Old 07-25-2009, 04:08 PM   #1
ReactorTrip OP
glows in the dark
ReactorTrip's Avatar
Oddometer: 557
BMW Zumo 550 map loading failure
I just bought a used BMW Zumo and updated the firmware, which was successful. I tried updating the maps from the 08 maps to the 2010 maps and it quits after 73% and says something about network failure. I didn't back up the garmin which was a big mistake, now I can't even enter addresses with it because it didn't get that far in the loading of the maps.
Anyone run into this before?
I tried asking on zumo forums with no response.
ReactorTrip is offline   Reply With Quote
Old 07-25-2009, 11:46 PM   #2
Ducman69
Ducman69's Avatar
Oddometer: 343
Even if your GPS is out of warranty, the maps are not. Garmin support is actually very good. The hold time is stupid, but you won't get a guy reading off a script in pakistan, no worries. Put em on speakerphone while doing something else, and they'll get you fixed I promise.
Ducman69 is offline   Reply With Quote
Old 07-26-2009, 01:11 PM   #3
JR356
JR356's Avatar
Oddometer: 3,937
Try running the map update again.
JR356
JR356 is offline   Reply With Quote
Old 07-26-2009, 01:20 PM   #4
ggrjr
ggrjr's Avatar
Oddometer: 965
I bought the upfrades for mine, first attempt to upload, came up with note sying it was registered to some one else (Warranty replacment with refurbed unit). emailed tech and they canceled existing registration, so I could proceed.
Did you upgrade the firmware before proceeding?
"If you are arguing with a fool, make sure they are not doing the same."
2005 DL 1000
93 VFR
ggrjr is offline   Reply With Quote
Old 07-26-2009, 01:35 PM   #5
ReactorTrip OP
glows in the dark
Oddometer: 557
firmware has been upgraded successfully. I have tried uploading the maps 3 times. All failures at 73%. Redownloaded the map .exe and tried again twice. Both failures at 73%. Makes me think it is some kind of timeout error or my device is out of memory. The device shows over 300 meg still available, so it doesn't look like that.
Old 07-26-2009, 02:05 PM   #6
ggrjr
ggrjr's Avatar
Oddometer: 965
ay be a time out error with yor ISP, or memory issue with your copmputer. Is teh error, during downloading maps to your computer, or during down load to Zumo?
2005 DL 1000
93 VFR
Old 07-26-2009, 04:05 PM   #7
ReactorTrip OP
glows in the dark
Oddometer: 557
upload to Zumo
been sending emails back and forth with Garmin, I've downloaded the file several times and tried several things when extracting/building/uploading to Garmin. They are confused. They told me to call them when they open in the morning. Think it will be shipped off for fixin.
Old 07-26-2009, 04:09 PM   #8
ggrjr
ggrjr's Avatar
Oddometer: 965
Good Luck. I have had excellent results with Garmin tech support.
2005 DL 1000
93 VFR
Old 07-26-2009, 05:39 PM   #9
ReactorTrip OP
glows in the dark
Oddometer: 557
Apparently I am not alone.
http://www.gpsmagazine.com/comments/000534.php#comments
Looks like some people have had success downloading it through IE and finding .img extracted file in the temp directory and manually uploading it to the GPS. I am going to try that. Can't call garmin til tomorrow though.
I don't understand why they take a 1.02 GB img file and make it a 1.9 GB .exe. No reason for that....
Old 07-27-2009, 07:51 AM   #10
ReactorTrip OP
glows in the dark
Oddometer: 557
Tried the above, no worky.
Brought it to work and tried the same thing I had been doing since the beginning and it worked. Go figure.... Solution to this problem is try another computer. Whats weird is my computer at home is free of a lot of bugs and issues and various other crap IT run computers are filled with and it is also a ton newer and faster, yet the crappy work computer won the day. LOL!
Times are GMT -7.   It's 05:31 PM.
