Old 09-11-2009, 08:21 PM   #1
Dr. Zombo OP
ADV Brewer
Dr. Zombo's Avatar
Oddometer: 193
Marvel Mystery Oil?
I have a neighbor who swears by this stuff. Uses it in his truck, lawn mower, 2 stroke weed whacker, etc. -- some in the gas tank, some as part of his oil changes.
What's the real story on this stuff? Is it really a marvel?
<-- snake-oil salesman
'09 Suzuki DR-Z400S - Sin Nombre
'08 Sachs X-Road 125 - Tiny Terror
Originally Posted by DDACT
When our tires would wear into the steel belts we'd refer to the little wires sticking out as 'Traction Spurs'
Dr. Zombo is offline   Reply With Quote
Old 09-11-2009, 09:11 PM   #2
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,977
I've read lots of stories and they sound about as convincing as Slick 50 commercials.
Support the AMA.
Waco is offline   Reply With Quote
Old 09-12-2009, 12:38 AM   #3
rens
F650gs, r90s, London UK
rens's Avatar
Oddometer: 35
I use it regularly on my boat (which as a 1968 atomic 4) and its great for lay-up and recommissioning, but I don't get the people who want to add it to everything.
I dont use it on the bike.
rens is offline   Reply With Quote
Old 09-12-2009, 05:55 AM   #4
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,391
http://www.advrider.com/forums/showthread.php?t=500407
http://www.advrider.com/forums/showthread.php?t=6994
http://www.advrider.com/forums/showthread.php?t=491919
http://www.advrider.com/forums/showthread.php?t=36652
http://www.advrider.com/forums/showthread.php?t=358018
http://www.advrider.com/forums/showt...php?p=10514043
http://www.advrider.com/forums/showthread.php?t=362581
These were just the treads that popped up immediately......
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman screwed with this post 09-12-2009 at 06:12 AM
Boatman is offline   Reply With Quote
Old 09-12-2009, 11:42 PM   #5
duckrider
duckrider's Avatar
Oddometer: 993
I've used it for years to lube my air tools. Just a drop in the connector. I've had many of them for twenty + years so I'd say it's fine for air tools. I have no idea where I'd use it on a bike.
duckrider is offline   Reply With Quote
Old 09-13-2009, 09:26 AM   #6
usgser
Oddometer: 2,237
Years ago back when most of the vehicles(cars/trucks) I ran were from the 50's and 60's and folks weren't as anal about oil changes as they are now I used to use it a lot. I'd substitute one pint MMO in every oil change. Great for freeing up sticky lifters. Never used it in a bike though. But agree it's a great lube for air tools too.
usgser is offline   Reply With Quote
Old 09-13-2009, 12:11 PM   #7
eric123
Gott Mit Uns
eric123's Avatar
Oddometer: 1,495
Gas and oil maybe? I use it in all my bikes...I will try it in my air tools, sounds like a good idea...
eric123 is offline   Reply With Quote
Old 09-13-2009, 12:14 PM   #8
acejones
acejones's Avatar
Oddometer: 5,274
Many years ago I worked in the assembly shop at a major chain saw manufacturer. We used MM in the air lines for our air tools and had very few tool problems. It is a great product for that application.
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 09-15-2009, 05:40 AM   #9
biggziff
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,633
A good discussion here including what is in MMO
http://www.rx7club.com/showthread.php?t=689158
"Fools you are. To say you learn by your experience. I prefer to profit by others' mistakes and avoid the price of my own."
- Otto von Bismarck
biggziff is offline   Reply With Quote
Old 09-15-2009, 08:31 AM   #10
Dr. Zombo OP
ADV Brewer
Dr. Zombo's Avatar
Oddometer: 193
That was quite the enlightening read. Thanks for the link, biggziff.
Old 09-15-2009, 10:06 AM   #11
biggziff
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,633
- Otto von Bismarck
Old 09-15-2009, 10:14 AM   #12
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,563
+1
FWIW, MMO has been a tradition in our family for a bajillion years, it hasn't hurt anything, the container is cool, and it's cheap so I will keep throwing a tables spoon in the tank of my bike - prolly isn't doing anything, but I reel better!
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 09-17-2009, 05:27 AM   #13
Toolman
toolman
Toolman's Avatar
Oddometer: 120
Mmo
Marvel mystery oil makes the air tool oil for Snap-On Tools and other tool mfgs. Heres a thought about oiling your air tools. When do you oil them? Most people say they put a few drops in the air inlet when they are ready to use them. Wrong time! You should oil them right before you put them away. This way they are stored with oil inside instead of moisture from the air line!
MMO is a good product with many uses much like WD40.
Toolman retired after 26 yrs!
Toolman
KTM 530 exc
KTM 950 Adventure S
KTM 250xcfw
Husaberg 501
Husqvarna 430WR
Toolman is offline   Reply With Quote
Old 09-17-2009, 05:43 AM   #14
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,756
Sounds like my dad.. I think he even puts it in his oatmeal...
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
KTMSER is offline   Reply With Quote
Old 09-19-2009, 12:05 AM   #15
Beezer
Oddometer: 5,849
I have a 30 year career as an aircraft mechanic & this question comes up a lot. I contend that it does no harm and may have benefits. MMO is an old time product that was used on radial aircraft engines for an number of reasons.... such as relieving sticky valves (I have seen it work for this). I know more than a few pilots that use it regularly in the fuel & oil (on modern engines), and generally speaking these engines run strong and trouble free, with good compression all the way out to overhaul. I have a collegue that owns an aircraft engine shop & is pro MMO for the above reasons. Notice on the link above that the stated downside to MMO is that it might loosen too much residue. Couldn't it be said then, that if used regularly... you might not have residue in the first place?
At any rate, it is quite popular in avaition even though it is not "approved" (by the FAA). I use it once in a while but am not a fanatic.
Beezer is online now   Reply With Quote
Times are GMT -7.   It's 09:31 PM.
