01-14-2013, 10:15 AM
#1 |
Oddometer: 33
KTM and torque wrench
I debated putting this in the Garage section of ADV, but figured it's more specific to my KTM, so here it is...
I'm a relatively new 2006 950 Adventure owner and slowly gettting more and more confident maintaining her. I have been slowly building up my tool set, finding things I need along the way and trying to get a decent set together. I've been borrowing a torque wrench, but now need to get one myself. I'm hoping people here can offer some advice on a good wrench that will cover the various torque specs needed for our beloved 950. Any tips? Tricks? Advice that you can share to a noob? I'm in Canada but close to the border to maybe some tips for both sides of the border? I will pay for quality, but I'm also not made of money - always looking for a good deal. Ideally I would only need one (3/8 drive?) that will suffice for all my KTM wrenching needs (my sockets are 3/8 drive). I know the torque specs vary across the entire bike, so looking for something that will serve me best. Ideas? Thanks as always, Matthew.
2006 KTM 950 Adventure - Black, farkled, and Inuvik bound |
01-14-2013, 10:50 AM
#2 |
Oddometer: 1,079
Good question. I have the same issue. I have a basic Craftsman torque wrench that does not have a ratchet head -- a "Dr. Beam" style. It does not give you enough options for positioning when working on things like spark plugs in a bike with a trellis frame. Get one with a ratchet head.
I thought about this one: http://www.sears.com/craftsman-elect...4&blockType=G4 But the reviews are not so good. It's hard to find one that covers low torque values (15 newtons or so on plugs) and the higher range as well (90 newtons on the rear axle). I hope there are some good suggestions coming.
"I'd like to meet the joker who had the nerve to call this a road!" -- Walter Sigmann |
01-14-2013, 10:54 AM
#3 |
Not in the clique...
Oddometer: 6,822
Just my humble opinion...
I think two torque wrenches are a must, no matter what bike you own: a beam-style for the lower values, and a ratchet/standard for the higher values. For what it's worth, all of mine are Craftsman, and have served me well... EDIT- If you absolutely needed a ratchet-style, for the lower values, you could consider one in inch/lbs, and do the conversion. However, "conversions" could be a great way to screw-up the math, and snap some parts. .
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO") "There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8 |
01-14-2013, 11:06 AM
#4 | |
toda su base
Oddometer: 422
With a 1/2-3/8 and 3/8-1/4 adapter, I can work on all my vehicles.
01-14-2013, 11:11 AM
#5 | |
Oddometer: 6,822
Now that is nice. I have an older "in/lbs" TW, but it doesn't have an N/m scale. I haven't used it in years (I believe it's stuck in the bottom of one of my rifle cleaning boxes.) Whenever I need a wrench for the smaller values, I've just gotten used to grabbin' the beam-style... .
01-14-2013, 11:39 AM
#6 |
Oddometer: 46
Canadian Tire has the 1/2" and 3/8" drive torque wrenches for 60-70% off regularly. Just watch the flyer!
01-14-2013, 12:06 PM
#7 | |
Oddometer: 493
'06 950S Adv, DRZ440E, KLX440R, DRZ250, & F650GS
01-14-2013, 12:19 PM
#8 |
For "usual" maintenance you mostly need a low-range torque wrench (6-20 Nm), might be useful to have also one that covers up to 100Nm or so (head bolts, shock bolts, sprocket etc) but you can live without if you have some experience on wrenching (and if you don't plan to remove cyl. heads)
I'm not extremely picky about torque w., so a decent quality wrench (lets call it 'good deal') is okay, invest the extra money on sockets and spanners. |
01-14-2013, 12:29 PM
#9 |
Oddometer: 185
Torque wrenches are very personal and depend on your budget. But you will need 2 wrenches to cover a large range of torques. Look at the torque list of the bike you have.
For regular maintenance, make sure you have the total range of 6 Nm to 90 Nm covered. (90 Nm for rear wheel). Everything below 6 Nm is just handtight with a screwdriver without lever. For more advanced maintenance the range should go up to 150 Nm (or 180 Nm with older models). A torque wrench is typically less accurate at the lower end of its range, so try to avoid that. It's best that you chose the torque wrenches such that they have some overlap in their respective ranges. |
01-14-2013, 01:09 PM
#10 |
Oddometer: 298
I really like the "click stop" type.
I would buy the best you can afford, and if possible you can test it against a friends for consistency or better yet find one that had recently been calibrated. I also learned a trick from cjracer (craig) to paint mark your bolts after being torqued that way trail side you can take a good guess at how tight by lining up the paint marks when there is no torque wrench available. This is very helpful on any bolts used in changing tubes from flat tires and chain adjustments, but I also mark everything else that gets torqued and just at a glance can see if something is working loose from vibration. Matthew
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo- 2006 KTM 950 ADV S http://www.mdfeditions.com/ http://www.cjdesignsllc.com/ |
01-14-2013, 02:35 PM
#11 |
Slabbing it
Oddometer: 786
I saw this last night while perusing. Might just work for you.
http://www.advrider.com/forums/showt...=Torque+wrench
49 Hudson - 72 Yamaha - 74 Caravelle - 00 Honda - 03 Chevy - 07 KTM
01-14-2013, 02:37 PM
#12 | |
Oddometer: 673
I have the same set-up works awesome and you use them way more often than you'd think if you work on a bike or six.
_______________________________ 06 KTM 950 Black 11 HD Ultra Limited Sunglo Cherry Red & Merlot |
01-14-2013, 06:40 PM
#13 |
Oddometer: 267
I'm looking into purchasing a torque driver. I found some on amazon that range from $50 to $200. I believe this is the ideal tool for all of the M5 screws on the engine case.
01-14-2013, 09:34 PM
#14 |
Oddometer: 146
You'll need two IMO. I personally own three... At the very least you need a foot pounds with a good range and a small inch pounds. I like craftsman, I own a Husky as well and have been very happy with the quality.
2010 KTM 990 Adventure 1978 Harley FX cut down |
01-15-2013, 10:03 AM
#15 |
Oddometer: 33
Thanks for all the advice! Great to have all your opinions to confirm what I had thought - that likely 2 tools are needed to service our wonderful machines.
Thanks too for the tip of one for sale in the classified. Love this forum Thanks all Matthew.
