04-10-2008, 02:13 PM
#1501 |
It's a short cut, really
Oddometer: 4,268
Hey G.
I almost snapped that guy up when I first saw the CL ad. Because I'm in the peoples repulic of Kaleeforneea, I figgured registering it with an old FL title would be too troublesome and I didn't want to physically harm any DMV workers. Hopefully your state is a bit more liberal when it comes to getting a plate. Happy the bike it going to someone who appreciates it. Some Transalp parts will fit. The RD04 side panels will fit but the RD03 had a bit of a different paint scheme and, I think, a different way to mate the side panels to the front fairing. The words "Africa Twin" that are totally on the RD04 sidepanels are partially on the tank of the RD 03 so paint doesn't match between the two models. To be honest, I like the 03 paint better. A total change to a RD04 front end would require a new front fairing support bracket since the front fairings for the 03 and 04 were a bit different. Instruments are the same. The 04 front fairing also uses a different windscreen than the 03 but these are available from Twisted Throttle. If the bike has the original fuel pump, this may be a source of trouble. Many guys have replaced it with a Facet electric pump. I've had good luck with the vacuum operated Mikuni. You will also probably find clogged pilot jets. The TA uses #38 pilots but I think the 03 was a bit bigger. Maybe check the xrv.org.uk site for the right numbers. Clean or replace as necessary The rear side panels and rear subframe for the 03 and 04 are also different but I think you were mainly concerned with the front. Who knows......Zebra might just grow on you. I think the bike will look better in person than in the photos. Let us see the bike once you get it....I sure wish one would turn up with a CA plate already on it. |
04-10-2008, 02:23 PM
#1502 |
Oddometer: 4,268
....also.....
If it were me, as eager as I'd be to ride it, I'd choose to trailer the bike home. This will help you be patient. Since it hasn't run for a few years I would: Drop the old oil....do oil and filter change Drop the old coolant and replace Open and check the airbox and filter. (One "barn find" I bought a few years ago actually had a family of tiny critters living in the airbox...the bike didn't want to run on straw and bits of cotton) Pull the plugs and run the starter motor without resistance for a couple of minutes to circulate the new oil through the cylinders, head and cams Drain old fuel (and maybe water condensation since you're in THAT part of the world) and fill er up with good gas. Try to start it then but don't be disappointed if it doesnt' run without the enrichener since the pilots are probably gummed. Pannier mounts and most everything for the RD07 won't fit the RD03. The rear 1/2 of the frame on the 07 is very different. I don't think bag mounts for the Transalp will work either since the 03 has a rear "sub-frame" hung off the back that the TA does not have. |
04-10-2008, 02:55 PM
#1503 |
Africatwinarama
Oddometer: 9,761
Buy it !!!, the RD03 is the pick of the AT's as far as Im concerned , I owned one for a while at the same time as my RD04. The 650 is only a tinny bit slower and is noticeably lighter and better on fuel. I only kept the RD04 as Im a big bloke and it's a bit bigger than the 650 and suited me.
All the Hawk 650 hot up parts fit the engine as well. Parts are a little bit harder to come by than the 750's but there is still a lot floating around. Search ebay Germany direct, many dont list posting OS as an option so wont come up in a US search but if you contact them a lot are happy to post OS. AT's are still a bit of a cult bike in Europe so parts on ebay sometimes go for amazing prices. Welcome to the club
1990 RD04 Africa twin 750 350,000km and still going strong |
04-10-2008, 03:02 PM
#1504 | |
That ... Umm ..... "Dude"
Oddometer: 5,260
It's a pleasure to finally be part of it ........
03 Caponord "The Funness out-weighs the Dumbness ....." - Mr. Jetmoto |
04-10-2008, 03:08 PM
#1505 | |
Oddometer: 5,260
When I got my 92 TDM, I didn't check the hoses ...... did everything else ..... well, about 6 weeks into having it, I was working on it, just moved one of the fuel hoses, and the damn thing cracked right there in front of me, and I just had gas F'ing spewing everywhere ....... Since then, I've made it a point to do a real good once over on every bike I obtain ............ Pics will be coming soon .......... G.
