Old 12-11-2012, 06:44 PM   #16
SpeedyR
SE in the SE
Oddometer: 889
typically a lot of the high end "race" tires for the big rallies are one off race tires that are a radial construction. most of your off road product tires are bias-ply tires.
my guess is that the "race" version is a radial, or at least a construction closer to that..
SpeedyR is online now   Reply With Quote
Old 12-12-2012, 04:10 AM   #17
rotax793
gravel hunter
rotax793's Avatar
Oddometer: 6
So you mean it could be that it's the same pattern, only a firmer inner construction?
rotax793 is offline   Reply With Quote
Old 12-12-2012, 04:33 AM   #18
JMo (& piglet)
Gone a bit Baja
JMo (& piglet)'s Avatar
Oddometer: 4,191
I have always used Michelin Deserts on my race bikes, but have also used both the T63 and Dunlop 908RR over the years too... (on my XR650R).
I'd say the 908RR rear is a great dual-sport (ie. road and trail use) tyre, having ridden one from the UK to Morocco and back as far as Northern Spain before it was worn out.
I've also used T63s (front and rear) on the XR, and found they were pretty useless by about 1000 miles - I wouldn't recommend them on a big heavy/powerful bike - the Deserts will really last twice as long...
However, if you are on a budget - as a previous poster suggested, the T63 rear is similar to the Michelin Desert rear... while I'd add that the Michelin AC10 front is a very similar tread pattern to the Desert front - all are DoT street legal tyres.
Jx
JMo (& piglet) is offline   Reply With Quote
Old 12-12-2012, 05:13 AM   #19
SpeedyR
SE in the SE
Oddometer: 889
actually a radial typically is softer construction, but when racing they also use a mousse insert which feels about like 8psi, but no problems with flats so the more flexible carcass will conform to the terrain better (more traction) but with no chance of flats.
also it's usually more expensive but racers don't care. well, at that level anyway. ;)
Old 12-12-2012, 06:38 AM   #20
mmurry
Oddometer: 81
burned up the rear on my SE pretty dang fast... the front truly is terrifying on the highway... but awesome on dirt.... going to try TKC's when my mich enduro's are done..
mmurry is offline   Reply With Quote
Old 12-12-2012, 10:04 AM   #21
jm65
jm65's Avatar
Oddometer: 183
hi guys
what do you think of "motoz" tyres ?
thanks
KTM 690 R 2014
jm65 is offline   Reply With Quote
Old 12-12-2012, 06:40 PM   #22
guns&coffee
Gnarly!
guns&coffee's Avatar
Oddometer: 1,237
Heidenau
Heidenau K60 is probably the best all round tire for the 950. Check with Craig at CJ Designs.
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '75 Husky 360WR/CR,
guns&coffee is offline   Reply With Quote
Old 12-12-2012, 06:44 PM   #23
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 925
Originally Posted by jm65 View Post
hi guys
thanks
I LIKE the rear,have not used a front.Good price. Stout tire.
dogsslober is offline   Reply With Quote
Old 12-13-2012, 03:27 AM   #24
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,143
for the desert rear's:
The desert is very hard and made for powerfull bikes at extended speed but no longer produced, get them if you can. I love it on the 950 for dry/desert ground.
The desert race has a lot lower profile and is made from softer rubber. specifically made for the 450's now active in dakar. Ive seen it wear a lot faster on these bikes than the old desert, grip is better on rock's and sand. I think on the big bike this is not your best option if you'r looking for a tire that you wont replace after every day racing for a new one.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is online now   Reply With Quote
Old 11-25-2013, 01:10 PM   #25
K u r t
K u r t's Avatar
Oddometer: 251
Did Michelin make a new version of the Desert? I see it here and I'm liking the tread:
http://www.motosport.com/dirtbike/MI...R-TIRE-1408018
Kurt
K u r t is offline   Reply With Quote
Old 11-26-2013, 09:28 AM   #26
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
micehlin desert
IMO I believe the new desert racing tires are for the single 450.
The old thread pattern and the weight of the original rear are for ther big bikes
LURKER
pepetrueba is offline   Reply With Quote
Old 11-26-2013, 10:57 AM   #27
Hockenrider
Wheel in Front
Hockenrider's Avatar
Oddometer: 72
Desert Rears
Hi I have used both on my 990 and they seem to deliver the same result.
No issue with either .
if I'm lucky I can get 3 days of riding out of them over gravel - rock and a bit of tarseal thrown in , that's about 1200-1500 km .
Pro's
: Great traction of road.
: Great Price
: Good road manners wet or dry
: Side walls also strong = puncture resistance
: Big grins when exiting gravel corners.
Cons : Shelve life . (but refer back to that Grin factor )
Throw a T 63 on the front and enjoy
Hockenrider screwed with this post 11-26-2013 at 11:03 AM
Hockenrider is offline   Reply With Quote
Old 11-26-2013, 03:21 PM   #28
K u r t
K u r t's Avatar
Oddometer: 251
I saw (what I believe to be) a prototype of the Desert Race a couple years ago on Rallye Pan Am's KTM 690R, which was fresh back from "Dakar" Rally in Argentina. It looked equally stout to the conventional Mich Desert but perhaps more road-worthy. I'd use it on my HP2 but I need it to be as good or better than the 908RR. Certainly the 908 is not a light-duty "450-ish" type tire - any intel here?
Kurt
Old 07-25-2014, 02:46 PM   #29
DYNOBOB
lucky dog
DYNOBOB's Avatar
Oddometer: 1,058
Resurrecting a old one here...
Any fresh intel on the newer Desert Race rear tire? Trying to decide on another 908 or ?? Have 1500 easy dual sport miles on my Desert Race front and it looks great.
TE630.KLX250S.GL1800.CBR900RRturbo.919
HoW (ForeverWest) 2014 CO/UT 2013
Northern Rockies 2013 IBA Key West 2014 Tentspace
DYNOBOB is offline   Reply With Quote
Old 07-25-2014, 04:25 PM   #30
DirtJack
DirtJack's Avatar
Oddometer: 1,595
Of course, the bigger the bike the harder it will be on rears. Since the rear is going quickly anyway, I've given up on high mileage and have raised the importance of cost in my selection of tires. The T63 is a real bargain but the largest rear you can get is 130/80 and that is too small on a 690 or larger. I think the next best bargain is the Pirelli Scorp. Rally and both front and back work well on my 690 and I just bought a set to try on my 1190R.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Times are GMT -7.   It's 05:33 PM.
