Old 08-03-2009, 03:52 PM   #16
Countdown
Oddometer: 5,658
Originally Posted by Gramps
When's your bike scheduled for launch?
Only takes 8 minutes to make orbit, most of my bike rides last 10-16 hours. Vibe and shock levels are similar, NASA quality may not be good enough.
The Auto industry requires much higher reliability than the Military.
Jerry Counts
Countdown is offline   Reply With Quote
Old 08-03-2009, 04:01 PM   #17
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,666
Originally Posted by Countdown
Only takes 8 minutes to make orbit...Vibe and shock levels are similar
You may want to think about getting your bike tuned up.
Boon Booni is online now   Reply With Quote
Old 08-03-2009, 04:40 PM   #18
kjclark7 OP
kjclark7's Avatar
Oddometer: 1,369
Originally Posted by Lead Wrist
This thread (post #7) can help you with the info related to hardwiring your GPS to GPS factory wiring harness from your GS as you pictured it (the thread is about Zumo but same applies for other GPSs):
http://www.advrider.com/forums/showt...hlight=R1200GS
The OE plug is designed and controlled by CanBus and provides switched power, ie. it's "on" when the key is "on" in the ignition and it goes "off" 1-2 min after the key is out, to any GPS. My GPS is wired this way and never had any issues with it.
No need to be afraid of CanBus as long as you don't cut and splice into OE wiring harness, as that's !! One more reason as to why GPS plug is provided by the factory for people to use it !! More on the topic of pro/con of CanBus you can find over at GSpot forum, dedicated to GS bikes.
As for your second picture and wondering what that block is, even though the location of it has changed on your bike relative to my 07 Adv, that appears to be fuse block for your fog lights. If you open it, you should be able to find 2x 7.5A fuses in it...
Hope above helps and enjoy your wrenchin' !!
lead wrist,
thank you for answering the questionn i originally posted.
2009 BMW R1200GS Adventure
2008 Yamaha FZ-6
1983 BMW R100RS
2013 KTM 350 XCF-W
kjclark7 is offline   Reply With Quote
Old 08-03-2009, 04:56 PM   #19
John Joel Glanton
John Joel Glanton's Avatar
Oddometer: 927
Man, you're harsh! I believe you about my wiring being non-NASA but....dang....what are you...some kind of electrical engineer?
The reason I did what I did on the connectors is because I wanted a big enough "eye" that would fit the battery terminals but which I could still get that thin little wire into. So, I stripped the wire down, folded it a few times until it "filled" the connecter, crimped it, then soldered it, then put heat-shrink tubing on it.
With my non-NASA-compliant GPS wiring, I rode my bike over 4,000 miles in this trip from Texas to Idaho, Washington, Oregon, and Utah some of it on dirt. Before that, I rode my bike all over Colorado which included a lot of dirt, rough roads, and washboard. So far, it's still working fine.
BTW: I think we may both be flirting with thread crapping now. Thanks for the advice and I'm glad the OP got his original question answered. Bye.
They rode on. They rode like men invested with a purpose whose origins were antecedent to them...
John Joel Glanton is offline   Reply With Quote
Times are GMT -7.   It's 04:47 PM.
