Old 08-18-2009, 06:35 PM   #1
Airhead OP
More human than human
Airhead's Avatar
Oddometer: 2,099
Facet 40171 install...my story
So, after burning through 3 OEM fuel pumps in less than 10,000 miles (2 had fried points, one just quit for no reason), I finally decided to install a Facet 40171 and try my luck with that. Just thought I'd go over my experience quickly in case someone else might find it useful...
I started by ordering the pump and recommended fuel filter from Aircraft Spruce:
www.aircraftspruce.com
The filter is listed under the Facet fuel pumps...you need to search for "40171" to find the correct pump.
I then ordered some Permatex Make-A-Gasket #3 (Aviation grade) to seal the threads on the barbed fitting and the fuel filter:
http://www.jamestowndistributors.com...ct.do?pid=9403
I had to order the barbed fitting for the outlet side of the pump, since I live in the middle of nowhere and couldn't find one locally:
http://www.marineengine.com/products...php?in=2560411
I bought some 5/16" inner diameter fuel line from the local Napa, and a Unicoil since I decided to run the fuel line straight to the pump inlet, rather than use a bunch of fittings to create a 180 degree bend in the inlet fitting:
http://www.gates.com/brochure.cfm?br...ocation_id=541
I snipped the electrical connector off of the old pump, and connected it to the leads on the new pump using weather proof posilocks:
http://www.posi-lock.com/positite.html
This allowed me to plug the Facet directly into the stock wiring harness, without having to modify the bike's wiring.
I used some closed cell neoprene, wrapped around the inlet side of the pump, to mount the stock pump housing, as suggested by cpmodem:
http://www.foambymail.com/neoprene.html
This resulted in a very secure fit between the new pump and the stock housing.
The new pump is a very tight fit, and I had to really work with it to get it to clear the stock skid plate. I routed the inlet fuel line between the pump and the engine casing in order to get it out of the way. I also found that it was difficult to keep the inlet and outlet fuel lines from slightly contacting the edge of the skid plate...I'll keep an eye on those spots and make sure the skid plate does not begin to rub through the hoses.
The new pump works great, and will hopefully last much longer than the stockers have been. I found the fit to be somewhat difficult, but in the end I found the results to be satisfactory.
Sorry I don't have pictures...maybe I'll take some to add to this the next time the skid plate is off.
Jeff
'05.5 KTM 950 Adventure
2008 KTM 450 EXC-R
All Orange, Baby!
Airhead is offline   Reply With Quote
Old 09-24-2009, 05:01 PM   #2
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Hi mate,
do you have close up photos of the setup?
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 09-24-2009, 05:17 PM   #3
kizniche
pyro
kizniche's Avatar
Oddometer: 165
Originally Posted by ADVJake
Hi mate,
I did this upgrade a little over a month ago after I got my 950. Here are some pictures of my final install. I found it to clear the skid plate by a centimeter or two. The hose to the filter has since had a hose clamp put on, and the others replaced with higher quality parts.
kizniche is offline   Reply With Quote
Old 09-24-2009, 07:45 PM   #4
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
cheers mate,
looks like i need to revise my setup. Im getting fuel line pinching issues when the bash plate is put on.
Old 09-25-2009, 01:00 PM   #5
Balsta
Oddometer: 400
Jeff
My first Facet 40171 (with a quality filter) died after about one season (12000 miles). I'm on the second which has survived this last season. Anyway, it seems from reading this thread my failed Facet probably is an exception.
Balsta is offline   Reply With Quote
Old 09-25-2009, 01:11 PM   #6
K80JIM
Super Tanker
K80JIM's Avatar
Oddometer: 556
This is just a suggestion. If that is a glass in-line fuel filter you might want to replace it with a plastic one. Those were very big about 20 years ago, you could unscrew them and replace just the filter if you wanted. A lot of V.W. shops were putting them on the bugs. I must have seen 25 burn to the ground because if them. We had a repair shop and my brother owned a tow company. They would bump into something metal and crack or maybe just crack from vibration. I could just see that thing being hit by a rock or crash the bike and it hit something or crack from the vibration of the bike.
Anybody else thinking the same thing or is it just me?
