Thread Tools Rating: Thread Rating: 118 votes, 5.00 average. Display Modes
Old 08-26-2009, 08:51 AM   #151
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
Originally Posted by Jhon
At only 40k miles it should all be OK.
An issue that can affect the TD5 engine is oil travelling through the injection wire harness and contaminating the ECU unit. This causes the engine to misfire and necessitates changing out the wiring loom.
The good news is that on the Defender the loom is longer (than the Disco f'r instance), so it shouldn't be a problem until a much higher mileage.
Injectors are very expensive (>£350 each) - as long as it starts and runs OK, no excessive smoke or noise from the turbo it should be fine.
Exhaust manifolds can be weak on them as well, particularly if they've been chipped. Look for broken studs or signs of blow-by.
Check the condition of the oil and fluids and budget for changing them all if necessary. If you get a LR dealer to do the service, it will be very expensive.
Usual things - wear an old overall, get underneath it, check for off-road damage, play in the propshafts, leaks from gearboxes/diffs, etc.
Oh and check low-box works fine, sometimes it can get sticky if not used regularly.
You're a star! Any suggestions on how to check the wiring loom or are you saying that at 40k I shouldn't need to worry?
And Nick - you're a git!
Mav
All the gear.. no idea!
Mav is offline   Reply With Quote
Old 08-26-2009, 09:10 AM   #152
Bonsai Elephant
Bonsai Elephant's Avatar
Oddometer: 18,756
No, I mean it, good luck, it sounds like a good buy if it's at a good price, but I don't know enough about landies to advise, I just like driving them!
Bonsai Elephant is offline   Reply With Quote
Old 08-26-2009, 09:15 AM   #153
Jhon
Oddometer: 3,004
If the mileage is genuine (check service records/old MOT's), you shouldn't need to worry about the wiring harness issue. It happened at about 70k on my Disco.
If you want to confirm, pull the plug off the ECU unit and have a look. (I think it's in the seatbox under the passenger seat on the Defender.) If there's oil present on the pins it's not the end of the world, but will cost several hundred to fix.
Jhon is offline   Reply With Quote
Old 08-27-2009, 02:24 PM   #154
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,012
... with pto driven front winch AND rear PTO for the powered trailer !!
http://www.offroad-forum.de/viewtopic.php?t=31908
Never stop exploring
Doc.Snyder is offline   Reply With Quote
Old 09-27-2009, 05:14 PM   #155
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
So I managed to get a couple hours off today so went to see some Landies playing
Lots more to come
Mav
Old 09-27-2009, 05:32 PM   #156
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,168
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 09-27-2009, 05:41 PM   #157
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
There were some classics there:
Although some were actually getting dirty
Mav
Old 09-27-2009, 05:47 PM   #158
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
Check out this old Lightweight:
About to climb a pretty nasty ascent... doesn't look so bad...
Turns out it needed some gas (Not exactly original suspension )
Looking a bit muddy now
Mav
Old 09-28-2009, 12:28 AM   #159
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
How about some lift...
Mav
Old 09-28-2009, 08:28 AM   #160
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
What about one for serious overlanding
Mav
Old 09-29-2009, 02:03 PM   #161
WIBO
Will it buff out?
WIBO's Avatar
Oddometer: 3,723
The Suit:What would you consider to be your greatest weakness?
Me: Honesty.
The Suit: Honesty? I don't think honesty could be construed as a weakness.
Me: I don't give a fuck what you think.
WIBO is offline   Reply With Quote
Old 10-07-2009, 10:25 AM   #162
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
So I've finally bought one!!! I don't get to pick it up for about 10 days
In the meantime, I shall have to make do with plenty more pics and videos
How about some serious articulation:
Mav
Old 10-07-2009, 10:50 AM   #163
neanderthal
globeriding wannabe
neanderthal's Avatar
Oddometer: 1,890
Nice. Congrats man.
That IS some serious articulation.
'O=00=O'
BMW 2002. long live the legend
neanderthal is offline   Reply With Quote
Old 10-07-2009, 10:51 AM   #164
neanderthal
globeriding wannabe
Oddometer: 1,890
Sex. On. Wheels.
Just paint it an olive green or desert beige and i'm set.
'O=00=O'
Old 10-09-2009, 05:37 AM   #165
damoace
PinderBuilt
damoace's Avatar
Oddometer: 802
Nice Roofrack but his fairlead wont last long if he keeps stuffing into the drit like that... Overall though, nice truck..
If you can't say anything positive, don't say anything.
WWW.BMRIDER.COM
damoace is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 04:11 AM.
