Old 08-29-2009, 07:01 PM   #4171
nobody
motomaniac
nobody's Avatar
Oddometer: 1,738
What`a beauty...Always no.1 in my wish list.
Everything happens for a reason!
nobody is offline   Reply With Quote
Old 08-29-2009, 07:28 PM   #4172
GSPD750
GSPD750's Avatar
Oddometer: 1,439
Looking at those specs it was the good old days when they built a simple reliable and mostly durable motorcycle. Judging by the threads on this forum of the woes the BMW 800GS is having it feels good to own an Africa Twin...in any shape or form. Watch for AT's, as they come up for sale in the lower 48 more than you think.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 08-29-2009, 08:34 PM   #4173
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
One in flea market right now.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 08-30-2009, 01:33 AM   #4174
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,021
US AT help needed
http://www.advrider.com/forums/showthread.php?t=501321
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 08-30-2009, 02:09 AM   #4175
Jim Davis
Owner, Eastern Beaver Co
Jim Davis's Avatar
Oddometer: 229
Not shredding this one!
Hi all, finally got the Sahara rear tire and mounted her up. Chalk one up for the Africa Twin, the rear wheel is so easy to get off you could do it blindfolded. Well maybe not, but it was my first time and I had it off, changed the tube and tire and back on in less than an hour.
I have some questions, but first look at these photos:
http://easternbeaver.com/Main/Stuff/...re_change.html
Questions:
1 - why is there no light spot marked on these tires? Is that normal for tube type off road tires? Don't people balance them then? I put on 40 grams just to get close. Not sure if that's a lot of weight, heck it's less than 2 ounces but it's more than I prefer.
2 - why is it that people pinch their tubes?
3 - why don't people always replace a tube with a new tire?
4 - why does my wheel rim have holes that look like they'll eventually eat right through them?
I can't wait to test out this tire, man this thing has thick tread on it!
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics.
2012 Yamaha WR250R in Japan.
Jim Davis is offline   Reply With Quote
Old 08-30-2009, 05:31 PM   #4176
DakarBlues
One-everythinged man
Oddometer: 1,285
SOHC and not DOHC
There is a typo in the brochure, AT is an SOHC engine each header has a single overhead camshaft with 3 valves.
He, whose nuts skim the ground while airborne, won't crash very far!
Pedibus Cum Jambus 1200 S
IBA # 38875
DakarBlues is offline   Reply With Quote
Old 08-30-2009, 09:41 PM   #4177
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,557
Interesting Find
This seems a bit odd but there is reference to the 15.9 kgm of touque ? Doesnt seem right.
And there is reference to 62.7Nm of torque.
Interestingly enough the AT has more torque than a KTM 950 @ 55Nm of Torque.
No wonder the KTM couldnt get away from me on Sunday.
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 08-30-2009, 10:51 PM   #4178
DakarBlues
Oddometer: 1,285
torque value
It's another typo, the real value is 6.1 kgm (even though I saw 6.8 kgm on other publications).
This gives 59.8 Nm at 5500 rpm.
IBA # 38875
Old 08-31-2009, 01:44 AM   #4179
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,557
59.8Nm is still quite good for a bike of that era. Compared to the 950KTM.
Hodgo Spot
Old 08-31-2009, 02:36 AM   #4180
Jim Davis
Jim Davis's Avatar
Oddometer: 229
ho de ho, more RD03 tire testing
Well it is a bit of tradeoff, you want high HP figures to sell bikes, you give up some torque :-)
Now, I'm curious about tire pressures on my AT. If all those conversions and figures didn't make your head hurt, how does 190 Kpa front and 230 Kpa rear sound? High? Thought so...
Well that's what I had in my AT today and it felt quite hard. I've lowered it when I got home to 160 front and 190 rear, does this sound about right for mostly pavement riding on Saharas?
I started out today in the rain, with the new Sahara on the rear I was taking it easy, still I could feel the rear step out a bit at the first corner - scary having a new tire in the rain!
Anyway, scrubbed her down pretty good today - after a few hours she felt pretty good. At least it got well washed off. Next outing I'll have to work on the chicken strips.
New tire, what with higher pressure and new tire profile, felt rather odd today compared to what I'm used to. I'll try the lower pressure tomorrow and compare.
So what pressure are you all running? (for data, I am a 90 KG rider on an RD03).
No idea of proper pressure. I can't even remember what I ran before the tire change but I know the front was a bit soft. I'm going to keep an eye on that one, might have a patched tube with a slow leak, or I might have just run it low.
Pressure conversion chart here:
http://www.webbikeworld.com/Motorcyc...sion-chart.htm
Oh ya, noise? The new Sahara rear is quieter at speed than the T63 that came off, but it's got a pucka pucka kind of sound when going real slow. You can hear the tread gripping the pavement.
Old 08-31-2009, 03:30 AM   #4181
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,021
i run about 30psi front & 32 rear on the tar, 22F & 24 on dirt roads, with Michie deserts on for outback trips I'll go down to 18 F+R for sandy sections
Old 08-31-2009, 04:56 AM   #4182
Jim Davis
Jim Davis's Avatar
Oddometer: 229
Greg, thank you for that info. The pressures sound a bit high for the kind of pavement I ride, but would likely be fine on a straight smooth road.
Unfortunately (or rather, fortunately :-) I like to seek out the twisty roads with often bumpy pavement so those pressures might be a bit high for me.
I may even out front to back a bit more as you've done, slightly higher in back than front but not too much, I think about 26/28 psi will do for me.
Old 08-31-2009, 05:07 AM   #4183
Capse
Oddometer: 5
hello
I new around here and a proud owner of a RD04
i have a problem with it and i don t know what it is.
When i pass over bumps there is a strange noise comming from the front fork witch i ve serviced and seems to be working fine
A friend told me the cause could be the bearings from the steering yokes
Replacing the bearings should solve the problem?
P.S I l post some picures with the bike soon
Dare to be different!
Capse is offline   Reply With Quote
Old 08-31-2009, 07:53 AM   #4184
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,484
Not a difficult task to perform. First lift the front wheel and with a little help, try to move the whole front suspension assembly to see if there is a bearing problem....did you placed the correct amount of oil in the forks?
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 08-31-2009, 04:12 PM   #4185
Gian
dreamer
Gian's Avatar
Oddometer: 1,182
Nice RD04 brochure, the driver has the same jacket boots and pants of the guys who used the "650 Marathon" at Dakar '89 and '90
Gian is online now   Reply With Quote
Times are GMT -7.   It's 01:05 AM.
