Old 09-10-2005, 02:27 AM   #136
Slimie
Oddometer: 1,080
Originally Posted by Possu
Just nudging you towards the path of two wheeled righteousness.... Won't be long before the subliminal message takes effect & you're dreaming of sticky out cylinders,ABS woes & final drive failures.............
Slimie is offline   Reply With Quote
Old 09-10-2005, 05:25 PM   #137
gas_pig70
Mmm... mud!
gas_pig70's Avatar
Oddometer: 1,407
Dang, I'd have one in my garage already if only they were available here. I'm guessing I'm not the only one in the U.S. who feels like that.
'07 Speed Triple 1050 | '08 WR250R
"'Course, don't ever tell anybody that they're not free 'cause then they're gonna get real busy killin' and maimin' to prove to you that they are." -George Hanson
gas_pig70 is offline   Reply With Quote
Old 09-13-2005, 12:57 PM   #138
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,250
Oh F Me. Those are some of the coolest bikes evah! Makes you wonder if the Adventure 950 didn't start off as a wish list AT. . . .
hillbillypolack is offline   Reply With Quote
Old 09-20-2005, 02:52 PM   #139
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,030
atgreg is offline   Reply With Quote
Old 09-27-2005, 01:27 PM   #140
Pjotr
Keep it rolling!
Pjotr's Avatar
Oddometer: 9
A few pics of my baby. A bought the bike this year after 15 year without a bike and I really loves it.
Road to Juvashytta in Norway
After a fun day at Bukkerittet rally in Norway
Favourite route close to my home in Sweden
Living in the westcoast of Sweden
Pjotr is offline   Reply With Quote
Old 09-27-2005, 02:38 PM   #141
modrover
BOOMSHANKA!
modrover's Avatar
Oddometer: 3,576
Nice one!
~Michael (of The Land of Misfit Land Rovers)
Had an Africa Twin and Transalp
X-Files Gov't Issue Sprinter TurboDiesel
Series IIA 109" Land Rover Deluxe Station Wagon
Washougal, WA USA
modrover is offline   Reply With Quote
Old 09-27-2005, 02:47 PM   #142
2tallnwide
2tallnwide's Avatar
Oddometer: 2,572
Thanks for all the great pics...
I saw my one and only AT at the Honda dealer in Dubai in 2002...and yes I lusted after it, pics just don't do the bike the justice it deserves. I wasn't aware they quit making them in 03, I wish I would have tried a little harder to get the bike and have it shipped home....although I know a couple guys that did that with HD's several years apart and both of them said never again, ummm not buy a HD but having it shipped to the States ...what a royal PITA that was for them.
Good luck to anyone attempting that venture!
If you're gonna dish it out make sure it tastes good.
http://www.youtube.com/watch?v=zBkh6lrOfT4
2tallnwide is offline   Reply With Quote
Old 09-27-2005, 03:14 PM   #143
GSPD750
GSPD750's Avatar
Oddometer: 1,455
Facet fuel pump install on '99 Africa Twin
This is also posted over at XRV.org.uk.
I have had my share of fuel pump woes in the past on my '99 @ and now I feel I have finally solved them with the recent install of this US made solid state Facet pump. Model # 40105
The orginal OEM pump failed after the contacts burned out. Probably not a 'bad' pump once it was modified for a suppressor to prevent the contacts from pitting. But the new OEM pump does not come cheap. $$ Alternative? Yes.
Next...the nice people at African Queens sent me the Mikuni vacum pump.
It seemed to be the answer, and after a few thousand kms it was performing flawlessly. Then it seemed in hot weather conditions I would experience fuel starvation symptoms. Fuel was somehow bypassing and blocking the vacum source..apparently. The 'T' fitting trap mod from AQ
did not seem to work. It was from the South African AT Club that I first heard of the Facet pump.
Ok, for only $29 USD plus shipping I can experiment. The first model of pump I ordered was #40106. The claimed pump pressure on this model
is 4-6 psi. Nothing in the packaging or on the pump indicates this. Strange that they do not. Another web source claims the pump pressure is 4-5.5 psi. I quickly installed this pump (hot wired) for a rally I attended.
