Old 09-07-2009, 09:51 PM   #16
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Umm... I think they are different. Different bike and different grips. You can't peel the F8GS grips off the heating element as far as I can tell. The heading element is bonded to it. You can cut it off but if you cut a wire you buy a new set of grips.
Either way you want both ways will work. I found this Renthal grip a sleeve an easy fix. Heated grips still work.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 09-08-2009, 05:02 AM   #17
Toadride
Toadride's Avatar
Oddometer: 835
I like your idea. And I like the white. The more grime they get on them, the better they'll look. Gonna go looking for some tomorrow.
Old 09-08-2009, 06:26 AM   #18
cisco
old fat guy
cisco's Avatar
Oddometer: 278
I replaced my stock grip with pro grip 7xx rally. I cut the stockers right off and installed two throttle side grips. My surgerized hand feels much better.
Cisco
cisco is offline   Reply With Quote
Old 09-08-2009, 06:40 AM   #19
flux_capacitor
I know a shortcut!
flux_capacitor's Avatar
Oddometer: 9,628
Umm... because they are foam. How long can they last?
I like your solution but since you asked...
Foam grips last a LONG time. I nearly have 20K on these ones. $7 at Cycle Gear for a set. The only real drawback is after a heavy rain they absorb some water, but truthfully not nearly as much as you would think. Also, the foam helps absorb vibrations as well.
flux_capacitor is offline   Reply With Quote
Old 09-08-2009, 10:05 AM   #20
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Cisco
Yeah, that's what I did. Two throttle side grips but didn't need to do the surgery on the F800 grips because these are streatchy and I wanted a thicker grip but not huge. For me the extra bit thicker is perfect... large hands.
Depending on how thick you want them to be I have a set of the brake side ones. I bought two sets and used the throttle side grips for mine. You could easily use the brake side ones with a little simple green and just a touch more effort. They'd be thicker than mine but not by much. Not sure what it would cost to ship but they'd fit in a USPS standard rate 2 day box. I think they were $12 bucks locally. Looks like $10 online.
Gangplank screwed with this post 09-08-2009 at 10:10 AM
Old 09-10-2009, 03:11 AM   #21
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,184
Talking Big Fat Grips for less than AUS$5.00
After reading this thread and being interested because I have always found the 800's grips too small I happened to be waiting to be served at a local business and they had a promotional cricket bat grip on the counter. as below;
http://s626.photobucket.com/albums/t...rrent=grip.jpg
This is to support the Mcgrath Foundation which was started by a very famous Australian ex test cricket player after his wife died of Breast Cancer, and usually involves the colour pink.
It occurred to me that if I got a similar grip in a more manly colour like ... black (although I did consider yellow to match my bumble bee) and cut it down it just might work. Much to my surprise I cut two sections 10cm long, heated them in hot water, sprayed a little windex on the standard grips and in almost no time I had the following results;
http://s626.photobucket.com/albums/t...00GSGrips2.jpg
http://s626.photobucket.com/albums/t...00GSGrips1.jpg
Have only ridden about 70Km but am impressed. Grips are more comfortable, the heated grips still work, as a bonus the vibration through the handlebars is reduced to almost nothing and low speed throttle control is vastly better.
This tip might be a bit difficult in those unenlightened countries where Cricket isn't played ( A couple of minor nations in North America come to mind ), but it should work for the rest of us. I suspect there must be somewhere in New England or Canada where you can get cricket gear, but there is always mail order.
Ducksbane screwed with this post 09-10-2009 at 03:37 AM
Ducksbane is online now   Reply With Quote
Old 10-02-2009, 07:27 AM   #22
narcosis
GS800
narcosis's Avatar
Oddometer: 96
Nice work Ducksbane.
This looks nice & comfi.
Are these your ordinary cricket grips which can be found in any rebel sport shop?
Ride as though you're invisible, not invincible !!!
narcosis is offline   Reply With Quote
Old 10-02-2009, 08:19 AM   #23
TexasMule
Float away ya fairy...
TexasMule's Avatar
Oddometer: 3,858
Nicely done, now I'm off to google cricket grips.
Thanks a lot...
TMule
You can buy everything, but more time...
______________________________________________
-to my mind alloy triumph tanks rank near titties in their inherent attractiveness -Mutt
TexasMule is offline   Reply With Quote
Old 10-02-2009, 08:32 AM   #24
TexasMule
TexasMule's Avatar
Oddometer: 3,858
All I can find is Gunn & Moore that come in poofter colors. No black
What brand did you use?
I really like the looks of what you did.
TMule
Old 10-02-2009, 11:07 AM   #25
M N B
would rather be riding
M N B's Avatar
Oddometer: 1,165
I tried some Grip Puppies for a couple of weeks. Didn't care for them at all. Too thick I think. Plus they reduced the effectiveness of the heated grips. So I've gone back to the stock grips for now.
2014 Ducati Multistrada 1200 Pikes Peak MNB Touring Edition
2009 BMW F800GS
2011 Husqvarna TE310 - 2003 Husqvarna TE610e
2007 HD Road King FLHR
1997 BMW K1100LT Special Edition
M N B is online now   Reply With Quote
Old 10-04-2009, 10:29 PM   #26
narcosis
GS800
narcosis's Avatar
Oddometer: 96
This is the range for Cricket grips in the Rebel sports dep (OZ)...
http://www.rebelsport.com.au/ecom/re...t%20grip&br=-1
Not sure which ones Ducksbane used though...
Old 10-05-2009, 08:19 AM   #27
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,184
Hi Guys ... not sure which brand I used either, I just went into the local sports store and they had a generic grip in lots of colours for $4.95
I have noticed that grips come with different patterns, and I liked the look of the pattern in the photo's.
Old 10-05-2009, 08:28 AM   #28
TexasMule
TexasMule's Avatar
Oddometer: 3,858
Was about to buy a couple from Rebel for $4.99 each until I got to the postage $39
I think I'll pass...
TMule
Old 10-05-2009, 08:33 AM   #29
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,184
I just had another thought for those in the northern colonies ... flea bay
Try searching for cricket bat grips.
Failing this the less fortunate should perhaps consider a campaign to raise interest in one of Advriders strangest group buys.
Oh ... Texasmule ... I agree Gunn and Moores colours are so, uhmnn, Gay. Typical Poms, surprised that they managed to win the Ashes.
Old 10-14-2009, 08:39 PM   #30
Xskydiver
Xskydiver's Avatar
Oddometer: 252
another option
I just used "whatagrip" tennis racket grips. They were about $5 a pair. One note cut them a tad long. When they stretch open they shorten slightly lengthwise. Probably 4.25" will be perfect.
Xskydiver screwed with this post 10-27-2009 at 10:01 AM
Xskydiver is online now   Reply With Quote
Times are GMT -7.   It's 09:04 PM.
