Thread Tools Rating: Thread Rating: 118 votes, 5.00 average. Display Modes
Old 03-16-2013, 09:35 AM   #1426
WIBO
Will it buff out?
WIBO's Avatar
Oddometer: 3,728
I like the retro style pics....beautiful example....and the Land Rover's not bad either...
The Suit:What would you consider to be your greatest weakness?
Me: Honesty.
The Suit: Honesty? I don't think honesty could be construed as a weakness.
Me: I don't give a fuck what you think.
WIBO is online now   Reply With Quote
Old 03-16-2013, 04:29 PM   #1427
sandgroper
sandgroper's Avatar
Oddometer: 4,800
i like the boots
sandgroper is offline   Reply With Quote
Old 03-17-2013, 06:09 AM   #1428
TiPirate
TiPirate's Avatar
Oddometer: 89
Scan-110614-0004_xl by matthewthompson.ca, on Flickr
Here's my D2. It's been laid up for some much needed attention after being our sole vehicle for business and personal use for two years. It's resting in the garage waiting for me to swap out the failed air suspension for a TerraFirma +2 MD kit, top end seals on the engine and Borla exhaust. Always seems to be something more important to spend on, though.
I'd love to have a Series truck someday.
TiPirate is offline   Reply With Quote
Old 03-22-2013, 06:28 PM   #1429
Hurley959
Hurley959's Avatar
Oddometer: 58
Originally Posted by MYBLUETT View Post
Build is coming along nicely...
Ditto!
Hurley959 is offline   Reply With Quote
Old 03-24-2013, 02:51 AM   #1430
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 2,894
Hi
Got a 2002 Disco2a TD5, Aus spec with ACE.
Ok, we have the 3 amigo lights AND the parking / brake warning light illuminated on the dash panel.
From what I have read, its usually the HDC / TC / ABS lights that come on but why the red parking light as well?
I did some breaking test yesterday on a clear section of road and had no ABS, I could get the wheels to lock up and skid, and the brake pedal didn't pulse like if there was ABS. It has been wet as well and have slipped on some wet / greasy roundabouts as well.
Because I had the red brake light as well, I wondered if it was a warning that the brake pads were thin / worn to limits. Because the brake pads were thin, the warning light came on and that has disabled the ABS / TC /HDC, so that the brakes don't get used more than they need to.
I had the front wheels off today and did a visual on the front brake pads, plenty there, so unless the rears are too thin, brake pads seem fine.
I have checked my regular go to source http://www.aulro.com/afvb/index.php but not able to find anything about the four lights (but my search fu is weak).
I got my Haynes work shop manual out and looked at the wiring for the red warning light and that is triggered by the hand brake lever and the brake fluid level. I have checked the brake fluid level and that is fine, though it needs replacing (I pulled the cap and did a visual).
I am suspecting that its caused by the ABS / TC / HDC system, because it all comes from the braking system, but why the parking light as well?
I looked at pulling the front disks when I had the wheel off today but then the rain came in (call me lame but near on 2" of rain in the last 2 days, its raining heavily at the moment - and no suitable under cover work area)
I am going to call my local LR specialist tomorrow and see about booking him in for some diagnosis and brake fluid change.
Any ideas / suggestions / experience of this?
Hay Ewe
Moments before you die, your life will flash before your eyes - make sure the film is worth watching - my Grandad
Don't go gentle into the long final good night from which no man has yet returned.
Moose Antlers need love too.
Hay Ewe is offline   Reply With Quote
Old 03-24-2013, 06:24 PM   #1431
TiPirate
TiPirate's Avatar
Oddometer: 89
Hay Ewe
If you're planning on running the D2 for a while, pick up a Bearmach Hawkeye. Best investment I've made for mine. Will talk to all systems on your truck and make troubleshooting a breeze, right down to realtime monitoring sensors and identifying faulty wiring.
Old 03-24-2013, 07:01 PM   #1432
Hurley959
Hurley959's Avatar
Oddometer: 58
I don't have any experience with the D2's, but perhaps the brake light is an issue independent of the 3 amigos. Did they all illuminate simultaneously?
Old 03-24-2013, 08:37 PM   #1433
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 2,894
I too think that the brake light is an independant fault but Mrs Hay Ewe says they all came on at the same time.
the next thing to do will be to check / clean the earth for the brake oil fluid and its connections. Same for the hand brake. If I can eliminate the brake light then i should be down to the rgular three amigos
Hay Ewe
Old 03-24-2013, 08:39 PM   #1434
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 2,894
Yes, I have read up on these but over the lat 5 years of D2a ownership (2 different vehciles) this is the first time a problem has occured. I shall do some more reasearch on them.
thanks
Hay Ewe
Old 03-25-2013, 09:56 AM   #1435
Juan44
Juan44's Avatar
Oddometer: 110
Not a Defender, but still very capable!
Sunt Nobis Dracones Interficiendi
Juan44 is offline   Reply With Quote
Old 03-25-2013, 10:13 AM   #1436
Achtung
Wicked Pisssah Adventurer
Achtung's Avatar
Oddometer: 960
Achtung is offline   Reply With Quote
Old 03-25-2013, 10:29 AM   #1437
TengaiJohn
TengaiJohn's Avatar
Oddometer: 3,121
Very nice!
Defenders are for men with short "you know what"
TengaiJohn is offline   Reply With Quote
Old 03-25-2013, 10:29 AM   #1438
TengaiJohn
TengaiJohn's Avatar
Oddometer: 3,121
What LR?
Old 03-25-2013, 12:02 PM   #1439
Achtung
Achtung's Avatar
Oddometer: 960
Old 03-27-2013, 06:32 PM   #1440
maloryII
more north, more wet
maloryII's Avatar
Oddometer: 3,687
Big bust out in NC at GB 4x4
http://www.wect.com/story/21791074/f...-investigation
Aaron was one of the more prolific importers of Defenders to the US. The internet Rover community is quite abuzz about this -- a couple trucks had already been paid for, and the owners saw pictures of them being hauled off by the Feds.
2006 KTM 950 Adventure
"The pen & sword, in accord."
"It's never over in a Rover."
maloryII is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:32 AM.
