Old 04-03-2009, 11:52 PM   #3481
Andy G
2wheeled alpinist
Andy G's Avatar
Oddometer: 551
Originally Posted by advNZer?
whats is the difference between rd04 and rd07?
Completely different frame, other fairing, relocated air intake & filter, tank, CDIs and some other small stuff...
Andy G is offline   Reply With Quote
Old 04-04-2009, 12:24 AM   #3482
diskow
diskow's Avatar
Oddometer: 226
My original Honda AT bike.
Original suspension....
But now I decided to make some changes. Progressive front, Ohlins back and more ground clearance.
here is a short video:
http://www.youtube.com/watch?v=ncHJ9reG43s
diskow is offline   Reply With Quote
Old 04-04-2009, 12:29 AM   #3483
ravelv
from Baltic side of river
Oddometer: 444
In '89 they released small book with updates of that year.
Originally Posted by E-Bum
I have the full Honda Workshop Manual and 7 wiring diagrams. What is the addendum?
ravelv is offline   Reply With Quote
Old 04-04-2009, 07:06 AM   #3484
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 635
Originally Posted by Mimer
Translation: ...perfect for desert trips..."
To brew a cup of tea or coffee!
dikow: that's some pretty nice riding there!
Andy G: Just checked your website. Recently updated? GREAT!!!
A-Wind screwed with this post 04-04-2009 at 07:21 AM
A-Wind is offline   Reply With Quote
Old 04-04-2009, 08:05 AM   #3485
E-Bum
E-Bum's Avatar
Oddometer: 717
Ah, I see. I have the 1988 version. Luckily I have an '88 anyway. The changes are probably miniscule anyway.
E-Bum is offline   Reply With Quote
Old 04-04-2009, 08:42 AM   #3486
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,999
I've never had the pleasure of comparing the two side-by-side but most AT guys in europe regard the RD03 as the best model for offroad and the RD07 as the best road/touring variation.
This, of course, is subjective and any of these is still better than what they are offering today. But then, in my opinon, the 89-90 Transalp is better than what's offered today.
Ladder106 is online now   Reply With Quote
Old 04-04-2009, 09:53 AM   #3487
diskow
diskow's Avatar
Oddometer: 226
Originally Posted by A-Wind
diskow: that's some pretty nice riding there!
Ohh ...Thank you very much...
Now we will see if there is going to be any difference with new suspension...
ohlins back and progressive front. i will raise my bike with shorten U link and fork extensions.... we will see
Old 04-04-2009, 02:01 PM   #3488
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,030
Ive owned a TA, an RD03 + an RD04 & riden RD07's a lot, the RD03 is the pick of them all
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 04-04-2009, 03:35 PM   #3489
Papa Pete
RIDES RED
Papa Pete's Avatar
Oddometer: 679
Better best
I like the placement of the air filter on the RD07.
I only had the pleasure to ride a 89 transalp and my RD07
so I guess that limits my opinoin.
I would take both! I will score a Transalp sooner or later.
Papa Pete is offline   Reply With Quote
Old 04-04-2009, 06:35 PM   #3490
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 635
Originally Posted by diskow
I will raise my bike with shorten U link and fork extensions...
I read in other forums that it is a good idea to go with a larger rear sprocket and corresponding larger front sprocket in order to save the chain slider.
Keep us posted with your impressions about handling after the conversion.
Old 04-04-2009, 08:10 PM   #3491
diskow
diskow's Avatar
Oddometer: 226
Do you know how much bigger sprocket? Like 46Teeth rear? 17 Front?
Is it possible to put like 17front and 47 rear?
Thank you for suggestion about that....
diskow screwed with this post 04-04-2009 at 09:37 PM
Old 04-04-2009, 09:36 PM   #3492
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 635
According to what I read 17 is OK. To keep the original ratio, that would correspond to about 48 in the back. But depending on the lift even 48 might not be enough.
Old 04-04-2009, 09:58 PM   #3493
Andy G
2wheeled alpinist
Andy G's Avatar
Oddometer: 551
Thanks! Translation / RR for this site will follow in the next weeks.
Lifting the AT:
I just did this last week with mine, performance test still pending. The shorter link in the rear is said to have a negative effect on the progression. Better put a longer shock (will come as soon as I got the money for that). the guys who realy lifter theis ATs (e.g. with 50mm WhitePower Extreme forks out of KTMs) usually use 17:52 to save the slider. On the RD03 you will in some cases have to cut 1mm of the teeth of the sprocket, otherwise it will touch the shift axle. There is also some material called "Murtfeld" which is said to be rather resistant. We will try this on Hardheaders RD03 during the summer. His bike is lifted approx. 8cm.
The best AT:
in my opinion is the RD07:
advantages to RD03/04: location of the air intake, +10HP, 140 rear tyre, stronger frame, better wind protection by the fairing, some kilos less than RD04
advantages to RD07a: two coils per cylinder, adjustable rear shock
... but that's just my opinion... ... and yes, I never rode an RD04 ...
Cheers, Andy
Old 04-05-2009, 06:07 AM   #3494
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,522
Can you just add an extension to the shock, like we do on the TA's?
I haven't seen an RD07 shock before, but this is what I've done...
It is a wheel nut, 1.5 x 14. The nut is about 25mm and the washer will add almost 2mm. Due to the link geometry the 27mm translates into a 4 to 6 inches of increase in height. Its cheap and I've been using it for almost a year, almost 2000 mi on it and no failure.
But I've noticed that this setup eats the slider fast. I changed the front sprocket to a 16T, but never thought about going bigger..hum
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 04-05-2009, 08:55 AM   #3495
Andy G
2wheeled alpinist
Andy G's Avatar
Oddometer: 551
You can do the same XR-Fork longer shock thing like on the TA, but the AT is even heavier, so setting up the forks is not so easy and you trade two disks against just one, but you could keep the triples... And there is that nice kit around with extensions to the forks and a changed U-link, the mod will take you 2hours and give you 4cm...
Cheers, Andy
Times are GMT -7.   It's 07:59 PM.
