Old 07-31-2009, 01:21 PM   #1
Radar OP
Radar's Avatar
Oddometer: 43
S&T to GPSU to 276C...HELP!
I am trying to learn how to transfer routes/waypoints from S&T to GPSU to my 276C. I can do the S&T to GPSU just fine, highlight the route and waypoints ok, but I can't get them to show up on the 276C when I click the upload to device icon. Some guidance would be appreciated...I need to get good at this before 8/24.
Thanks for your help,
Bill Rauschenberg
Radar
Radar is offline   Reply With Quote
Old 07-31-2009, 06:28 PM   #2
AugustFalcon
AugustFalcon's Avatar
Oddometer: 1,047
GPSU?
cheers... jack
04 BMW R1100S
02 KTM 250 Exc Racing
SmugMug referral code: jXF8ohDWlTm56
AugustFalcon is offline   Reply With Quote
Old 08-01-2009, 12:02 PM   #3
mcnut
Oddometer: 1,365
I think he may be using GPSUtility which is a nice data editing tool which has been around (with updates) for many years. It will open and display GPS Waypoints, Routes & Tracks on any georeferenced maps files. Recent improvements to MapSource (mostly with tracks & maps) have reduced the need for GPSU
I don't have an answer for the problem other than to suggest checking for current version of GPS firmware and of GPSU. Falcon, have you had any luck transferring any data using GPSU on your current computer and the 276?
Bruce
mcnut is offline   Reply With Quote
Old 08-01-2009, 12:41 PM   #4
AugustFalcon
Oddometer: 1,047
Originally Posted by mcnut
...Falcon, have you had any luck transferring any data using GPSU on your current computer and the 276?
Bruce
I'm so far behind I hadn't even heard of GPSU, hence the question. But, now that I have, I'll find it and play around with it and see if I can work his problem.
EDIT: Took a quick look at the GPSU site --- the free version has some limitations ...
Freeware version
This version is limited to 100 waypoints, 5 routes of up to 10 waypoints each, 500 trackpoints, bitmap image size of 2000x2000 pixels.
cheers... jack
04 BMW R1100S
AugustFalcon screwed with this post 08-01-2009 at 12:51 PM
Old 08-02-2009, 12:28 AM   #5
mcnut
Oddometer: 1,365
Sorry, I meant to direct my question to Radar.
Bruce
Old 08-02-2009, 03:03 AM   #6
Jamie Z
Jamie Z's Avatar
Oddometer: 7,693
Is this something GPSBabel can't do?
Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is offline   Reply With Quote
Old 08-02-2009, 10:48 AM   #7
mcnut
Oddometer: 1,365
I have never used GPSBabel. Having said that they are somewhat similar. Babels strong suit is the number and type of data formats it supports and converts. GPS Utility does not support as many formats but has better data editing tools and map tools. Utility can load any georeferenced map or if you know the location of 3 points on a map (IE a map you have scanned) it will geo reference it for you. Utility can only transfer data (waypoints, Routes & Tracks) to or from the GPS, not maps.
Used to be a bigger deal before Garmin beefed up MapSource and the available map products.
Bruce
mcnut screwed with this post 08-02-2009 at 10:56 AM
Old 08-02-2009, 03:01 PM   #8
chopped58
chopped58's Avatar
Oddometer: 1,392
Try this, hope it helps..
http://www.goldwinggadgets.com/iWay/GPSU_Tutorial.htm
chopped58
ADV Rider Relay 2008 New York
IBA# 27774
06 Uly
58 FL
Ride report: NY to Vegas
http://www.advrider.com/forums/showthread.php?t=513905
chopped58 is offline   Reply With Quote
Times are GMT -7.   It's 08:08 AM.