04-10-2008, 04:26 PM
#1506 | |
Now what?
Oddometer: 2,248
![]() Jim. |
04-11-2008, 12:55 AM
#1507 |
Oddometer: 4,268
LOOK WIDE !!
Good Grief Jimmy, it IS wide!! Good thing you Colorado guys can't split lanes (the ONE good thing about riding a bike in CA other than the ocean, the mountains, the desert and lots of badly maintained roads)....you sure couldn't do it with those bags on I think there is actually room for another bag between the bike and the bag...if you know what I mean. With all your welding and fab skills, I'd expect those guys to be just barely kissing the body work. I guess you could actually put the bike on its side and sit out a snow storm under it.......hey is this more lashing?? I'm up way too late. |
04-11-2008, 12:57 AM
#1508 |
Oddometer: 4,268
....hey Jim....is that a Acerbis roadbook holder on your bars? I just got two of them from Jason at MX1West.
Having a bit of trouble with the rollers being tight and it trys to rip the paper apart before it actually rolls. Any tips?? |
04-11-2008, 06:21 AM
#1509 | |
Loco, pero no estúpido!
Oddometer: 2,266
Rd03
So you bought it....If you change your mind, tell the owner to stow it on the boat and bring it down to the caribbean that I'll buy it!!! Never mind, just kidding.
Go for it and don't look back. I own a TA and did the AT conversion from an RD03. eBay France is the other possibility to get parts and accesories, and they are willing to do business with you. I noticed that most of ebayers from France accept Paypal, which is less expensive for transfering funds. Before doing the carbs, take out the petcocks and clean the screens. Be careful when removing the tank, because there are two fuel sensors connected. There is also a fuel pump and an inline filter after the pump that deserve an inspection or replacement. Go to www.xrv.org.uk and there is a bunch of info and the manual for you to have fun!!! Welcome and go riding soon! Quote:
Carlos locorider 1989 Honda XL600V Transalp, slightly modified! 1974 Catalina 22....sailing, mi otra pasión! "If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian "Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller Longaniza Ride Ruta del Café |
04-11-2008, 06:29 AM
#1510 |
Barrus Vegrandis
I don't have the Africa Twin anymroe but used to and absolutely loved it, my first taste of the big go anywhere machine!
But the even bigger KTM is definitely an upgrade!
Veni, vidi, velcri. |
04-11-2008, 06:30 AM
#1511 | |
Now what?
Oddometer: 2,248
My outriggers... I mean Gobis will be relocated this summer under the wide ass protection plan. Jim. |
04-11-2008, 06:32 AM
#1512 |
Oddometer: 4,268
Check the Transalp Mod thread for photos of the uber-cool TA/AT side panels that Carlos made. Since you might be doing a repaint anyway...now is the time to consider that mod.
Carlos probably has photos of the RD03 front fairing bracket, and I have one of the RD04 bit if you want to compare the two. Lotsa help here between the two threads.....tomorrows the BIG day....Gluck....oh yeah, it's a good idea to have someone else safety check the trailer chains and the bike tiedowns.....if you're like me you'll be too excited and let something slip. |
04-11-2008, 10:18 AM
#1513 | |
Oddometer: 5,260
With that said, you mentioned that you didn't have time to put your spin on it ...... does that mean you do fabrication and / or altering? Because if so, maybe we could work out some sort of deal, that if I procured some HB hardware, you could alter it for me, for a fee of course. A friend of mine in town is a fabricator, and rides, but he's never had an AT, where you are knowledgable with them ..... What do you think? Oh - and even though they're wide - your bike looks sweet. G.
04-11-2008, 10:23 AM
#1514 | |
Oddometer: 5,260
Carlos .... could you post some pics of the RD03 front fairing bracket ????? Excitement ????? Oh Yeah !!!!!!!! That's why I'm also bring my friends along ... they'll be checking the trailer chains and tiedowns after I'm done with them ...... : : I'm already drooling guys ................ G.
04-11-2008, 12:08 PM
#1515 | |
Now what?
Oddometer: 2,248
Jim. |
