Old 03-25-2010, 10:00 AM   #91
Tee2
I SAID! Woo Hoo!
Oddometer: 1,276
Originally Posted by FatChance
Powerlet already makes them and they are referenced in this thread...
A little pricey, but they are a simple solution to the problem if you're not an electrical engineer and don't want to make your own.
And only want to charge something with a female mini USB. I think it would be more useful with a female USB A conection.
A little pricey? You know some of us ride KLRs.
Todd
Tee2 is offline   Reply With Quote
Old 03-25-2010, 10:07 AM   #92
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,686
Usb
I have had 2 KLRs so I'm really cheap!
Todd
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 03-25-2010, 01:59 PM   #93
rosscoact
need constant supervision
rosscoact's Avatar
Oddometer: 5,503
Whatever you do don't put 12v into that USB plug. It needs a voltage regulator to get it down to 5 volts.
I checked my numbers for pin 2 (D-) is 2 volts, and pin 3 (D+) is 2.75 volts.
NOTICE that the pin numbers and colors may change if it is a male or female device. Just make sure you get the correct ones.
Todd
I told you I was a numpty. It all sounds like a shop job to me so I better buy one off the shelf.
Cheers
Stupidity got us into this mess, then why can't it get us out? Will Rogers
www.transaustraliatrail.com.au
rosscoact is offline   Reply With Quote
Old 03-25-2010, 02:03 PM   #94
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,741
The one Motoriley made is what I'm looking for, this way I can charge my iPhone/iPod and camera or a non-Apple phone, like my Android phone, I can also emergency power up my GPS if I needed to say the circuit for my GPS went bad for some reason.. I'd still have instant power for it..
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 03-25-2010, 03:23 PM   #95
msszq
Oddometer: 13
try an adapter...
You can also consider getting something like this (http://www.buyextras.com/usbfetomib5f.html) to change the gender and type of the connection. I did attach the adapter it to a random mini usb wall charger and plugged my Delorme gps in. It had no problem receiving a charge, so hopefully that's a good sign it will also work on the bike. I'm planning to try it with one of the garmin hardwire cables on one of my bikes (much cheaper than the powerlett--$11 on overstock.com).
I'm buying the other USB cable that motoriley has to use on my dual sport bike since it gives me more flexibility with connecting & mounting.
Todd
msszq is offline   Reply With Quote
Old 03-25-2010, 09:05 PM   #96
JeffinTD
JeffinTD's Avatar
Oddometer: 1,404
Originally Posted by Motoriley
2 minutes apart.....great minds think alike...........
I picked up 2 more of the USB plugs from Canadian tire. I'm mailing one to bash3r and have one more if someone wants it. edit - second one is gone to msszq. Stick the plug of your choice on it and you are off and running. Here's mine with a Powerlet.
Wanna make some more of those? I'd sure take one.
09 R1200GSA
JeffinTD is offline   Reply With Quote
Old 03-26-2010, 12:11 AM   #97
GHO100
Crazy George
GHO100's Avatar
Oddometer: 1,095
For running inside a tank bag, I'll probably be getting something like this:
http://www.safehomeproducts.com/shp2...rce=GoogleBase
http://www.safehomeproducts.com/shp2...sion=75&text=Y
Not sure how long they'll work, but if it works at all, it'll be good enough for me. I use an HTC tilt with Garmin on it, so my cellphone and GPS are the same. Just need a way to power them while I ride, but having extra plugs open will be handy for the mp3 player as well.
2012 BMW R1200GS
www.NYMSTF.org - Support NY Riders!
GHO100 is offline   Reply With Quote
Old 03-26-2010, 04:44 AM   #98
Motoriley
Motoriley's Avatar
Oddometer: 2,686
Usb
I'm not making them but I have sent a few of the USB ends with bare wires stateside. If I find some more I'll let you know.
Old 03-26-2010, 08:29 AM   #99
JeffinTD
JeffinTD's Avatar
Oddometer: 1,404
Thanks.
09 R1200GSA
Old 03-26-2010, 06:31 PM   #100
worwig
Oddometer: 1,276
If anyone is interested in my 7805 regulator results. I've been using this setup for about 6 months now.
I mount my phone in this RAM finger grip mount.
On the back of the mount, I have a 1/8" thick, 2.5x3 inch aluminum plate, plus the aluminum RAM ball. The 7805 regulator is on the top (left side in the photo).
Here I have my phone running GPS software and the battery at about 50%. I connected the regulator to a 13.8 volt supply. The phone was taking close to 1 amp (about 900ma actually), to charge AND operate.
Using an IR thermometer, the aluminum plate started at 67F. About 10 minutes later it was at 126F. After another 10 minutes it was at 133F. Another 10 minutes and depending on where you measure it, it was still very close to 133F (and I have to head to work). That is VERY hot to the touch, though still safe for the 7805. I could get away with a little less heat sink I suppose, but I wouldn't want to go much less.
Hog mountain Weather
worwig is offline   Reply With Quote
Old 03-27-2010, 06:22 AM   #101
jkelly
Oddometer: 18
USB charger for 1.99 shipped with car199 code
http://www.cellularfactory.com/fulld...ci=1461&eng=dn
jkelly is offline   Reply With Quote
Old 04-08-2010, 07:16 AM   #102
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,741
Perfect!
Thanks Motoriley.. got mine working and think it will work great!
I posted up more photos and what I did to make the connections on my website here.
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Old 04-08-2010, 07:39 AM   #103
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,728
NIce Worwig,
Im thinking making the same set up for mine, I was considering 2 LM7805s wired in parrallell though to lighten the load on them.
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 04-08-2010, 08:01 AM   #104
the kaz
has become "FERAL"
the kaz's Avatar
Oddometer: 1,691
OK I am confused abit here
Does this Canadian tire plug convert 12v to 5v USB ? I dont see any transformer ? or is it hidden in the usb plug houseing ?
< spell cheqeur is bustimicated >
the kaz is offline   Reply With Quote
Old 04-08-2010, 12:25 PM   #105
Motoriley
Motoriley's Avatar
Oddometer: 2,686
USB on a bike
The transformer is in the plug so it does indeed convert 12 volt to 5 volt.
Times are GMT -7.   It's 01:10 AM.
