Old 04-02-2011, 03:49 PM   #391
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,408
Busy day yesterday!!!
Finally finished the Tank and Coil brackets. Just need painting
Also got the Dyna installed and just need to tidy up the wiring which will take 10 minutes. All i need now is the tank taps and Im away
I have tred not to butcher the 400's frame so used 3mm plate for the tank supports.
Had to cut around a few of the frame tags.
Dyna S Installed
Pezz :)
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
Pezz_gs is online now   Reply With Quote
Old 04-03-2011, 05:24 AM   #392
OldDog
Smelly Adventurer type
Oddometer: 3,676
Lookin good mate! Can'twait to see this beast in acton Have you seen Tina's progress? Thats another nutso bike
"Never trust a man who, when left alone in a room with a tea cosey, doesn't try it on" Billy Connelly
1966 Norton Atlas "Ruby"
'09 KTM 990 Adventure
Boxes of XR600's and a psychopathic Ducati
OldDog is offline   Reply With Quote
Old 04-03-2011, 04:04 PM   #393
sabertooth_buterfly
Dinosaur Pirate
sabertooth_buterfly's Avatar
Oddometer: 358
Looking great Pezz, I am also looking forward to seeing this bike.
OldDog, this is the bike that inspired me to build sagy. I think everyone should build a project thats compleatly nuts at least once.
Life is an adventure.....live it while your alive....this is not a dress rehearsal
Whatever you dream do it now
If you love your motorcycle, let it go. If it comes back to you, you've high sided
sabertooth_buterfly is offline   Reply With Quote
Old 04-03-2011, 06:50 PM   #394
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,408
Its driving me nuts at present!!!!!!!!!!!!!
The Jolly tank has two holes for the taps, but the one on the right (in the pic below) looks like the guy used a very blunt chainsaw to make the hole.
I have cleaned it up with a file and have been using a tapered temp sender from a mini moke with thread tape and carefully screwing it in so as to not open up the hairline cracks above and below.
I has a minute hole/split and will not seal up and drips out a steady flow
I will need make up an alloy disc and insert an o-ring and a locating shoulder to seal using a bolt through from the tank and see what gives from there.
Pezz :)
Airhead Tragic
Old 04-27-2011, 03:48 AM   #395
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,408
Well if you have seen the Scrapheap thread you would have noticed Yajyuu didnt get far, running like a peach, fuel tank leaking like a siv
I had a bit of fun with an old 620LC4 rear guard to make a 'Rallye' fairing, Ice cream container hand protectors, but the Malcolm Smith Desert Tank split near the top tank mount and covered the high tension leads so no road trip ensued
I will be talking to a mate who builds alloy fuel tanks and sending him a nice chunk of cabbage for a new tank.
It will be sorted, really it will.
Finished here, not 20 feet later
Pezz :)
Airhead Tragic
Old 04-27-2011, 02:00 PM   #396
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,845
Got further than last time then
NordieBoy is offline   Reply With Quote
Old 04-27-2011, 02:50 PM   #397
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,408
Sure did
So have you finished yours yet??
Mine is running so well with the Dyna S and Dyna coils.
Think I might even fit up an XR650 front end I have here
Pezz :)
Airhead Tragic
Old 04-27-2011, 02:57 PM   #398
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,845
Originally Posted by Pezz_gs View Post
Sure did
Been waiting about 4 months for some engine mounts and bolts from a GSX400 twin to arrive, I'm hoping they'll fit with minimal mods.
Once the engine is in the frame I can start on the back end.
Also still need to check with the po-po and licensing people about whether I can actually get it on the road (legally).
Old 04-27-2011, 04:15 PM   #399
OldDog
Oddometer: 3,676
I reckon thats a bloody good idea mate, it should handle that extra weight a little bette than the XR250 ones which seem to be a bit spindley even on the 250
Dya have the 650 brakes as well?
By the way......work has commenced on the new scrapheap, i couldn't help myself
Old 04-27-2011, 07:20 PM   #400
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,408
Nope, just have the tripples, minus spindles and forks. $200 fork springs for the XR forks will go up in smoke.
I have to find a wheel and brakes and redo all the headlight and other mounts. It will be a big remodel with lots of new brackets etc. dont want to lose the look but.
Pezz :)
Airhead Tragic
Old 04-27-2011, 07:38 PM   #401
OldDog
Oddometer: 3,676
D'OH! I forgot to give you that YZ rim while you were here. Ah well, i reckon it won't be long mate and i'll be living just over the ridge from you and can drop it in when i stop by for a cuppa
Old 04-30-2011, 09:13 PM   #402
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,408
Well my 2012 Scrapheap (Re-build) preparations start today.
Since the latest, and very public, unsuccessful launch, I have been contemplating my navel flint and options to move ahead. Looks like it may be better to take 2 steps back and then on forward. I will scrap the Plastic tank! Relocate the coils to the original spot under the ntank, the get the second steel tank I have and take the whole bike to a tinsmith I have heard about via Glen Maisey, in Inverell.
After talking to Jock, I will get the steel tank modified with recesses for the forks and make it a bit bigger, about 20 litres. I have to head up that way in a few weeks so, it will be done sooner rather than later.
I am also about to start a DRZ400 rebuild, so look for another thread soon
Pezz :)
Airhead Tragic
Old 04-30-2011, 09:37 PM   #403
DRjoe
DRjoe's Avatar
Oddometer: 4,296
If you rode the bike up this way Pezz I'd make a tank for you and it would be a made from ally not that nasty rusty steel stuff.
You should come up here with the family and while your sunning yourself on the beach I would be happy to donate some time and materials to such a great cause
DRjoe is online now   Reply With Quote
Old 05-02-2011, 05:19 AM   #404
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,408
Joe that is a very generous and humbling offer!!
I know how much work would have to go into that!!
If the Nasty Rusty Steel tank doesnt make the grade, I will give you a call.
But if you would like a ride when its finished you are welcome!!!
Pezz :)
Airhead Tragic
Old 05-03-2011, 02:43 AM   #405
DRjoe
DRjoe's Avatar
Oddometer: 4,296
As long as your not worried about it looking pretty then It would only realistically take a day or so and it would be a fun project for me.
Like I said book a holiday up here with your family drop your bike off for a couple of days and it'll have a new tank when you pick it up.
(It would obviously only be a water tank but if you decided to put petrol in it I couldn't stop you)
Times are GMT -7.   It's 05:53 AM.
