10-24-2009, 09:28 AM
#256 | |
BOOMSHANKA!
Oddometer: 3,570
Now, personally... on an early 90 rim (many series rigs have this size on them too) of 16 x 5.5" (9" wide) I really like the 235/85R16 size for a 90/110/Series. Even on the wider width rims, this size is really great for more stock trucks with no additional lift. I've not run 255/85R16 sized tires on a 5.5" rim, but have heard of guys doing this... I don't think I would though. That's just a bit narrow... this becomes an issue when you start airing down to low psi for rough work... bead blowing can be a problem. I do like the 255/85 size over the 265/75 size. The 255/85 is 33.1" tall and 10" wide. The 265/75 is 31.6" tall and 10.4" wide. I know this doesn't sound like anything, but... there is a difference... not enough to sway me from buying the 265/75 for a deal though. Tall and narrow... the best combo in my opinion. There is a good reason why the military uses tall/narrow over just say... BIG ASS TIRES... because pizza cutter tires work. I think if you could score those AL Rover rims (and they're probably 7" wide) with the 265/75 BFGs for a deal... do it... be sure to get the AL lug nuts to go with them. I think your idea of keeping the steels around for tossing on some MT tires sound like a good one. That said, I've run BFG AT tires and BFG MT tires (235/85R16) on the same series rig... I got the same mileage out of both of them... and that was dual duty work of street/trail. I kept them at 33 psi for a proper footprint and they got even wear to the end. For that reason, I'm not keeping extra rims/tires around... plus... it's hard to find a place to store all that gear!![]() Something else... on RR classics and Disco rigs with a minor lift (like the 2" lift given by Old Man Emu springs)... I really like the 215/85R16 size. These are 30.4" tall and 8.5" wide. I know many folks run the 235/85R16 size once they lift their RR or Disco, but they usually get that rubbing at the back wheel arch area. Some guys even trim that area. No thanks... not me. The other thing that goes into this equation is tossing on full chains, these are legal here in the state of WA for me, for deep snow work. Those 235 tires with chains will do damage to the truck (unless the truck has been modified or lifted for that additional clearance). I know the 235 is only an inch taller and wider, but the wheel arches on the RR and Disco are tight... that one inch tall/wide finds those tighter spots and... shall we say... removes the lesser strength materials under full articulation. Most of the time it's the brand new rubber knobs on those tires... don't ask me how I know this! So, and what the hell... I've gone and drawn this out yet again, I'd say get some proper AT or MT tires for a deal if you can. If they come with Rims... run 'em on those. If not, and the tire size is over 10" wide, run them on a steel rim over that 5.5" size. Oh... and some older steels still run tubes in them. I'm not a fan, but some expedition guys like them better than tubeless. I like tubeless rims, but I have run tubeless tires on tubed rims before... probable not a good idea as the tubeless designed rim has a proper "lip" for keeping the bead of a tubeless tire locked on better. I ran them on my old '62 stock Series IIA and never did experience air leaking past so I soon forgot about the issue. Either way... I'm extremely envious of your 110 MAV! Even if it had no rims/tires... and was sitting on breeze blocks!
~Michael (of The Land of Misfit Land Rovers) Used to have an Africa Twin and Transalp X-Files Gov't Issue Sprinter TurboDiesel ![]() Washougal, WA USA |
10-24-2009, 09:31 AM
#257 |
Broken Hearted
Oddometer: 9,543
Hey Modrover/ Rover guys:
'99 is disco II, yeah? Or is it the tail end of I? This looks like it's worth a look: http://portland.craigslist.org/clk/cto/1433869091.html Agreed? |
10-24-2009, 09:44 AM
#258 | |
BOOMSHANKA!
Oddometer: 3,570
The 1999 was the first year for the US Disco II. I like the older Disco I rigs for more basic equipment, but that wouldn't turn me off to the Disco II completely... especially if there was a deal to be had. Be sure to ask for the full service history... maybe some Disco II owners here can shed some light on growing old with the series II Disco. I just have never owned one so can't give my blessing on it. That said, I'm still a less is more kind of guy so take that with a grain of salt mate!
