
Thank you for the tip it worked out well.
Times are GMT -7.   It's 06:27 PM.