Good luck with the pump, hope it takes care of all the problems you have had.
Jim
You're never lost as long as you still have gas!
K80JIM is offline   Reply With Quote
Old 09-25-2009, 01:23 PM   #7
firebolter
Oddometer: 606
I used the filter from Aircraftspruce for my set up
2014 F800GSA
2007 KTM 525 EXC
2013 Berg TE300
2006 Husky SM610+71 BSA 250 Trials
2011 Beta 300 2T Lim Ed+ 74 RL250 Suzi
firebolter is offline   Reply With Quote
Old 09-25-2009, 11:49 PM   #8
kizniche
pyro
kizniche's Avatar
Oddometer: 165
Thanks for the advice. I now have the metal filter above on order. I had the thought of danger when I realized it was glass and not plastic while installing it. Plastic wouldn't have made me feel much better anyway.
Old 09-27-2009, 02:03 AM   #9
Swashplate
50 MSL & 150 KTS
Swashplate's Avatar
Oddometer: 1,206
+1
Euphoria is state of mind
Swashplate is offline   Reply With Quote
Old 09-27-2009, 02:55 AM   #10
Peanuts
Peanuts's Avatar
Oddometer: 1,698
Why do you need a filter? The fuel taps will have filters in them.
Peanuts is offline   Reply With Quote
Old 09-27-2009, 03:18 AM   #11
Swashplate
50 MSL & 150 KTS
Swashplate's Avatar
Oddometer: 1,206
I know the tap filter (if the 950 has them) is good enough for the carbs but what about for the pump itself?
I used the one above pictured above for my install but it on the inlet side of the 40105 pump.
Note 1: The filter makes a nice easy way to get to the STBD/inlet side of the pump then by using some brass elbows resulting in having the inlet and outlet on the same side just like the stock pump is. Ref: http://www.ktm950.info/ fuel pump, 40105.
Note 2: I had to swap the fuel line postion in that hose holder under the Rectifier/Regulator to make it fit a bit closer to avoid hitting my TT skid plate.
Swashplate screwed with this post 09-27-2009 at 03:25 AM
Old 09-27-2009, 03:31 AM   #12
Swashplate
50 MSL & 150 KTS
Swashplate's Avatar
Oddometer: 1,206
Jim
My thinking too, I used to live in So Cal in the 80's and saw these all over the aircooled crowd. Also know a guy who lost his 69 baja for this reason. Magnesium burns very hot and bright too !! They look trick for the show VW's but that about all I would use them for....show.
Old 09-27-2009, 04:42 AM   #13
Airhead OP
Airhead's Avatar
Oddometer: 2,099
These pumps require very fine filters...any crap in the fuel will cause them to seize. I used the one recommended by Facet...
The only problem I have had is that the leading edge of my pump touches the OE skidplate when everything is bolted together. Not a big deal, just not exactly ideal...
I also used a Unicoil to protect the inlet hose where it is bent the sharpest...
2008 KTM 450 EXC-R
All Orange, Baby!
Old 10-05-2009, 05:10 PM   #14
kizniche
pyro
kizniche's Avatar
Oddometer: 165
Facet filter
Here's the setup with the new fuel filter in place. The line runs the same space the previous filter took up, minus ~5 cm. past the pump to the right where the new filter is installed. The hose has enough slack to where I don't believe a problem will arise. The bend is on the negative pressure end of the pump, so that may be the only issue if the hose becomes soft and decides to buckle and pinch the fuel supply.
Old 04-29-2013, 11:12 PM   #15
bazza950
bazza950's Avatar
Oddometer: 9
Breather tank connectors on the 950 Adventure
just fitted the facet pump and then discovered that the redundant 4 breather tubes have 7mm connectors into the tank.No one sells 7mm!
Eventually found that Vespa scooters use this size and ebay (UK) threw up a supplier.
uniscootuk
So if you want to buy all the parts before you start - get 4 x 7mm x 10mm long bolts to seal in!
I have a small issue with the facet filter being too long so might have to remote it, as it touches the bash plate.Unless you know of an answer!
bazza950 is offline   Reply With Quote
Times are GMT -7.   It's 06:41 PM.
