Old 02-21-2010, 09:59 PM   #196
troy safari carpente
Team f5ool
troy safari carpente's Avatar
Location: "Pearl of the sound" - f5ederation of scandwegia
Oddometer: 20,133
Originally Posted by Pezz_gs
Ahh Troy and OldDog, are you finished . . . . . .
ummmmmmm... no?
I mean let's face it... you are the only bloke I know who would preface the following paragraph with the words "quite simple";
After getting the XR stem pressed out, and with the suggestion of Terry - SOHC Forum, extended the shaft 20mm to align the steering head bearing surfaces.
Process was quite simple, part the shaft in the lathe, face the edges, fabricate a spacer which would be pressed into the shaft, took 6 ton of pressure, machine a groove, then weld and machine down to 25mm OD.
I ordered some Taper roller bearing kit from a UK which should be here in a few days. The bottom bearing has an inside diameter of 30mm, the stem is 26mm. I will make a sleeved spacer to take up the 2mm ID and locate the bearing in the correct placement.
Your ingenuity constantly impresses me Pezz... just think of my "ribbings" as badges of honour... Gee... next to McFear, you must be the most decorated OzADV soldier we got! I guess someone had to take the heat off OldDog didn't they... although, when I think about it... in the outback "combined" event (maniac mechanic projects AND stacks), I still think that Old Dog has still got the wood on both you and young McFear combined!
Well better get back to it. That's our Pezz!
Not to leave my iDIOlitimate son out of the picture... I must say that it is pretty hard to reconcile those last two RZ350 photo's as motorcycles of the same make and model isn't it? The black and silver one is billiard room porn for sure...!
tREV's looks like something he'd brung home from kindie and mum put a fridge magnet on...
WATCH THIS SPACE...
troy safari carpente is offline   Reply With Quote
Old 02-22-2010, 01:00 AM   #197
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,786
Now Troy,
I have a feeling that maybe we could build a safari bike for you
Its a 660cc jobbie
We could get a hat passed around and Advrider Oz could be your sponsors.
An RZ250 with one of these slapped on top, tREV has the suspension under development . . .
More info here.
http://www.cpindinc.com/pub/view_pro...1102-8558-1253
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Old 02-22-2010, 02:39 AM   #198
Team f5ool
Oddometer: 20,133
Now Troy,
I saw Paul Wrights efforts to pilot something along those lines in the Suffari back in 1990...(CR 250 frame, suspension and RZ 350 donk)...
... Ummmm... fanks, but no-fanks!
WATCH THIS SPACE...
Old 02-25-2010, 03:36 PM   #199
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,786
Well look what UPS just delivered
Steering head bearings, cam chain and engine seal kit.
Now I have to get busy . . . see ya later
Airhead Tragic
Old 02-27-2010, 11:55 AM   #200
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Early YZ250 with a TZ350 donk in it.
75hp at the rear wheel.
NordieBoy is offline   Reply With Quote
Old 02-27-2010, 11:30 PM   #201
dirt_bloke
No idea
dirt_bloke's Avatar
Oddometer: 910
I have the parts you need!
Do you like this tREV
This is the reason I bid on the RZ, okay
Hi pezz, I have all the RGV parts you need for this project. They will be up for sale at the 'Swap Meet in Maryborough 7th March' http://www.advrider.com/forums/showt...ight=swap+meet
PM me with what you want.
I've been inspired by this thread. Last week I 'won' a GSX650F, repairable write-off. The project is very long term. The build thread will start later.
With the bike stripped down, I'm wondering what the hell I've got myself in for!
I've often thought that
_________________________________________
Not a Member of the......Quorn Schnitzel Club
(yet)
dirt_bloke is offline   Reply With Quote
Old 02-28-2010, 12:22 AM   #202
KASUYAHO
Road Hog
Oddometer: 3,637
looks like a bit of fun doing this,
under a $1,000 hey. hhhmmmmm
KASUYAHO is offline   Reply With Quote
Old 02-28-2010, 04:50 PM   #203
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,786
Well there was a little progress this weekend with the bottom end back together, need to get the rest of it completed as I am running out of time.
I was standing looking at the bare cases and wondering how this all came apart? It was a little daunting, but I took a lot of pictures and used the spare parts book and took little steps. It is a straight forward process, the gearbox just fell in, well sorta.
Sorry about the pictures, taken with the iPhone as I forgot the camera
Airhead Tragic
Old 02-28-2010, 05:06 PM   #204
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,786
I dont need another project that soon
I like the idea of the GSX, what forks etc are you thin king of running?
Please start a build thread, you only have 4 weeks to make Wanaaring
I want to build one of these next.
Airhead Tragic
Old 02-28-2010, 06:43 PM   #205
desert dog
scrub basher
desert dog's Avatar
Oddometer: 1,124
not quite what I had in mind...........
your discription of an offroad chair 'needs a bit of polish'
cheers matty
PS. skunkworks
Trailer tyres are cheaper than bike tyres
desert dog is offline   Reply With Quote
Old 02-28-2010, 08:25 PM   #206
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,786
Thanks Matty, glad you have registered.
The Hand Cycle is a fitness thing for me. Not that Im in training for Dakar
My bike is in SO many bits, but it is close to going together on many fronts.
The forks need a spacer the be machined to carry the bottom steering head bearing, once that is on the headlight and instruments bars controls.
The swing arm will be extended this weekend, which will be great.
then once that has been reinstalled, put the motor back in and then lift the back end to get the correct steering head angle. Then the top shock mounts and seat sub frame need to be built and attached.
As OldDog kindly reminds us we only have 31 days
Airhead Tragic
Old 02-28-2010, 08:53 PM   #207
desert dog
scrub basher
desert dog's Avatar
Oddometer: 1,124
no worries mate, it's in the bag !!!
you'll do it easy
will see ya there !!!
spoke to Unc Gra 'all good' will be backing up these hillbilly boys. !!!
cheers matty
Old 03-01-2010, 01:44 AM   #208
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,323
Question for you Pezz,
how many people do you think would be building 'Adventure' type rigs out of 'roadies' due to being short arses like myself?
Or are they just up for a challenge [like me]
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 03-01-2010, 02:48 AM   #209
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,786
Gee . . . . . . tough one there.
Quite a number being built for various reasons. Another constraints come in here too. Like $$$
The questions you need to ask are;
What do you want to ride over and how fast?
How much gear you want to carry and how much fuel will you need?
Ted Simon rode an old Triumph around the world. He had to ride it accordingly.
I reckon you need to work out how much suspension travel you need at each end. 100 - 200 - 300mm? then work out the height you behind needs to be located above the ground. then work from there.
Below is a bike built by Paul Rooney. Is a R100 with a R65 seat unit and even the seat unit was lowered for a vertically challenged rider. I reckon its one of the nicest looking old airheads around. Its still on the road.
Airhead Tragic
Old 03-01-2010, 06:49 PM   #210
hunter_greyghost
Oddometer: 8,323
That's a nice looking unit, I like the idea and thought put into it,
Probably stick with what I know and like best, maybe down the track?
Thanks for the reply, gotta catch up with you one day,
Times are GMT -7.   It's 04:27 AM.
