07-23-2009, 07:53 PM
#1 |
Wannabe Far-Rider
How to (almost) kill yourself with brake cleaner
http://www.brewracingframes.com/id75.htm
Be careful out there guys, especially those of you welding or other high heat type jobs on the bike.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time. 2008 Yamaha WR250X - 1998 Honda Nighthawk CB750 Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012 |
07-23-2009, 08:04 PM
#2 |
Cheated Anion
Oddometer: 4,540
Cant remember which, either r12 or r134 but when it burns it makes mustard gas.
07-23-2009, 08:34 PM
#3 |
new orange flavor
Oddometer: 1,058
I think its r22
-John
An Elefant never forgets. 2012 Baja 1000 www.Raceforthewounded.com Help us race the 1000, and double the value of your KLR by buying a t- shirt |
07-23-2009, 08:36 PM
#4 |
Old Enough To Know Better
Oddometer: 5,518
Good warning. I used to only worry about zinc fume sickness, but since I do use carb cleaner and brake cleaners to degrease stuff that I may later weld on, this is an eye opener.
Thanks for posting.
Mark J Merritt Island, FL When a person asks you for advice, they don't want advice. They want corroboration. |
07-23-2009, 09:05 PM
#5 | |
Oddometer: 1,571
but:Quote from and A/C training manual FAQ: They could also test for leaks before evacuating it by using an electronic "sniffer". In the past, a propane heated halide detector with an attached hose was used. Refrigerant would be sucked into the hose and cause the flame to turn bright green. This is mentioned for historical purposes only. Burning R-12 produces toxic phosgene gas and this old technique and equipment should no longer be used. Phosgene is bad too mustard is worse if it matters............
showkey screwed with this post 07-23-2009 at 09:10 PM |
07-23-2009, 09:58 PM
#6 |
Woolf Barnato
Oddometer: 29,149
Any chlorinated solvent is going to cause grief if combusted. Any chlorofluorocarbon or even hydrofluorocarbon. Any of the halogens deserve plenty of respect. Fluorine is the most reactive element on the periodic table. Anyhow, thanks for the article, I've got a few different chlorinated cleaners around and I have been fairly casual in their use.
'Gonna get me a six pack...push people off the highway!' "they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood." "I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!" "Yeah, that guy sure is terrible at touching moms" |
07-23-2009, 10:27 PM
#7 |
Oddometer: 16,052
Chemistry can be fun too.
But yes, vapor decomposition is definately something to watch out for. Even those cans of compressed "air" will react with other gases and mix into rather dangerous substances. Always always always always be careful when welding... know your surroundings, know who/what's around you (dogs, kids), know what you're welding and what's on the other side of the weld.... |
07-24-2009, 12:33 PM
#8 | |
Oddometer: 2,363
07-24-2009, 07:20 PM
#9 |
Oddometer: 5,518
Yep, I use that too. And denatured alcohol for some stuff.
My liver should glow in the dark by now from all the solvent stuff I used to expose my skin to back in the 70s in factories that never saw OSHA inspectors. Not to mention all the tax-paid ethanol it has metabolized Maybe it's true that what doesn't kill you only makes you stronger. Hopefully...
07-25-2009, 11:30 AM
#10 |
zipper suited sun god
Oddometer: 1,348
Holy crap this freaks me out. I expected to see some kind of ho hum yawn fire deal.
Good info thanks. |
07-25-2009, 06:50 PM
#11 |
Don't buy from Brad
Oddometer: 7,403
Good info to pass along.
This might merit being a sticky. At least a sticky saying "don't eat the toxic chemicals and here's why" or something. Safety's a tough thing to stay diligent on. Thank you for linking to it.
On tap:Nada Aging: 3 experiments in mead - blackberry, apple, and straight honey |
07-25-2009, 07:20 PM
#12 |
earthbound misfit, I
Oddometer: 6,597
I use this stuff a lot, but had no idea it could be this dangerous or how small of an amount could kill you.
07-25-2009, 07:30 PM
#13 |
Oddometer: 1,348
I used to work in the chemical industry, and I got to run preps with warnings from the chemists saying stuff like mutagen, teratogen, extra-head-ogen, stuff like that. One night a few of us started puking after work, no warning, just instant projectile vomitous. Another time all of us guys got a bad burning down there after a spill clean up.
Honestly, the stuff that really spooked me wasn't the really nasty stuff I dealt with occasionally like silanes and cyanides and stuff, but the day in and day out exposures to MTBE, acetone, THF, and other solvents that I sprayed around with wild abandon. I figure the MTBE (ether) is pretty much permanently stuck in my fatty tissues and I'll die of cancer someday. Kinda sucks. I should have known about this whole brake cleaner deal, or at least have a higher awareness level. This is a good reminder to be careful out there, wear your PPE and use a mask. Acetone is a big rip off. It costs about 70 cents a gallon in bulk, so when you buy some, bend over. Oh, and it will kill you too so wear gloves. Have fun... |
07-25-2009, 09:44 PM
#14 |
Oddometer: 265
i'm freaking out man.... good info to think about.
07-26-2009, 03:06 AM
#15 |
Ravening for delight
Oddometer: 8,645
Scary stuff, and in part an inevitable outcome of our profusion of warning labels. They sit there on everything you buy... "Wolf!" - Don't ride this bicycle without a light. "Wolf!" - Licking the inside of this light socket could really hurt you. "Wolf!" - The state of California has decided that you'd better know there is a bit of lead in this wire's insulation. "Wolf!" - Sharp edges can hurt your wittle finger. "Wolf!" - Inhaling smoke may lead to long term health effects. "Wolf!" - If you apply a little heat to just a tiny bit of this stuff you will be killed. Whoops, that one SHOULD have a warning label, but I ignored it as I am now wont to do.
Why did I drink all of the ingredients for vomit? "Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar "you cannot reason a person out of something they were not reasoned into." - Jonathan Swift |
