Old 08-21-2009, 08:31 AM   #106
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,011
The 2.8l tgv International 4cyl engine is the best diesel engine for a Defender. That's right. It's essentially the same as the 300tdi, but with a bit more displacement and another turbocharger.
I exchanged my 300tdi for the 2.8l version. Best mod ever.! Also I removed the external Rollcage, removed the spare tire from the hood, exchanged the roof with a 110 Station roof (w. alpine windows & Sunroof), added the mantec snorkle, the mil. arctic snow cover for the heater intake, 6.5x16" LR Wolf Rims w. 265/75R16 Cooper Discoverer STT, additional Gastank, Rocksliders, NATO tow hook, NATO rear bumpers, LR Light guards, LR Safari aux. Lights. RECARO Seats, complete rubber floor front, standard LR A/C. Black front undercarriage protection (blend in really good :-) )
Never stop exploring
Doc.Snyder screwed with this post 08-21-2009 at 08:38 AM
Doc.Snyder is offline   Reply With Quote
Old 08-21-2009, 08:40 AM   #107
svs
All Hands on Deck!
svs's Avatar
Oddometer: 20,704
Way to go DOC!!!!
What is this Green Energy we are looking for?
"Self Replicating Carbon Sequestering Bio-Nano Technology"................TREES are the Answer!
svs is online now   Reply With Quote
Old 08-21-2009, 08:49 AM   #108
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 20,424
Very very nice Doc
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 08-21-2009, 08:49 AM   #109
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,011
I had to sell it when I moved to the US
Old 08-21-2009, 08:55 AM   #110
PaleRider
gelande/strasse
PaleRider's Avatar
Oddometer: 9,980
... hey Doc, way cool!
... what is the little black mod on the right front fender?
One Life. Live It.
PaleRider is offline   Reply With Quote
Old 08-21-2009, 09:06 AM   #111
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,011
That's the arctic snow cover from the mil. spec Defender. It covers the Air Intake of the Heater, so it still can suck in Air when covered with snow (or mud ).
One detail I forgot to mention is the flip cover below the speedo. Also from the mil spec Defender. It covers the warning lights. useful when driving at night w. lights off (hunting)
Old 08-21-2009, 09:45 AM   #112
Blair
Blair's Avatar
Oddometer: 689
Nice 110. What transmission did you have hooked to the 2.8? That motor looks to ne a great option for my 110. I just need to figure out how to get one.
Originally Posted by Doc.Snyder
tengo un cohete en el pantalon!
Blair is offline   Reply With Quote
Old 08-21-2009, 10:08 AM   #113
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,011
That's the standard transmission. R380 + LT230
It's an international engine (navistar)
http://www.mwm-international.com.br/...ies&idSerie=44
There's also a 3liter available, but it's diffucult to use for a Defender:
http://www.mwm-international.com.br/...=23&idLinha=12
Old 08-21-2009, 10:41 AM   #114
Blair
Blair's Avatar
Oddometer: 689
No adapter between the transmission and motor? I really would like to find a couple of those. I have a 5 speed disco that could use one as well.
Blair
Old 08-21-2009, 11:33 AM   #115
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,011
Oh, wait... there was an adapter kit, but it was included with the engine...
Can I fit the new HS 2.8L TGV engine in place of the ‘300’ Tdi without any conversion parts?
No! The engine differs in several ways,
1. Not all the engine mounting M12 holes are not drilled and tapped in the cylinder block. We drill and tap these with a special jig before the engines leave our works.
2. The rear end of the crankshaft is different. We supply a special crankshaft adapter and bush in the kit.
3. The engine oil filter arrangement is different. The oil filter is mounted further back and fouls the standard RH Tdi engine mounting bracket. A special 90° oil filter adapter is supplied in the kit to miss the bracket. The oil filter block also mounts the lubricating oil cooler (Modine type). The radiator engine oil cooler is not used but we do offer a remote oil cooler adaption Kit 160 which is part of the ‘200’ Tdi Discovery Kit 156 due to the RH engine mounting bracket fouling the standard Modine oil cooler.
4. The turbocharger has different exhaust and compressor connections and the inlet manifold is different. All our kits have inter-cooler pipes & hoses and exhaust pipes to suit the new 2.8 engine.
5. The dipstick tube on the HS 2.8 lubricating oil sump would foul the front propshaft. We weld a special tube to the sump before the engine leaves our works.
Our conversion Kit 154 for Defender and Kit 151 for Discovery ‘300’ Tdi include all the necessary parts to fit the new HS 2.8L TGV engine to these models.
http://www.mdengineering.co.uk/index.php?act=faq
http://www.mdengineering.co.uk/index...egory&cat_id=1
Old 08-21-2009, 04:56 PM   #116
desert dog
scrub basher
desert dog's Avatar
Oddometer: 979
Thumb defender 110
sorry didn't get back to you guy's, slow day !!!
here's a photo of under the bonnet (hood)
yep - needs a clean !!!
will get them spec's.........................soon !!!
cheers matty
spot the landy !!!
desert dog is offline   Reply With Quote
Old 08-22-2009, 04:07 PM   #117
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,612
So what about the V8 Defenders?
What do you guys think of the V8 defenders? I found an older but low mileage (50k) V8 110. I don't do many miles and even with the odd trip, it shouldn't be more that 5k a year so maybe I won't mind about the fuel consumption... just how bad is it? And what about the reliability?
On the plus side... there is that sound
For example:
Mav
All the gear.. no idea!
Mav is offline   Reply With Quote
Old 08-23-2009, 12:37 AM   #118
Bonsai Elephant
Barrus Vegrandis
Bonsai Elephant's Avatar
Oddometer: 17,719
Send a message via MSN to Bonsai Elephant
For example:
Do you really need to ask?
Veni, vidi, velcri.
Bonsai Elephant is offline   Reply With Quote
Old 08-23-2009, 01:25 AM   #119
Lewy
Minus the LC8
Lewy's Avatar
Oddometer: 1,832
Cool Landy thread.
I sold my 1985 110 last year after 10 years.
I loved the V8 sound
And to fight the itch of buying another, I have made a mini one.
&nbsp
&nbsp
Lewy screwed with this post 08-23-2009 at 01:32 AM
Lewy is offline   Reply With Quote
Old 08-23-2009, 08:51 AM   #120
Mav OP
Something witty...
Mav's Avatar
Oddometer: 3,612
Here's a pic of the landy in question:
Seriously thinking I need to get some time off work to go see it
Mav
Thread Tools
Times are GMT -7.   It's 10:25 AM.
