Go Back   ADVrider > Riding > Layin' down tracks > GPS Tracks - West & PNW
Old 09-02-2009, 12:01 PM   #1
dmulk OP
dmulk's Avatar
Oddometer: 140
Thumb Big Bear Area GPX files?
I could use some good ride suggestions for the Big Bear area. I'm planning to be at my place in Crestline with a few inmates this weekend. We are all n00bs so those routes would be prefered. 80 to 200 mile range would be idea.
Any suggestions?
Cheers!
PS: My email is dmulk 'at' yahoo.com
PPS: I have a Garmin and Mapsource
dmulk is offline   Reply With Quote
Old 09-02-2009, 06:07 PM   #2
Countdown
Oddometer: 3,971
Any suggestions?
Cheers!
All depends on riding skill and what kind of bikes. There are killer rock trails (see Big Bear Trail Riders Dual Sport ride report) and great road rides.
Jerry Counts
Countdown is offline   Reply With Quote
Old 09-03-2009, 11:18 AM   #3
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,106
.......Big Bear area.........We are all n00bs so those routes would be prefered.
Attached a set of "lollipop tracks" that may fit the bill for your noob ride.....I just took a group up there last weekend to ride the southern loop....a few pics of the single track (Belly Ache Springs Rd.) on the southern loop can be found here:
http://www.dualsport-sd.com/forums/i...showtopic=5454
Track file description = ~50 mile south loop......~35 mile north loop.......threw in one short single track on both loops.......wouldn't suggest southern single track for big bikes and/or really new riders......northern single track is no big deal for anyone......it just breaks up the monotony of riding fire roads.....
As Jerry replied, there's lot's of stuff in the area......the attached file is just meant to be a one day/~85 mile/easy "sampler" of areas south/north.
Lot's of other noob stuff in Holcomb Valley.......or ride back and forth to Pioneer Town.....search for tracks on GPSXchange.....
EDIT: a few stretches are closed off now........IRRITATING.......but still easy to find a work around if you have a decent mapset in your GPS
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy screwed with this post 05-26-2010 at 12:09 PM
Crawdaddy is offline   Reply With Quote
Old 09-11-2009, 07:57 PM   #4
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,106
Pinnacles Loop - Arrowhead
For the more advanced class ......50 mile loop from the Pinnacles staging area......run it in either direction (though we generally go counter clockwise)....easily accessible from Crab Flats and Big Pine Flat camping areas.....have fun
EDIT: There are a few closures on this loop now.....IRRITATING......but still relatively easy to find a work around if you have a decent mapset in your GPS
Crawdaddy screwed with this post 05-26-2010 at 12:12 PM
Old 09-11-2009, 08:20 PM   #5
Countdown
Oddometer: 3,971
I would start with the CTUC (Calif Trail Users Coalition) maps for Big Bear. You may get it a the Jawbone Station or on line at Friends of Jawbone.
Jerry Counts
Old 09-13-2009, 09:46 PM   #6
focallength
patty cake champion
focallength's Avatar
Oddometer: 3,393
no GPX files but maybe this can help.
http://www.fs.fed.us/r5/sanbernardin...d_bigpines.pdf
http://www.fs.fed.us/r5/sanbernardin...actusflats.pdf
http://www.fs.fed.us/r5/sanbernardin...an_jacinto.pdf
I know the Sanberdoo OHV trails well, if you need some route sugestions just PM me.
focallength is offline   Reply With Quote
Old 05-26-2010, 12:03 PM   #7
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,106
Another Advanced/Half Day Loop
Another set of tracks from this past Sat for the advanced class....
Trip Report: http://www.dualsport-sd.com/forums/i...showtopic=7577
I edited my active tracks and started Track 01 at the AM/PM Arco at Stansfield cut off on Big Bear Blvd………park somewhere in the vicinity and brim the tanks because you’ll be spinning/using low gears
We ran into a few closed trails which are marked with waypoints. Irritating but irrelevant (now) since the tracks will lead you on some other nearby trails we took instead
We came across two downed trees which are marked with waypoints (hopefully they'll be removed by the time many of you use this file)……the first one could be ridden over if someone headed out there with a chain saw to remove a few branches.......until that happens, it can be cheated by swinging up high to the left around the tree…….the second downed tree can be cheated by cutting hard right and going up and around it……the upside is the first one is keeping jeeps off John Bull at the moment
Total track distance is ~76 miles…..don’t be fooled by the shortness of the loop……..it’s a good ~6 hour ride when you factor in rest stops, jeeps in the way, etc......
Keep track 3 turned OFF on your map until you reach Delamar (to avoid any confusion where the tracks intersect)
Have Fun!
Crawdaddy screwed with this post 05-26-2010 at 12:15 PM
Old 06-04-2010, 06:45 AM   #8
DUTOMI
Fanatic Angler
DUTOMI's Avatar
Oddometer: 85
Looks like a cool loop. I 'll give it a try this weekend. should be a good way to figure out the gas milage on my new 450.
'10 KTM 450 EXC (WORLD CHAMPION EDITION)
'08 DUCATI HYPERMOTARD
'07 KTM 300XC
'98 BETA 250 TECHNO
'79 YZ400 (Ready to Race)
DUTOMI is offline   Reply With Quote
Old 05-08-2012, 07:21 PM   #9
dirtdiver
Oddometer: 1,859
I may try this on Saturday. Anyone interested to join me?
DD
04 CRF230F
06 CRF250x
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
dirtdiver is offline   Reply With Quote
Old 12-18-2012, 12:26 AM   #10
gulley cruiser
Oddometer: 2
i like this version of a map
i use this mapName:  riding in big bear.jpg
gulley cruiser is offline   Reply With Quote
Times are GMT -7.   It's 12:58 AM.
