Old 08-11-2009, 11:08 AM   #1
kjclark7 OP
kjclark7's Avatar
Oddometer: 1,340
View multiple map layers on a Zumo550?
i am looking at the zumo 550 and that comes loaded with the city navigator maps. with the addition of a SD card, you can load other maps as well. so i am wondering, if you load up the topo maps, does that come up while the city maps are up or do you have to select the topo maps and look at it seperate?
2009 BMW R1200GS Adventure
2008 Yamaha FZ-6
1983 BMW R100RS
2013 KTM 350 XCF-W
kjclark7 is online now   Reply With Quote
Old 08-11-2009, 02:55 PM   #2
Jamie Z
Jamie Z's Avatar
Oddometer: 7,702
I don't have a Zumo, but in my experience with Garmin is that you can only view one at a time. There is a menu option to choose the mapset. Curiously, you can select more than one mapset at a time, but only one shows up on the screen at a time. There must be some sort of order of priority.
It's a good thing that it doesn't display more than one at a time, because quite often the road data isn't exactly the same, and it would be quite a mess on the screen.
Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is offline   Reply With Quote
Old 08-11-2009, 04:51 PM   #3
mcnut
Oddometer: 1,365
As Jamie Said.
You can have more than one map set to "Show" but it will default to a hierarchy that is set by the software. In your case CN will overwrite Topo or Roads & Rec. Not sure about the Garmin marine products or 3rd party maps.
So if you have CN and loaded Topo you have the option to "Show" or "Hide" CN and "Show" or "Hide" Topo (and for that matter the base map). You could leave Topo set to "Show" and toggle CN between "Show" & "Hide". This will slow down the redraw a little. For a faster redraw, setting Topo to "Hide" will speed things up.
Bruce
mcnut screwed with this post 08-12-2009 at 02:44 PM
mcnut is offline   Reply With Quote
Old 08-11-2009, 07:12 PM   #4
WoodButcher
WoodButcher's Avatar
Oddometer: 2,068
Actually you can convert the topo to be transparent and they will over lay CN on the Zumo. I haven't done it, but you can read about it on the zumoforums site.
Rusty
WoodButcher is offline   Reply With Quote
Old 08-12-2009, 02:41 PM   #5
mcnut
Oddometer: 1,365
You are right! I stand corrected (edited my previous post) and do remember that folks were able to do that. As I recall it is not straight forward and therefore may be best reserved for advanced power users.
Bruce
Times are GMT -7.   It's 10:55 AM.