After 2,000 kms round trip it worked perfectly. Having not yet hard wired it to the fuel cutoff relay I occasionally would forget to unplug it (as it was wired direct to the battery) and after shutting the ignition off the pump would continue to run and fuel would spew out the carb overflows via the drain tube onto the ground. No problem, once I permanently hard wired it it to the fuel cutoff relay that fuel spill would be eliminated.
I now permanently hardwired the model 40106 in and drove it hard and fast. It was then I noticed a small amount of fuel coming from the carb overflows when idling at a stop. Mmmm....It was small enough to piss me off and it was telling me this pump pressure is just a wee bit on the high side.
Ok, I now ordered in the Facet Model # 40105. Claimed pressure is 2.5 - 4.5 psi, depending on the web source, I have also read where pressure is 2.5 - 3.0.
Again, nothing on the packaging or pump indicates pressures. In fact the
models 40105 and 40106 are "identical" in appearance and markings.
Time to install the 40105.
The pump measures less than 3" in any direction and weighs in at 18 oz.
Lets cut off the pump mounts which are not req'd.
Sand off any sharp edges.
Well ain't that special. The OEM pump rubber shock mount fits right over the Facet pump. Its a tight fit but it can be done. A little silicon spray on the rubber eased the installation.
Lets slightly bend the mounting supports upwards and downwards on the frame to accomodate the Facet.
To install you simply push it onto the supports. Views are fuel "IN".
Fuel "OUT"
Fittings are 1/8" IPT
Connecting the wires is straight forward. You can use your old connector
from the OEM pump and splice it in. Fuel hoses have to be shortened
accordlingly. I have only a few hundred kms on the 40105 and so far I am very pleased with the performance and no overflow spillage. In the USA this pump can be sourced at Aircraft Spruce & Specialty in the state of Georgia or CA.
http://www.aircraftspruce.com/catalo...facetpumps.php
So, just thought I would share with what works for me. And of course, the usual disclaimer.
Wayne
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 09-27-2005, 04:34 PM   #144
modrover
BOOMSHANKA!
modrover's Avatar
Oddometer: 3,576
Wayne... thanks for posting. Be sure not to "move" those photos or delete them as they make for a great how-to.
I've not even looked at the one on my RD03. I know all the bad press on 'em... I'll probably order up one of those pumps at some point. Hopefully it won't be when I'm really F'd and in need though.
Washougal, WA USA
Old 09-27-2005, 05:05 PM   #145
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Way to go WAYNE
I've read up on the Facet also on the XRV-UK site. You really clarified the install. I'm getting a pump tomorrow. Thanks for posting it.
Jim.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 09-27-2005, 09:18 PM   #146
GSPD750
GSPD750's Avatar
Oddometer: 1,455
Hey Mod,
The cover comes off the OEM pump quite easily for inspection of the contacts.
If yours are showing "peaks and valleys" then I'd suggest you rip it out
now before it strands you. My OEM did...luckily it was not far from home and the truck ride was short.
Old 09-27-2005, 09:29 PM   #147
GSPD750
GSPD750's Avatar
Oddometer: 1,455
Hi Jim,
Congrats on the AT purchase. Nice look'in one too.
You sold me a pair of Galfer Green pads and an SS line
awhile back for my GS. Nice improvement...and the GG pads
seem to last forever.
Yeah, the Facet is the way to go. Nice price too.
...later
Jim.
Old 09-27-2005, 09:52 PM   #148
modrover
BOOMSHANKA!
modrover's Avatar
Oddometer: 3,576
Originally Posted by GSPD750
Hey Mod,
Good advice on that. I'll have to find out if the XRV650 uses the same pump part number as the XRV750. I know flow rates and such can vary.
Hey, my fuel pump part number is 16710-MS8-005 (this number could be an old number that has been superseded though). Is this the same part number for the fuel pump on your XRV750?
Washougal, WA USA
Old 09-28-2005, 12:07 AM   #149
GSPD750
GSPD750's Avatar
Oddometer: 1,455
I believe 16710-MAY-305 applies to my RDO7. Probably pretty close in comparison to yours...but I can't be sure.
Old 09-28-2005, 05:13 AM   #150
Slimie
Oddometer: 1,080
That's a really nice job, I'll have to inspect mine soon if only for reassurance. Can the part of this thread detailing the pump installation be transplanted into the "Wisdom" forum?
Thanks, Wayne, for such a clear explanation and great photgraphs.
Cheers
-Simon
Times are GMT -7.   It's 02:05 PM.
