06-11-2009, 06:39 AM
#3841 |
Oddometer: 62
ventilation for the rectifier.
I earlyer asked for a sidepannel, the reason is that i my rectifier broke, probably because og heat, and since i mounted a new one i thought that i wanted to solve the problem, with some ventilation in the sidepannel, therefore to make a "testrun" i was seeking a spare sidepannel, however patience ran of with me the other day and i ended up making a hole in me excisting pannel, here is the result.
I have seen some italian guys do the same. Has anyone had the same problem with the rectifier? what did you do to solve the problem? Twiniver |
06-11-2009, 07:07 AM
#3842 |
Andreas RD07a
Oddometer: 522
Hi Iver, I admire your fabrication skills. The sidecover-hole project came out very professional looking. However I seriously doubt that this will solve the problem. It is said on other forums, that the main cause of rectifier burning up is a result of connetion problems at the rectifier connections. In short: bad connections -> rectifier heats up. Remedy: good connections. That can be crimping or sodering, if you really know how to soder right (sodering <> sodering)
BTW: rectifier problems are preceeded/accompanied with over/under-voltage problems, which are detectable. A voltage monitoring system, as we discussed a few pages earlier here on the AT-Thread, is advisable. |
06-11-2009, 07:30 AM
#3843 |
Andreas RD07a
Oddometer: 522
There is a big Africa Twin meeting this weekend in Germany.
![]() Too bad it is too far to go for many of us. At least it is sure too far for me. |
06-11-2009, 11:23 AM
#3844 |
Oddometer: 20
06-11-2009, 01:23 PM
#3845 | |
2wheeled alpinist
Oddometer: 551
looks great! I had one of the harmless rectifier deads on my old RD07 a few months ago. Means that it didn't let out more than 11.8V anymore. Better than that thing with 15+V... And the connector looked still nice, clean and new. I replaced the rectifier, put a voltage monitor and cut out the connector and crimped the cables. I tried soldering the ends but my skills are not enough for that. The part coming from the alternator didn't like to bind to the tin. Cheers, Andy |
06-11-2009, 06:16 PM
#3846 |
Loco, pero no estúpido!
Oddometer: 2,266
I did this...and it is working...plenty of holes, a cpu fan and a place to hold a fuse holder...
![]() ![]() ![]() ![]() There has been some argument about covering it, but the fan provides cooling and the aluminum disipates the heat.....we'll see. I like the vent idea....
Carlos locorider 1989 Honda XL600V Transalp, slightly modified! 1974 Catalina 22....sailing, mi otra pasión! "If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian "Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller Longaniza Ride Ruta del Café |
06-12-2009, 03:40 AM
#3847 |
Oddometer: 20
here, you can find anythink we need for your AT.. for recondition...
it is in italian language... http://www.qsl.net/iz7ath/moto/africatwin.htm |
06-12-2009, 06:16 AM
#3848 |
Oddometer: 62
Looks nice with the fan, i also considered that solution, but came to the conclusion that it would only make the electric system even more vulnerable! I will be going out riding tomorow, the weatherforecast says sunny weather and close to 20 degrees celcius so testconditions are in place! I will let you know if the vent-hole works! I read all the things about the voltagemonitor, but i would rather have a analog voltmeter, but then again, more vulnerable things!!!
Hey Andyg are you going to the ATmeeting? Twiniver |
06-12-2009, 05:19 PM
#3849 |
Squily
Oddometer: 1,034
Met a guy (Josh) on the long way round Australia from Brisbane on a DR650. He's been keeping in touch. He is currently in Broome and noticed a few AT's on tour. Anybody know who they are, where they are from or where they are going?
![]() Squily |
06-12-2009, 08:32 PM
#3850 |
Africatwinarama
Oddometer: 9,760
added a new screen,we'll see how it goes,hopefullyit will throw the turbulent air over my head
![]() compared to standard ![]() Also fitted up my Zumo,still got to do the wiring. ![]()
1990 RD04 Africa twin 750 350,000km and still going strong |
06-13-2009, 04:02 AM
#3852 |
Oddometer: 149
Hi Greg.
You're dashboard and the windshield looks good! I just got my Trailtech dashboard and i still don't know what OEM scale should i use. I've been told that the RPM scale on the trailtech is not as accurate as the original and i can see that you left the TEMP and the RPM guage. |
06-13-2009, 06:54 AM
#3853 |
Oddometer: 2,266
Greg!
Hum hum hum...looks great! Did the wind screen came with the frame support?
06-13-2009, 10:21 AM
#3854 |
Oddometer: 149
BTW, how does the original scale can be taken apart like that?isn't it a one chunk?
06-13-2009, 11:55 AM
#3855 | |
Andreas RD07a
Oddometer: 522
