Thread Tools Rating: Thread Rating: 121 votes, 5.00 average. Display Modes
Old 07-14-2010, 02:01 PM   #676
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
Originally Posted by Bonsai Elephant
How the bourgeoisie live!
So bourgeois that I will be renting one rather than buying
Mav
All the gear.. no idea!
Mav is offline   Reply With Quote
Old 07-14-2010, 03:21 PM   #677
Jhon
Oddometer: 3,025
Originally Posted by Doc.Snyder
Tibus
http://killeraxles.com/
one portal box is around 1300 EUR.
It's a lot of money for an extra 3-4" of ground clearance. If I had the money to spare I'd do it (and a pair of ARB lockers) just for the sake of having the ultimate Land Rover.
Sadly, I'm unlikely ever to be in that position. Nice to know they're there though, and to dream.
Jhon is offline   Reply With Quote
Old 07-14-2010, 03:23 PM   #678
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
What does it do to the road handling?
Mav
Old 07-14-2010, 03:41 PM   #679
Jhon
Oddometer: 3,025
Not sure, I've never driven one on road.
One of my local club members fitted Unimog axles. The downsides are much higher unsprung mass which affects suspension and ultimately handling. This is unlikely to be such an issue with the Tibus bolt-on units which would be much lighter than the 'mog axles. The CofG would go up too, which would have an effect - this might be offset by the slightly wider track. I'll ask him next time I see him - I know that he sold the vehicle not long after building it. I think the reality was different from what he imagined.
I can't see that there would be any advantages to them for road use - apart from being able to see over the top of Transits.
Old 07-14-2010, 03:50 PM   #680
wayno
wayno's Avatar
Oddometer: 6,769
From what I know they are Air activated so run like an open diff until activated with switch in cab..
RIDE SAFE
wayno is online now   Reply With Quote
Old 07-14-2010, 03:57 PM   #681
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,012
These Defenders have additional Air Lockers in the front and rear axle. That would make 3 lockable diffs. Front, Center and Rear.
From what I've read in their Thread on www.offraod-forum.de , the Top speed is a bit lower, but you can compensate with bigger tires. But bigger tires put more stress on the drivetrain,... So it depends what you do with it.
Handling is not much different. Of course it is a bit higher, but at the same time a bit wider.
The guy in the white 130 uses it as a Press vehicle for rallies like Berlin Breslau or the trans Siberia challenge.
Never stop exploring
Doc.Snyder is offline   Reply With Quote
Old 07-14-2010, 04:16 PM   #682
wayno
wayno's Avatar
Oddometer: 6,769
The air locker its self doesnt change speed in any way except when activated....what changes is people usually change gear ratios when they do the locker. Taller tires decrease final gear ratio and sometime are a negative factor after a certain point.
RIDE SAFE
Old 07-14-2010, 05:07 PM   #683
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,012
I know that. LOL.
I first thought you referred to the portals in your previous post (From what I know they are Air activated so run like an open diff until activated with switch in cab..). Hehehhh.
I think Mav wanted to know what the Portals do to the road handling. not what the lockers do to it.
Old 07-14-2010, 07:48 PM   #684
wayno
wayno's Avatar
Oddometer: 6,769
I know that. LOL.
Ok LOL
RIDE SAFE
Old 07-14-2010, 11:43 PM   #685
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
I know that. LOL.
That's right - I wanted to know what it does to road handling. I'm not looking to make my Landy some kind of car... but I do still want to be able to cover long distances rather than make it a challenge truck! And it seems to me that these lift kits everyone goes for don't really help that much... articulation and axle clearance would seem to be the main things that will make a difference. That and lockers...
Mav
Old 07-15-2010, 01:57 AM   #686
Jhon
Oddometer: 3,025
Unless you're planning a jungle expedition somewhere like Borneo, you're unlikely ever to need the extra clearance from portal axles.
Think about it - the majority of guys who do extreme winch challenges or rock-climbing in the US don't have portal axles. None of the Camel Trophy vehicles were ever fitted with them.
If you want to maximise your ground clearance go to something like a 35" tyre and adjust your diff gearing to suit.
That, combined with good suspension (Old Man Emu is recommended) and a rear locker (ARB are very good) will take you pretty much anywhere a road-legal wheeled vehicle will go.
If it's primarily long distance with some off-roading leave the Land-Rover standard. A couple of waffle boards, a Hi-lift jack and a tirfor winch will get you through pretty much anything. It will be more pleasant to drive and will be reliable and easily fixed if something does break.
Old 07-15-2010, 02:03 AM   #687
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,713
This is pretty much what I had in mind for our trip to Africa in a few weeks... the portals just attracted because I'm a sucker for bling
Interesting that you didn't suggest a mounted winch... I've long held the suspicion that unless you go front and back... with a mounted winch you're just as likely to get stuck and in fact might go places you shouldn't go, because you thought your winch would get you out!
Mav
Old 07-15-2010, 02:14 AM   #688
Jhon
Oddometer: 3,025
Yeah, I'm a sucker for bling too, that's why I love the idea of portals.
Vehicle mounted winches have their advantages but also add weight and complexity, not cheap either. Also you need power to run them, not handy if your vehicle battery is flat or the motor won't run.
If you have a tirfor you can pull the vehicle from any angle and right it in the event of a roll-over. Also, you can transfer it easily between vehicles.
Tirfors can be hard work - but then again knowing you've got to go through all that hassle, you make damn sure that you don't get stuck in the first place.
Old 07-17-2010, 11:37 AM   #689
Motojournalism
motojournalism.com
Motojournalism's Avatar
Oddometer: 1,665
More LR lust
Some fine specimens in Guatemala
Way out West-0214
Way out West-0210
Way out West-0211-2
Way out West-1290442
Way out West-1290579
And a quick glimpse in Costa Rica
Way out West-1310449
"Absorb what is useful, Discard what is useless, Add what is uniquely your own" - Bruce Lee
Motorcycle Travel Photography tips at motojournalism.com
Way Out West - Canada to the Darien Gap
Follow me on Twitter
Motojournalism is offline   Reply With Quote
Old 07-18-2010, 09:36 PM   #690
sandgroper
sandgroper's Avatar
Oddometer: 4,802
That i like, hard to get in OZ
Like my GS red goes faster
sandgroper is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:40 AM.
