Old 11-18-2009, 09:44 PM   #31
skodadog
skodadog's Avatar
Oddometer: 30
Pissed
Originally Posted by Ducksbane
I just had another thought for those in the northern colonies ... flea bay
Try searching for cricket bat grips...
I found an online place shipping from NC, $5.98 for two grips, $18.00 shipping to WA!
'08 F800ST
'10 F650GS
'06 DR650SE
former
'01 Super Sherpa
'05 Ducati M650
'05 Aprilia Scarabeo 50
'00 Ducati M900
'97 Ducati M900
'81 Vespa 200
skodadog is offline   Reply With Quote
Old 12-03-2009, 10:54 AM   #32
stevemic
Strange Duck
Oddometer: 8
Thanks for grip tip
Tried your method, got some Renthal "Medium" grips and installed them per your instructions. Very happy with the outcome. Thanks alot.
stevemic is offline   Reply With Quote
Old 12-03-2009, 11:08 AM   #33
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Glad to hear it. Mine have held up pretty well. Figure about 12,000 per set, maybe more. Best thing is the stock heated grips will look brand new for years. I'll be trying the medium grips next time myself.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 12-03-2009, 01:14 PM   #34
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,393
Fwiw, when I installed the G2 Throttle Tamer, I was easily able to remove the stock grips. If all I wanted to do was change the grips, I could have done so easily. Just carefully cut off the old ones and install the new ones. Done.
Only downside is having to buy two sets of grips since the left grip requires a throttle sized grip.
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 07-28-2010, 08:39 AM   #35
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,190
Simple Cure!
I have also slipped on the Renthal mediums over the stock grips.
These have virtually ended the numb hands I've been getting on this bike.
It seems the small diameter alone of the stock grips is the reason for numb hands, at least for me.
Great tip!
Maxacceleration is offline   Reply With Quote
Old 07-28-2010, 12:39 PM   #36
Moab
Moab's Avatar
Oddometer: 132
Thumb grip puppies
the stock grips were a killer, bought some grip puppies for $9 and they installed in 5 mins....well worth it, nice and soft!
Good, Bad.....I'm the guy with the gun
'04 1150 GS
'09 KLR 650
'10 800gs
Moab is offline   Reply With Quote
Old 07-28-2010, 01:29 PM   #37
GeckoRider
GeckoRider's Avatar
Location: Oakland, CA, USA, Thrid Rock from the Star Sol
Oddometer: 446
Did the Renthal grip over the top of the stock grips. Love the feel now. Still using my Throttle Rocker but it just feel so much more right. Thanks for the tip. My install did not look as nice, but I guess I am just not as handy nor do I have a proper shop to work out of.
F800GS Mag/Black 2009 "Faucon GriS"
Farkles; Garmin GPSMap478 in a TT cradle, Airhawk seatpad, Pivot Pegs, SW-motech bars, MOD skid plate, Altrider headlight guard, HDB handguards, Maier Mudguard.
GeckoRider is online now   Reply With Quote
Old 07-28-2010, 03:03 PM   #38
sturgeon
sturgeon's Avatar
Oddometer: 928
Another possible option to buying two sets is these:
Hopefully they'll fit over.
sturgeon is offline   Reply With Quote
Old 07-28-2010, 03:41 PM   #39
THE BONE SHAKER
Adventure Tourer
THE BONE SHAKER's Avatar
Oddometer: 269
I fitted neoprene pushbike grips over mine. Cost me 6 dollars. Greatly improved grip and throttle control. I cut the lip off the standard grips to get them over. Water and detergent as lube with compressed air behind it . They fit very snugly.
THE BONE SHAKER is offline   Reply With Quote
Old 07-28-2010, 03:41 PM   #40
dsrydr
dsrydr's Avatar
Oddometer: 273
grip puppies
Took a chance (not much of one, $10 shipped) and ordered some grip puppies. At first they seemed a little large but got used to it pretty quick. Very comfortable, I like em. It took a day or so for them to grip where they wouldn't slip (humidity?). When it rained they dont hold much water. Wrapped a dry rag around them and sqeezed a little and they were pretty much dry.
dsrydr is offline   Reply With Quote
Old 07-28-2010, 03:46 PM   #41
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
That is what I used only I got the motocycle grips. Same thing except ATV's don't have a throttle side so those will be 2 thicker grips. BTW you would only need one set of those but they might seem thick.
Old 07-28-2010, 03:48 PM   #42
GeckoRider
GeckoRider's Avatar
Oddometer: 446
Exactly the ones I bought. I don't have an air compressor so I used hot water to soften them up then stretch with some hand tools and invert them so I could roll them on over the stock grips. A little push and shove and they went on fine. I trimmed the ends off with a razor blade before mounting.
Old 07-28-2010, 03:52 PM   #43
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Did the same with mine. Simple green sprayed in. They went on easy and have not moved a CM. 10,000 mi so far and they are starting to look a little worn on then ends but still have a lot of work left. perfect.
Old 08-04-2010, 05:36 AM   #44
sturgeon
sturgeon's Avatar
Oddometer: 928
Finally put 'em on - not too thick for me. Just about right, in fact. I don't have particularly large hands, but I hated the skinny, hard OEM grips.
Old 08-07-2010, 05:58 PM   #45
TheCowboy
back in the saddle again
TheCowboy's Avatar
Oddometer: 606
Good thread - I did mine today - no simple green - I just used soap and water. Used two duck-bill pliers to pull them on over the OME grips - went for test ride - me likey! Throttle seems a bit more touchy now - but I'll get used to it.
TheCowboy
TheCowboy is offline   Reply With Quote
Times are GMT -7.   It's 05:34 PM.