10-24-2009, 05:35 PM
#259 |
Oddometer: 2,012
LR rims, safe combinations:
5.5 R 16 > 7.5 R16, 235/85 R16 6.5 R16 > 7.5 R16, 8.25 R16, 9.00 R16, 235/85 R16, 255/85R16, 265/75 R16 There are 'closed' 6.5 rims from the early 130 Defenders and the 127 LR(not recommended for use w. disc brakes, especially rear. Needs more clearance, ie. Wheelspacers), 'open' 6.5 tubed rims (130 Defender) and 'open' 6.5 tubeless rims (130 Defender & LR Wolf / TUL, TUM / XD) Which size steel Rims did the NAS spec Defenders have?
Never stop exploring |
10-24-2009, 05:47 PM
#260 | |
Once you go Triple...
Oddometer: 20,490
I also doubt German military would be armed outside the confines of the embassy
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
10-24-2009, 07:23 PM
#261 |
Oddometer: 2,012
Yeah, those are italian Defenders.
The only LR The Bundeswehr uses is this one and a civil looking version for Range Control. The German Border Guards use LR Discovery2, though. The Bundeswehr calls those Vehicles 'hümS'. Stock vehicles w. special mil. upgrades. ![]() ![]() ![]() ![]() ![]()
10-25-2009, 09:53 AM
#262 | |
BOOMSHANKA!
Oddometer: 3,570
ANR1534 6 1/2 X 16 X 20,6
10-25-2009, 10:11 AM
#263 |
Oddometer: 2,012
Ok. Those are the non vented, riveted 127 / early 130 rims. Thanks!
10-25-2009, 05:05 PM
#264 |
Prêt? Allez!
Oddometer: 9,773
Isn't Prince Philip Rather Tall??!!
Just for shits and giggles I went and drove a '93 County Range Rover LWB today. It surely is built like a bank vault...very solid and very impressive. Had the spring/shock conversion, and it handled beautifully on slightly oversize tyres.
The thing is, I'm not a great gangling tall fellow, I'm only 6-1 but with a rather long torso...but DAMN I couldn't sit upright in the thing! I put the seat in its lowest position and STILL had to crane my neck sideways to drive! I was really flabbergasted by this. I haven't driven a car with such poor headroom since the inlaws' old MGB convertible. Is this something that people just don't talk about? Is it Rover's awful secret? Did the owner of this car secretly have a phone book hidden in the seat cushion? Inquiring minds want to know.
Hey mec, ne chie pas dans mes cornflakes. Be kind whenever possible. It is always possible. -the Dalai Lama |
10-25-2009, 07:54 PM
#265 |
Jellyfish Proctologist
Oddometer: 1,953
10-25-2009, 08:35 PM
#266 | |
Having said that, I got used to it after the first couple days of ownership and no longer even notice the lack of headroom.
'03 KTM 625 SXC | '07 Moto Guzzi Breva 1100 |
10-26-2009, 06:40 AM
#267 | |
BOOMSHANKA!
Oddometer: 3,570
This reminds me... an article of the release of the Disco some time ago. Talked about the Rover group addressing many complaints about the RR with that model. Additional seating, easier access to gear (one big door as opposed to liftgate/tailgate... folks didn't like getting their moleskin slacks dirty when trying to load items in/out of the back ), more internal storage (by getting that spare out of the back storage area and outside on the rear door), and it was mentioned... more head room overall. My '96 Disco SD has more headroom than our old '88 RR (both have moon roofs), but about the same headroom as our old '81 2-door RR. My guess then... if you need the additional headroom... get a Disco without the moon roofs and you'll have that 10 gallon hat clearance... well... maybe not quite that.
10-26-2009, 07:03 AM
#268 | |
Der geizige Schwabe
10-26-2009, 07:24 AM
#269 | |
Oddometer: 20,490
Please feel free to start your own G-Wagen thread
10-26-2009, 07:58 AM
#270 | |
Oddometer: 2,012
KSK: ![]() ![]() Heer:
| Thread Tools | |
