Old 08-14-2009, 10:46 AM   #4096
Andy G
2wheeled alpinist
Andy G's Avatar
Oddometer: 551
Originally Posted by Bocosb
Anyone know what type of AT is this? it looks like a rd04, but the front fairing seems to be from a rd03.. and i don't think that i saw this colors before..
exactly! Or any kind of combination. Forks are RD04 or newer, tank and front side panels are RD03 or 04, rear side covers are RD04, paintjob is custom, bashplate looks like rd04, so I would suggest its mainly a rd04 with some rd03 parts...
cheers, Andy
Andy G is offline   Reply With Quote
Old 08-14-2009, 01:30 PM   #4097
DakarBlues
One-everythinged man
Oddometer: 1,296
RD04 with RD03 fairing
Looks like an RD04 to me (sides, exhaust angle, passenger footpegs, skidplate
double disk).
I is not a problem nor a great expense to replace the front fairing, but it would be quite expensive to replace all the rest.
My take is it's indeed an RD04.
He, whose nuts skim the ground while airborne, won't crash very far!
Pedibus Cum Jambus 1200 S
IBA # 38875
DakarBlues is offline   Reply With Quote
Old 08-14-2009, 03:16 PM   #4098
SurPopp
Oddometer: 7
Originally Posted by GSPD750
Short answer. No.
At 40 k kms it's just broken in.
Buy it...and post pics.
Bought it!!!
I'll post some pics when I'm back home where I left my camera. I just have to make a quick detour to Murmansk first. And Ushuaia. And Leh. And...
I've been laughing out loud several times today! It is such a great bike to ride - I'm happy as a pig in deep shit
SurPopp is offline   Reply With Quote
Old 08-14-2009, 06:33 PM   #4099
GSPD750
GSPD750's Avatar
Oddometer: 1,455
Originally Posted by SurPopp
Bought it!!!
Come over to http://www.xrv.org.uk/forums/ and chime in when you get a moment. Lots of info over there.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 08-14-2009, 07:16 PM   #4100
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,530
I agree...
double disk).
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 08-15-2009, 05:20 AM   #4101
oldmotors
The Professor
oldmotors's Avatar
Oddometer: 13
Originally Posted by locorider
I agree...
I know the bike. It is an RD04 with RD03 front fairing and custom colors. The bike is for sale.
Powered by morning coffee!
oldmotors is offline   Reply With Quote
Old 08-15-2009, 11:26 PM   #4102
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,591
Choke Plungers
Gday,
Pulled the carbys off the bike today, concerned about high fuel usage.
Are the choke plungers supposed to be sealed ? Looks like someone has been heavy handed on the plastic retainer bits and broken them. One had a poor attempt at glueing them and the other had a brass plug. See pic.
Was thinking of getting rid of the choke cables etc. Not really needed the choke in Queensland. & Just putting in blanking plates from the front brakes.
Any ideas anyone ?
Hodgo screwed with this post 08-24-2009 at 01:19 AM
Hodgo is offline   Reply With Quote
Old 08-16-2009, 12:45 AM   #4103
meljordan
A simple machine
meljordan's Avatar
Oddometer: 8
Originally Posted by Hodgo
Gday,
Any ideas anyone ?
Hi, blanking the chokes is a common mod here in the UK and it will take your MPG back to normal.see xrv.org.uk and do a search as its been well documented......
IT IS BETTER TO TRAVEL ONE MILE THAN READ A THOUSAND BOOKS. (confusious-clever bloke)
meljordan is offline   Reply With Quote
Old 08-16-2009, 01:39 AM   #4104
fabienlegall
Oddometer: 66
Thumb
Hi Mel,
Glad to see you here too
fabienlegall is offline   Reply With Quote
Old 08-16-2009, 01:41 AM   #4105
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,591
Done, & removed the jammed up choke cables. Pinched the blanking plugs from the front brake calipers. Same size and done on the xrv.org site. Cleaned the carbies and a general once over. Cleaned the main jets. All gummed up with light brown stuff.
Put the carbs back on next weekend and try her out. Should have the clutch cable by then too. Getting some made up to exact spec of OEM cable for $40 AUD each. Keep one as a spare.
Tks meljordan much appreciated.
Old 08-16-2009, 01:44 AM   #4106
Jacqueslemac
Jacqueslemac's Avatar
Oddometer: 75
Originally Posted by fabienlegall
Hi Mel,
It's a small world isn't it?
2003 Triumph Tiger 955i.
1990 Africa Twin RD04.
Jacqueslemac is offline   Reply With Quote
Old 08-16-2009, 04:15 AM   #4107
fabienlegall
Oddometer: 66
Oh yes it is
Old 08-16-2009, 06:50 AM   #4108
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 638
...Should have the clutch cable by then too...
...Looks like someone has been heavy handed on the plastic retainer bits and broken them...
Peter (same login/screenname) on German Africa Twin page FAT is selling these "plastic retainer bits" for the choke, which he fabricated out of aluminium. I think they are about 10 Euro each, but considering it is quite some work involved in the fab, I think it is reasonable. Also think about how expensive the crappy plastic OEMs are. I already got two of these from Peter and will install them by next chance.
If you want to get in contact with him, his homepage is http://www.wuestentwin.de/
He also sells revised springs for the back of the clutchplate, the ones that start rattle on OEM configuration.
A-Wind is offline   Reply With Quote
Old 08-16-2009, 08:07 AM   #4109
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,020
I can understand wanting to eliminate those fragile plastic fittings.
However, just "blanking-off" the holes with nothing inside doesn't seem like the correct method.
I'd think that the two small rubber seals would have to be replaced and the brass bits and springs would have to go in. The "blanking plate" would hold those parts inside the carbs.
The important bit is that the "enrichening circuit" of the carb has to be closed and the way to do this is to have those brass bits seal the passage with the rubber tips.
Otherwise, your carbs would be running with the "choke" ON all the time.
Ladder106 is offline   Reply With Quote
Old 08-16-2009, 11:50 PM   #4110
Jim Davis
Owner, Eastern Beaver Co
Jim Davis's Avatar
Oddometer: 230
Mosfet R/R Unit installed on RD-03
Well guys I told you about the R/R unit I picked up on EBay and how it is the new type with Mosfets and supposed to be cooler and better, well here's the results of today's swap:
http://easternbeaver.com/Main/Stuff/.../r-r_swap.html
This should liven up the thread heh heh.
So you want to know how hot does it get? Well I don't know yet but I'll see if I can touch it after a long run on a hot day. I'd like to put a remote temp probe on it, but likely won't go that far. I'm looking forward to a well charged battery though...
I may be able to borrow my friends' temp gun, but it won't be for a couple weeks.
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics.
2012 Yamaha WR250R in Japan.
Jim Davis is offline   Reply With Quote
Times are GMT -7.   It's 02:41 AM.
