Old 08-27-2009, 08:21 PM   #1
_DreamRider_ OP
Oddometer: 150
KTM Fuel line clamps
I searched this forum for "hose clamps" and really only found people asking for and talking about the special tool and where to buy the tool and clamps.
I am a new KTM owner, getting familiar with it, and need to replace the fuel line in one section. My question is - what is the proper way to remove the clamp that is on there now, without doing any damage to the line, in case areas where I will be reusing the line. I plan to just install hose clamps when reinstalling. Any trick to removing the ktm clamps, and any suggestions to what works best.
I know the ktm clamps are supposedly better but not worried about it, I dont want to order a tool or clamps.
Thanks.
_DreamRider_ is offline   Reply With Quote
Old 08-27-2009, 10:05 PM   #2
ABYSS
KTM
Oddometer: 1,198
The clamps are good but once I pulled mine off I went with spring clamps like what come on Comercial Lawn mowers. I went to a local John Deere facility and got the clamps they use on the comercial tractors they have three times the spring tension as typical residential mowers. They make all sizes fro 3/8in up to 3 in. for radiators. All you need a a pair of typical pliers to take them on and off and they have been working great for over 5 K miles.
Every question in life has an answer of YES OR NO
Maybe = NO
Keep life simple and enjoy it!
ABYSS is offline   Reply With Quote
Old 08-28-2009, 05:50 AM   #3
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
autoparts stores supposedly sell fuel injection clamps that wont tear the line. When changing the fuel filter on my 690 those little things were ridiculous to remove, but with the filter set they include new clamps that were actually ez to put on with the pliers from the tool kit. I had to carefully pull the clamp apart all the while thinking there has to be an easier way.
MookieBlaylock is offline   Reply With Quote
Old 08-28-2009, 11:07 AM   #4
Airhead
More human than human
Airhead's Avatar
Oddometer: 2,099
I replace those Oiteker clamps with high-pressure fuel injection hose clamps whenever I have to take one off. To get the Oitekers off you just have to pry/cut them with a pair of snips...just get it to open up enough that you can slide them off once the hose is disconnected. You can get fuel injection clamps at any auto parts store...they're cheap, too.
'05.5 KTM 950 Adventure
2008 KTM 450 EXC-R
All Orange, Baby!
Airhead is offline   Reply With Quote
Old 08-28-2009, 08:35 PM   #5
_DreamRider_ OP
Oddometer: 150
Thanks for your replies, I guess no trick to getting them off but pry with a pair of pliers or cutting off with some snips ......
Old 01-16-2013, 02:08 PM   #6
rossaduc
rossaduc's Avatar
Oddometer: 33
zip em off with dremel with fiber reinforced cutting wheel.
rossaduc is offline   Reply With Quote
Old 01-16-2013, 10:43 PM   #7
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,022
Really?? You're going to cut a 50 psi FUEL line with an abrasive (sparky!) cut off wheel? You're going to generate a lot of abrasive and sharp metal shavings around a fuel injection system that is very sensitive to debris? What's wrong with an axe?
Just take a pair of electrical side cutters and cut into the loop. Easy-peasy.
"Son, you can't do both"
Times are GMT -7.   It's 05:27 PM.
