Old 03-23-2010, 01:40 PM   #76
JeffinTD
JeffinTD's Avatar
Oddometer: 1,162
Originally Posted by ssven
The Belkin adapter above puts out a full amp--add a $3 lighter socket from any auto parts store and you're in business.
Yeah, I've got two cig sockets on the bike, but would like something in a waterproof USB outlet...
Have: 09 R1200GSA, FLHR Road King, 680 Rincon, 500 Foreman.
Had: CX500, DR650, S2 Thunderbolt.
Need: To win the lottery so I can actually get time to ride.
JeffinTD is offline   Reply With Quote
Old 03-23-2010, 01:50 PM   #77
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,511
USB power
The power limit also means that for devices like my GoPro camera it takes twice as long to charge plugged into my computer as it does when plugged into my USB wall charger.
Originally Posted by worwig
Also keep in mind that some cables limit the charge to 500ma. A true USB should never go over 500ma or it may damage the PC USB port. My unit was two type of cables, one is 500ma and the other is 1amp.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 03-23-2010, 02:15 PM   #78
JeffinTD
JeffinTD's Avatar
Oddometer: 1,162
Yeah, ditto here. I plan to use it for a Veho muvi, and a Vado camera on an Alaska trip.
I'll probably snag a super-small laptop or a netbook, but when I camp I'll want a way to charge the cameras while riding.
Old 03-23-2010, 02:19 PM   #79
Motoriley
Motoriley's Avatar
Oddometer: 2,511
USB fun
I grabbed a cheap Acer netbook for my last trip and it was great to have an expendable machine to download pics and video to as well check mail. use mapping software and blog etc... Forgot to bring a little usb hard drive so I was risking it by having my pics and video only on the computer with no back up once I re-used the memory cards. Worked out OK but I'm usually mister back-up when it come to digital media....
Old 03-23-2010, 02:24 PM   #80
JeffinTD
JeffinTD's Avatar
Oddometer: 1,162
Yeah. From what I see there isn't too big a price difference between a high end net book, and a 10" or so laptop with much more processor power and an optical drive...
Once I get the USB charger and computer situation figured out, I need to think about a firearm, and maybe a Spot for the trip.
Old 03-23-2010, 02:56 PM   #81
bash3r
bash3r's Avatar
Oddometer: 1,596
Send a message via ICQ to bash3r Send a message via AIM to bash3r
Seems like someone in the know-how here in the States could make these little Powerlet to USB adapters and make a few bucks. The Cig plugs just don't stay connected very well.. a Powerlet to USB with about a 1.5' cord to run to a tank bag and charge up your Phone or Camera on the road would be sweet!!
08' Yamaha WR250R
08' Kawasaki Versys
My ADV Website
| ADV Legends
bash3r is offline   Reply With Quote
Old 03-25-2010, 12:54 AM   #82
kirkkw
Oddometer: 79
http://www.robobargains.com/mm5/merc...y_Code=ACC-013
kirkkw is offline   Reply With Quote
Old 03-25-2010, 02:56 AM   #83
rosscoact
need constant supervision
rosscoact's Avatar
Oddometer: 5,460
forgive my stupidity but if i bought one of those neat little surface mounted USB ports, how does the power get to them? they have 5 wire leads for data i assume
Stupidity got us into this mess, then why can't it get us out? Will Rogers
www.transaustraliatrail.com.au
rosscoact is offline   Reply With Quote
Old 03-25-2010, 04:10 AM   #84
Tee2
I SAID! Woo Hoo!
Oddometer: 915
Black is ground
Red is +5v
Green is pin 2
White is pin 3
Depending on what you are charging or just powering will depend on if you need to connect pins 2 and 3. My GPS just needed 5v on red and ground. But my Ipod needed power at pins 2 and 3. I don't have the voltage with me now but it was something like 1.8v or 2v.
Data - (D-) was 2 volts, and D+ was 2.75 volts
NOTICE that the pin numbers and colors may change if it is a male or female device. Just make sure you get the correct wire to pin.
What are you using to get your 5v?
Todd
Edited to add data voltage and notice.
Tee2 screwed with this post 03-25-2010 at 07:36 AM
Tee2 is offline   Reply With Quote
Old 03-25-2010, 04:54 AM   #85
rosscoact
rosscoact's Avatar
Oddometer: 5,460
Originally Posted by Tee2
Black is ground
Red is +5v
Green is pin 2
White is pin 3
Todd
I need to add a couple of chargers plus the GPS to the 690 so I thought a small fuse block would do the trick. The USB will charge blackberry and gopro
Old 03-25-2010, 07:32 AM   #86
Tee2
I SAID! Woo Hoo!
Oddometer: 915
Whatever you do don't put 12v into that USB plug. It needs a voltage regulator to get it down to 5 volts.
I checked my numbers for pin 2 (D-) is 2 volts, and pin 3 (D+) is 2.75 volts.
NOTICE that the pin numbers and colors may change if it is a male or female device. Just make sure you get the correct ones.
Todd
Old 03-25-2010, 08:32 AM   #87
FatChance
Road Captain
FatChance's Avatar
Oddometer: 9,312
Powerlet already makes them and they are referenced in this thread...
A little pricey, but they are a simple solution to the problem if you're not an electrical engineer and don't want to make your own.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 03-25-2010, 08:34 AM   #88
Motoriley
Motoriley's Avatar
Oddometer: 2,511
Powerlet to USB
Nice looking cable and only 45$...
A little pricey, but they are a simple solution to the problem.
Old 03-25-2010, 09:20 AM   #89
AngryScot
WeeBeastie
AngryScot's Avatar
Oddometer: 18,210
someone was too busy image linking to see the post already
some good info in here
⊕R1200GS⊕
⊕Zuma 125⊕
Save $5 on Smugmug "so9RUAXlMm0bE"
AngryScot is offline   Reply With Quote
Old 03-25-2010, 09:34 AM   #90
Motoriley
Motoriley's Avatar
Oddometer: 2,511
Usb
2 minutes apart.....great minds think alike...........
I picked up 2 more of the USB plugs from Canadian tire. I'm mailing one to bash3r and have one more if someone wants it. edit - second one is gone to msszq. Stick the plug of your choice on it and you are off and running. Here's mine with a Powerlet.
Motoriley screwed with this post 03-25-2010 at 02:05 PM
Times are GMT -7.   It's 03:55 AM.
