08-23-2009, 09:44 AM
#121 | |
more north, more wet
Oddometer: 3,675
Hotness. That V8 will hurt your wallet. Figure around 10-12 mpg.
2006 KTM 950 Adventure "The pen & sword, in accord." "It's never over in a Rover." |
08-23-2009, 10:03 AM
#122 | |
Something witty...
Oddometer: 3,612
![]() What's the deal with some people suggesting the V8 isn't as good in water compared to the diesel?
Mav ------------------------- All the gear.. no idea! |
08-23-2009, 10:38 AM
#123 | |
Oddometer: 3,675
I can't imagine owning a V8 in Europe unless I was super rich or something. You tell yourself: "Oh, I won't drive it very much. That'll keep the cost low!" Problem is, they're so cool and fun to drive and you end up driving it way more than you originally intended. ![]() I've never heard the V8 vs diesel water comparison... Air intake height should be the only real issue? Maybe the V8 is a heavier motor? Anyway, fuel consumption aside, looks like an awesome truck. You Brits are very lucky to have those things on every street corner -- they're becoming increasingly rare in the States.
08-23-2009, 12:53 PM
#124 | |
Oddometer: 2,994
The engine driven fan throws water up and over the distributor and plug wires - you can combat this to a certain extent by fitting electric fans and switching them off before entering the water. Lots of silicone grease helps as well. The newer engine with the distributerless ignition may well be better, but I've no experience with this engine in deep water. |
08-23-2009, 02:06 PM
#125 | |
Something witty...
Oddometer: 3,612
This is a '92 so I'm guessing it'll suffer from this problem... surely someone has developed a waterproof distributor cap? If not, I guess there is always duck tape
08-24-2009, 01:54 AM
#126 | |
Oddometer: 2,994
A cheap and cheerful mod that we used, was to cut a plastic water bottle or milk carton in half, and place it over the distributor to shield it from the water. Punch holes in the top for taking the leads through and seal them around with silicone. Route the leads carefully so that they're isolated from any metal and rub them with silicone grease. That should keep you going with a bow wave water height up to the headlights. If you're planning going deeper, diesel is definitely the way to go. |
08-24-2009, 02:55 AM
#127 |
Something witty...
Oddometer: 3,612
I don't deliberately go looking for water... but I seem to find myself in deep water a little too often
08-24-2009, 06:48 AM
#128 | |
Conundrum
Oddometer: 35,170
The diesels don't rely on as much electrickery to do their thing ..... thus are less susceptible to water. Hope that helps..... Learnt from many painful and sometimes expensive lessons
08-24-2009, 08:27 AM
#129 |
UglyPirate
Oddometer: 6,937
diesel ignition is through a high combution ratio.
Gasoline is through an electrical spark. Electricity don't work underwater. Diesel engines will run underwater provided water is not sucked though the intake. Gas is dead as soon as the distributor is submerged. You can't make them water resistant enough or for very long.
"Beauty sleep?" Bitch, you don't need a nap, you need to HIBERNATE! |
08-24-2009, 08:58 AM
#130 |
Oddometer: 2,011
That pretty much nails it.
Never stop exploring |
08-24-2009, 09:04 AM
#131 | |
Oddometer: 2,011
After 1997, the 300tdi was still used in the military Defenders (TUL / TUM) and in ROW (Rest Of the World) spec. Defenders until a couple of years ago.
08-24-2009, 09:09 AM
#132 |
Oddometer: 2,011
You can clearly see the similarity between the 2.8 liter TGV and the 300tdi LR Engine:
08-24-2009, 10:16 AM
#133 |
Something witty...
Oddometer: 3,612
OK, so I've spoken to my friendly local Landy mechanic - he confirmed how bad they are in water. He said that simply pooring a bottle of water over the bonnet of his first V8 was enough to stop it
He also said that it's surprising gutless....But given how cheap this particular Landy is, for 2k he could drop a 300TDi unit and gearbox in there and it would still be cheaper than buying a similar mileage TDi... Decisions, decisions
08-24-2009, 10:38 AM
#134 |
Oddometer: 2,011
Make sure, the Frame has some substance left. Especially if it has seen a lot of water and rain. Some try to cover rust damage with loads of Waxoyl or similar stuff.
New galvanised frames are not too expensive, though. Designa Chassis, Marsland, or similar manufacturers make great stuff. Also check the front bulkhead (between windows and bonnet, and under the front rubber mats). Another thing: Check for contact corrosion, where the aluminium body comes in contact with steel parts. Especially the doors (new ones are made completely out of steel again) and where the cappings (steel) meet the body panels (aluminium).
08-24-2009, 01:53 PM
#135 | |
Oddometer: 2,994
The 3.5 Efi was a better engine and the 3.9 can be pretty poky. The problem is, that unless you change the oil really regularly the cams and valve gear wear out. Compression drops as well and can vary hugely across the cylinders. The engine still sounds like it's running OK, but there's bugger all power. Oversized wheels and tyres up the gearing and inertia, which doesn't help either. The good news is that it's a very tuneable engine. A company called Real Steel can supply you with a 4.3L stroker conversion and a torquey cam. Combine this with a pair of 1 3/4'' SU's or a 4 choke Weber and it'll take you up over 200hp easily. I built and run one for years, it was great fun. Everyone should own a V8 at some point in their life, to hell with the expense. |
| Thread Tools | |
