Old 07-26-2009, 08:09 AM   #16
corrado113
corrado113's Avatar
Oddometer: 465
Monoprice
Checkout monoprice.com for some really inexpensive stuff. You can pick up a car charger to USB for $.83!!! Shipping is reasonable too! I bought a bunch of them just because they were so cheap.
http://www.monoprice.com/products/pr...seq=1&format=2
1986 K100RS
1996 R1100GS
2005 DRZ400S
Custom Sewing and Cordura Products Storm Industries or visit us on facebook
corrado113 is offline   Reply With Quote
Old 03-05-2010, 12:43 PM   #17
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
When I don't want to use a tank bag for charging my stuff for day rides, I plug a powerlet cigarette socket + mini USB charger into my GS's side power socket. Run the apple USB power cord to my iPhone in my pants side pocket. Works like a charm. Can be done with most cell phones that use USB 5 volts to charge.
Burnszilla is offline   Reply With Quote
Old 03-05-2010, 12:52 PM   #18
Tail Gunner
Life is Good !!!
Tail Gunner's Avatar
Oddometer: 1,608
I got a hardwired usb cable. $10
http://www.overstock.com/Electronics...2/product.html
Drew
06 BMW HP2 - BLUE
94 Goldwing - BIG RED
06 BMW RTP - BLACK & WHITE
Meet & Greet Thursdays 6pm
Tail Gunner is offline   Reply With Quote
Old 03-05-2010, 01:12 PM   #19
Tiz
Tiz's Avatar
Oddometer: 626
Originally Posted by mouthfulloflake
I made mine, its a $1.49 voltage regulator from radio shack, and a usb connector.
lm7805, takes anything DC up to 35 volts, and makes it 5 volts DC, pins 1 and 4 on the USB are power.
simple.
http://www.radioshack.com/product/in...ductId=2062599
Neat. Schematic please, for those of us who know nothing about connecting these?
--Kevin
FJR1300-2008
ex-2005R1200GS
ex-DL650K5
ex-2001 XR400
ex-2002KLR650
Tiz is offline   Reply With Quote
Old 03-05-2010, 01:22 PM   #20
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,503
LM7805 has 3 pins.
pin 1 input is any DC voltage from 5-35 volts.
pin 2 is ground ( for both input and output)
pin 3 is regulated 5 volt DC output, up to 1amp.
you should install a small heatsink on the unit to keep it cool if you are using it at near an amp of current, or it will get hot either shut down or not last long.
Pins 1 and 4 on the USB are what you power.
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake screwed with this post 03-05-2010 at 01:28 PM
mouthfulloflake is offline   Reply With Quote
Old 03-05-2010, 01:28 PM   #21
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
LM7805 has 3 pins.
you MUST install a small heatsink on the unit to keep it cool if you are using it at near an amp of current, or it will get hot either shut down or not last long.
Good to know.. I tried making one with these parts and I guess I fried it.
I ended up just using one of these...
Old 03-05-2010, 05:47 PM   #22
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,716
7805 will probably work a lot better if you throw some filter caps on the input and output to ground.
Although it's not usually a problem on a bike, a 5v regulator won't work too well with 5v at the input... 7's about the lowest i'd go.
My reg of choice is the LM2937 for 5v applications.... had better luck with those, lower drop-out voltage.
Heatsink's a big deal on them. Case/tab is ground, so if you put it in a metal box, run a screw through the tab to the box. Easiest way to get the job done.
A nice connector is L-Com's ECJ504B-UA. Red and Black are +5 and Gnd respectively.
Spewer of the poignant non sequitur
#155 | Mule's Photos | BackCountryRebels | ThumperTalk | Tekrider | TylersBA
SnowMule is online now   Reply With Quote
Old 03-05-2010, 06:30 PM   #23
theWolfTamer
Lupie on a Mission
theWolfTamer's Avatar
Oddometer: 395
I saw the powered tank bags after I had just purchased a new one. Instead of buying a powered bag, I have a radio shack power outlet attached to the left panel of my 2005 FZ1. I run an extension cord with an outlet to the tank bag that has an on/off switch. Inside the bag, I have the dual usb adapter (like pictured before) that I use to power my pda which runs my gps software. Later I added a y outlet so I can power my heated gear or radar in addition to the gps.
Power Accessory Outlet
Outlet from accessory jack to tank bag:
theWolfTamer screwed with this post 03-05-2010 at 06:36 PM
theWolfTamer is online now   Reply With Quote
Old 03-05-2010, 07:00 PM   #24
x3300
geoff
Oddometer: 170
Originally Posted by a1fa
Has anyone wired a USB port on their motorcycle yet?
Hi,
Yes, I power my GPS, charge my cell phone, and even recharge my NiMN batteries with an Energizer Duo Charger.
When I go on a trip I carry a small 115V to USB power adapter so I can power everything either from the bike or a wall outlet.
I just got a LM7805 5v voltage regulator (radio shack, etc) and soldered it to the BMW 12 volt accessory plug. If you run high current you need a heat sink. I just used a piece of scrap aluminum I had around.
http://tinyurl.com/yecs4ud/bmw-to-usb-adapter.jpg
-x3300
x3300 is offline   Reply With Quote
Old 03-05-2010, 07:23 PM   #25
mouthfulloflake
Not afraid
Oddometer: 17,503
nah, the 7805 works fine in this app with no caps, and has 2x the current ability of the the LM2937
Old 03-05-2010, 07:31 PM   #26
worwig
Oddometer: 1,254
I use a 7805 regulator (with a .1 ceramic cap on the in and out legs BTW) on the USB cable to charge and run my PDA phone. The PDA is clipped in a RAM mount. I made an aluminum plate that is about 2.5x2.5 inchs, 1/8 inch thick, and the aluminum RAM plate is attached to it. It still gets VERY warm. The charge current gets right up there at the 1 amp limit and it is dropping 7 to 9 volts, so 7 to 9 watts)
But the nice part of the 7805 is that it will just shut down if it overheats. Aand it will shut down it you short the output. But connect it backwards and you toast it in a second.
Point is that you may want a LARGE heatsink.
Hog mountain Weather
worwig screwed with this post 03-06-2010 at 07:53 AM
worwig is offline   Reply With Quote
Old 03-06-2010, 03:22 AM   #27
Dusty Boots
Dusty Boots's Avatar
Oddometer: 315
I use this 100 W power inverter to charge my MP3, cell, netbook etc, while riding
No one is completely useless ....... they can always be used as a horrible example!
Dusty Boots is offline   Reply With Quote
Old 03-06-2010, 03:48 AM   #28
TeneRay
2>4
TeneRay's Avatar
Oddometer: 2,159
walmart has a car/wall charger with 2 usb ports for a few bucks.
I feel closer to home the further I get from it.
TeneRay is offline   Reply With Quote
Old 03-06-2010, 11:55 AM   #29
CharlieP
CharlieP's Avatar
Oddometer: 122
I have a small 110v inverter that also has USB so I can run my helmet cam and charge my netbook on the fly. Helmet cam mounted to bars when plugged into charger
CharlieP is offline   Reply With Quote
Old 03-06-2010, 02:08 PM   #30
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
Originally Posted by Jamie Z
Motorola Razr won't charge from a standard USB. Otherwise, I could lose my Motorola 12V charger.
Jamie
the razr is funny that way. I downloaded the drivers to a few computers, it charges on most but not all computers. The front usb ports on most computers wont due but on the same pc if plugged into the rear usb plug it works fine.
HaChayalBoded is offline   Reply With Quote
Times are GMT -7.   It's 08:24 PM.
