Old 09-04-2009, 04:04 AM   #1
Autostream OP
Autostream's Avatar
Oddometer: 5,833
Sherco behind a KTM
Today my wee project became officially finished, well all except the registration that happens next week.
Autostream screwed with this post 09-04-2009 at 04:36 AM
Autostream is offline   Reply With Quote
Old 09-04-2009, 04:13 AM   #2
Autostream OP
Autostream's Avatar
Oddometer: 5,833
Treg style coupling to allow bike to go offroad... or more likely, me to fall over.
Hitch is made from 12mm steel.
Was going to mount it to where the center stand was mounted, but stand is so strong figured I woudl just attach to that.
Whole hitch can be off in less than 3 minutes.
Trailer with bike and gear weighs in at about 200 kg
Feels a little weird at slow speed, but seems to quiclky settle down over about 10-20kmh... but have yet to give it agood run.
Old 09-04-2009, 04:25 AM   #3
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 14,684
Sensational stuff Auto..
It looked good when I saw it the other day but it looks even better finished.. Well done..
Just as a thought, what have you done to steady the KTM when loading the Sherco?? I`d imagine it would push the 990 off its side stand if you pushed the bike onto the trailer too hard..
nevgriff64 is offline   Reply With Quote
Old 09-04-2009, 04:31 AM   #4
Autostream OP
Autostream's Avatar
Oddometer: 5,833
Actually I thought that, but stood on the very back of the trailer, I weigh about 30kg more than the Sherco and all it did was lift the back wheel off the ground a little.
Much more stable than I expected.
Old 09-04-2009, 04:43 AM   #5
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 14,684
Excellent..
Look forward to seeing the finished product on Sunday..
Old 09-04-2009, 04:09 PM   #6
Autostream OP
Autostream's Avatar
Oddometer: 5,833
Excellent..
Not this Sunday as I couldn't get a registration apppointment until Wednesday.
It is only a small trailer and would be exempt, but being wider than the towing vehicle means it needs to be registered.
Old 09-04-2009, 07:47 PM   #7
grizzzly
The Pre-Banned Version
grizzzly's Avatar
Oddometer: 3,432
Nice I have been thinking about doing the same thing with my 650L
you actually expect people to take responsibility for their actions in today's society?!
grizzzly is offline   Reply With Quote
Old 09-04-2009, 09:01 PM   #8
harcus
harcus's Avatar
Oddometer: 1,333
Autostream
Is this style coupling common in AU? Production? Home made?
Nice work!
JLH
harcus is offline   Reply With Quote
Old 09-04-2009, 09:26 PM   #9
Autostream OP
Autostream's Avatar
Oddometer: 5,833
Common for off road
Old 09-08-2009, 07:37 AM   #10
PTRadam
Oddometer: 504
Good work man! We have a guy here in PA that hauls his trials bike on a side car on his Harley!
PTRadam is offline   Reply With Quote
Old 09-08-2009, 10:46 AM   #11
ct-ktm
Oddometer: 3,433
Sweeeet...
ct-ktm is offline   Reply With Quote
Old 09-08-2009, 09:13 PM   #12
Autostream OP
Autostream's Avatar
Oddometer: 5,833
Initial ride report.
Rides like having a heavy novice pillion on the back, except it does not squash the suspension down.
U turns - no probs
Up and down curbs and slow maneuvering - a little wobbly but soon get used to it, speed and looseness is your friend, sort of like riding in sand (to a point)
General riding - much like the feel of towing a laden trailer behind a car, just need to use care when braking etc.
Harder braking - could feel the trailer trying to pick one side then the other as the brakes were fed on hard from about 80k / 50 mph, not an issue if you are familiar with riding slippery surfaces off road but may be scary for street only riders.
Slippery surfaces - I found a factory construction site, excavated clay and it was wet (not my brightest idea for the day) and tried crossing it slowly. Trailer wants to push the front wheel around, but as long as you steer with the pegs and body weight it is not an issue, try steering with the bars and you'd probably be on your butt fast.
Have yet to try the freeway, that happens this weekend. But if it has a propensity to wobble or weave I will be shifting the axle back about 8". According to the trailer supplier this is common when using this trailer behind bikes and improves the handling.
Old 09-08-2009, 10:31 PM   #13
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,803
Would some sort of electric brakes be a good thing for the trailer: Also I find that the longer the arm on the trailer is the less tendency to wobble from side to side (in a car at least).
Cool setup.
Seth S
Seth S is offline   Reply With Quote
Old 09-09-2009, 09:57 PM   #14
NMTrailboss
Team Dead End
NMTrailboss's Avatar
Oddometer: 6,449
Awesome set up! The best of both worlds!
NMTrailboss is offline   Reply With Quote
Old 09-12-2009, 06:30 AM   #15
RedRider3141
277cc's of FUN!
Oddometer: 44
EPIC WIN!
Current: :'(
Past: '75 XL175, '82 XL250R, '83 FT500 Ascot, '94 XR280L, '00 XR400L
RedRider3141 is offline   Reply With Quote
Times are GMT -7.   It's 02:50 PM.
