05-14-2009, 08:52 PM
#3751 | ||
2wheeled alpinist
Oddometer: 551
![]() When I'm talking about "special" H4 with bilux socket I mean this: they can relplace the stock bulbs, are halogen and have 40 / 45W, they fit in the stock reflector and stock socket, but don't last very long, in my friends RD03 about one year, I don't know how many Kms. Everything sorted out now?
Tunesia RR (the unfinished) Stella Alpina and Liguria 2009 Balkan 2008 RR Slovenia-RR (TA, AT, DR, 11GS, 650GS) www.agrimm.net (Transalp and AfricaTwin travels) Andy G screwed with this post 05-14-2009 at 09:30 PM |
05-14-2009, 09:04 PM
#3752 |
Owner, Eastern Beaver Co
Oddometer: 201
Andy, thank you for clearing that all up, cheers!
You like the buttpad?
-- Jim Davis, Owner, Eastern Beaver Company: http://easternbeaver.com/ - Motorcycle Electrics. Check out my new fusepanel, the PC-8! 1988 Africa Twin 650, 1990 VFR, Address 110 Super G Riders, Tokyo Riders |
05-14-2009, 09:29 PM
#3753 |
2wheeled alpinist
Oddometer: 551
Looks nice! I used to ride on a complete sheepskin in the beginning of my Transalp days. Once i'll have to scan the old paper photos.
I like the heated riding gear you are selling, that stuff is so hard to find in Germany and extremely expensive. Good night after 9 hours nightshift in the office, here it's 6:30 in the morning... Andy |
05-14-2009, 10:02 PM
#3754 | |
from Baltic side of river
Oddometer: 405
So, then RD03 also have H4 bulbs as well originally? This means that electrical power generated should be enough for two H4's.
05-15-2009, 01:19 AM
#3755 |
Oddometer: 81
My first RD03 '88 had the non halogene bulbs. I replaced them with an adaptor with 2 H4 bulbs and it worked fine for 4 years that I owned the bike. Both lights always worked simultaneously.
My present RD03 '89 already have the H4 bulbs as OEM...so I can assume electrical system can supply enough current whether the bike has the H4 or not... MAZ |
05-15-2009, 11:07 AM
#3756 |
Loco, pero no estúpido!
Oddometer: 2,266
Well, it may. On my case, it is a TAAT so I did the whole wiring with dual relays.
Carlos locorider 1989 Honda XL600V Transalp, slightly modified! 1974 Catalina 22....sailing, mi otra pasión! "If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian "Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller Longaniza Ride Ruta del Café |
05-15-2009, 03:59 PM
#3757 |
Oddometer: 2,266
Bulbs
These are pictures of the now famous rare bulbs that came from France for my RD03 TA mod.
Sorry for the crappy blurry pics.... ![]() ![]() ![]()
05-15-2009, 05:05 PM
#3758 |
Oddometer: 201
Those bulbs used to be quite common. Norton Commandos I believe used the same wimpy bulb or something close to it.
I'm not sure if my RD03 originally had H4s or if the reflectors have been changed. However, the H4s I found in it are 45/45 so I suspect original reflectors and bulbs. It would appear the bike can keep 45w x 2 headlight burning, two modern H4s would only be an extra 20 watts and as the other guy said his burned them for years with no problems. I going to add a Battery Monitor to my RD03 so I'll be able to tell if the battery is being charged even at idle with the dual 60/55 H4s burning. Now the question really is, can it burn them and still heat my jacket liner in the winter? I was thinking actually to make a relay kit where I could cut one beam at will. This way an extra 55 watts is available, plenty for my heated gear. I noticed in some photos I saw and videos that Africa Twins were burning only one low beam and wondered if that is stock in some countries or if they happened to have a bulb burnt out that day? Now I wonder if you burn two 55 watt bulbs perhaps the reg/rect would live longer not having to burn off so much extra power as heat :-)
05-15-2009, 07:09 PM
#3759 |
Oddometer: 2,266
I think it was stock to have one low and two high. Mine had a small bulb on the lower part of the left headlight.
I run two low 55w and the power monitor will remain flashing red until 1500rpm. I was considering adding a switch so that I can turn one off when more output power is needed for the heated vest and hand warmers. I changed to LEDs on the taillight to conserve energy. At 1500rpms, with a green light, when I pressed the brake, it started to blink red, but know with the LEDs it stays green. Again, this is for the TA alternator.
05-15-2009, 11:12 PM
#3760 | |
Oddometer: 405
Just opened XRV650 service manual, there is stated that XRV650 alternator gives 310W@5000RPM's. Same as TA.
If replace all other lights to LEDs, then power should be enough. About headlight: " Headlight (high/low beam) | 12V 35W/35W x 2 | F type: 12V 36W/36W x2 | SW type: 12V 60W/55W " I guess that F type is French and SW is Swiss. Quote:
ravelv screwed with this post 05-16-2009 at 02:18 AM |
05-16-2009, 03:33 AM
#3761 |
2wheeled alpinist
Oddometer: 551
In Germany it was not allowed to have two headlights with low beam on a motorbike. High beam was ok. This changed in 1996 when some EU law took over, now you are allowed to have two of them if your bike is newer than that. But nobody minds if you modify your old bike... That's the reason why most German ATs only run with one headlight on.
Cheers, Andy |
05-16-2009, 03:41 AM
#3762 |
Africatwinarama
Oddometer: 9,758
ah, alternators & bulbs, fun stuff, the RD04 has a 360 watt alternator + my bike has H4 globes, no probs running 2 x 80/100 globes & heated grips.
A couple of the european RD04's imported to Oz came with with wierd yellow bulbs in their headlights, any ideas about that anyone ??
1990 RD04 Africa twin 750 350,000km and still going strong |
05-16-2009, 03:50 AM
#3763 |
Oddometer: 2,266
British imports maybe?
05-16-2009, 04:47 AM
#3764 |
2wheeled alpinist
Oddometer: 551
They should be french. They used to have that yellow stuff also in cars. It's said that the reflection of the yellow light in snow and fog is not so strong as with white or blue light and gives you a better visibility in bad weather.
Cheers, Andy |
05-16-2009, 08:29 AM
#3765 | |
Oddometer: 405
OK, this means that RD04 alternator is one to look for to get more power. I guess it will fit also TA engine?
RD07 seems have something different, even engine cover on left are are different. Quote:
