11-28-2009, 04:01 AM
#376 | |
Something witty...
Oddometer: 3,612
![]() I really need a smaller house and a bigger garage!!
Mav ------------------------- All the gear.. no idea! |
11-28-2009, 12:23 PM
#377 | |
Oddometer: 11
One life. Live it. 1995 Land Rover Discovery 1962 Land Rover Series IIa Bike: ? |
11-28-2009, 12:58 PM
#378 | |
BOOMSHANKA!
Oddometer: 3,570
So, yes... I enjoy carbs. for their simplistic values. I do think I've reached that point in my life... that point when EFI is actually easier to live with day to day. Plus, they are better at altitude changes and really off camber situations. I've had my carbs. get a little "funny" during some higher altitude off-road angle stuff. They stayed running with some blurps of the pedal at key moments! The only thoughts that have been really giving me some trouble... and what I was on about with all that carbs. vs EFI stuff... the carbs. have never let me down. I've always been one to upgrade or modify based on my own personal experiences. Changing to EFI will be the first time I just do some mod like this... because I'd like better mpg and such things... and not because I've had a failure. It's not that big a deal really... I can change back to carbs. later if the EFI starts to become troublesome. So, the wife gave you the yellow light eh? Better get a good Disco before the snows hit the valley areas. Remember last year? Usually just a couple dusts of snow at my 250 foot elevation... I had 4 foot drifts with 2.5 overall depths last year during that storm! Oh... and that's when the furnace decided to pack it up too!!! Ahhh... good times
~Michael (of The Land of Misfit Land Rovers) Used to have an Africa Twin and Transalp X-Files Gov't Issue Sprinter TurboDiesel ![]() Washougal, WA USA |
11-28-2009, 01:06 PM
#379 | |
BOOMSHANKA!
Oddometer: 3,570
Ha... good luck with the clutch. These rigs have a lot of room to work so... you should have no problems. They are very straight forward in that regard. I understand having to get things done as it's used as the family truckster... me too. I must complete things to the Disco in a more timely fashion! I'll try to get some photos of the motor in various stages... they're not real impressive until you start offering up those rebuilt shinny bits though! Hey, you've got the tdi right? What year is your Discovery?
11-28-2009, 04:41 PM
#380 |
Oddometer: 2,011
...For example, the LR4 doesn't utilize a classic oil plug in the bottom of the oil pan as does almost every car and truck. The only way to change the oil in an LR4 is to have a Land Rover Dealership use a special device to "vacuum" the oil out of the engine.
W T F ???
Never stop exploring |
11-28-2009, 04:43 PM
#381 |
Something witty...
Oddometer: 3,612
You tak about getting things done quickly... I got around to removing the sidesteps today. It ook well over an hour... for 12 bolts!!! And four of them were straightforward! Maybe I should've let the trail take them off
11-28-2009, 04:51 PM
#382 | |
Something witty...
Oddometer: 3,612
11-28-2009, 09:38 PM
#383 | |
Oddometer: 11
11-29-2009, 01:52 AM
#384 |
Something witty...
Oddometer: 3,612
That doesn't bode well for the required defender replacement due in the next couple years
11-29-2009, 02:52 AM
#385 | |
Dances with spaniels
Oddometer: 1,754
- I can't believe the above. I have had 2 1/4 petrol, 2 1/4 diesel, TDi & TD5 and all had sump drain plugs. Even if it was true for some obscure type of LR product then you can be sure there is an after market fix for it. |
11-29-2009, 09:19 AM
#386 |
Oddometer: 2,011
I was looking for some info about the updated LR3 (LR4), and I found this on Wikipedia... unbelievable. The LR4 is still a very, very capable offroader, but this missing oil drain plug is ...
But on the other hand they say, that for the LR4, the new V8 has been slightly modified with a deeper oil sump to provide engine lubrication while the vehicle is operating under severe tilting angles when off-roading. In addition, a mechanical cooling fan has been added and various components, including the alternator, power-steering pump and starter motor, have been waterproofed. Somebody will come up with a solution for this. Oil drain plug issue, I'm sure.
12-02-2009, 07:16 AM
#387 | |
BOOMSHANKA!
Oddometer: 3,570
Nothing speaks more to auto co. than keeping your money in your own pocket
12-02-2009, 07:21 AM
#388 | |
BOOMSHANKA!
Oddometer: 3,570
yeah, sometimes I feel... Land Rover manuals should state, on the very first page, "when you're about to attempt something... be sure to allow 3 times the amount of time to get it done." Good on ya for dumping the steps. I removed my sills and fabricated some really solid rock sliders to my '65 IIA beasty. Not only do they provide gobs of protection off-road (and allow for a hi-lift jack point)... they also provide side impact protection on the street. You know, it the event some dipstick t-bones you!
12-02-2009, 10:55 AM
#389 | |
Radical centrist
Oddometer: 21,269
I had a turbocharged Peugeot from the 80's and it was the same way. Actually suctioning oil isn't that uncommon. It's a technique used in big boats for years. I had a rig that I tried to use with my motorhome (6V92 Detroit) but it didn't work worth a damn so I gave it up in favor of taking the motorhome to truck stops every so often. What intrigues me more about Land Rover maintenance is that I just discovered that to replace the spark plugs and plug wiring on my 2003 Disco II requires the removal of the intake. I'm looking at a $500 bill for having a mechanic do what I used to do myself on my other autos.
PirateJohn -- http://www.PirateJohn.com IBA #7552 - SS1K in 2000 and 50CC in 2002 In the Laredo, TX area and always willing to help travelers escaping into Mexico.
12-02-2009, 11:06 AM
#390 | |
dude
Oddometer: 1,589
service.The truck does NOT need to be lifted in the air so they pay LESS...
dude on a bike... Be who you are and say how you feel because those who mind don't matter and those who matter don't mind~ Dr. Seuss Much of life is simply timing or luck.~Zerk |
| Thread Tools | |
